Old 28th December 2016, 10:26   #2941
Thanked: 21,423 Times
Originally Posted by rajivtelang View Post
Great. I will place order in that case. I will place order for 5 quantity. I assume it is one hub cap per packet.
I hope you'll be placing an order with the MGP stockist in your city rather than the guys. It is easily order-able and you would get it within 7 days.
Shipping charges on that website are atrocious hence I stick to MGP stockist to get me the parts.
Originally Posted by arjithin View Post
That is correct. By the way I have no prior experience with the above website, I just found it while googling.
Old 28th December 2016, 11:21   #2942
Amey Kulkarni's Avatar
Thanked: 1,687 Times
re: Review: 1st-gen Maruti Ertiga
I am pleased to announce the purchase of a new Ertiga ZDI+ 2016 Silky silver color.
During the initial running-in , I am trying to maintain upto 2,000 RPMs for the engine to properly break-in.
I have also purchased a few accessories to go along with the vehicle from Maruti Suzuki showroom itself viz -
1. Spoiler
2. Door chrome handles
3. Window chrome garnish
4. Floor mats
5. Seat covers
Observations (Cons) -
1. Poor headlamp quality; lacks visibility
2. No Auto climate control
3. Getting used to the SHVS mode; where running on neutral shuts off the engine.
4. Imperfect voice recognition
Review: 1st-gen Maruti Ertiga-silkysilver1350x205.jpg
Review: 1st-gen Maruti Ertiga-29553_maruti_suzuki_ertiga_005_468x263.jpg
Amey Kulkarni is offline   (2) Thanks
Old 28th December 2016, 20:03   #2943
Thanked: 567 Times
I second that along with some other ertiga owners. I still have not driven my ertiga much in dark but whenever I do I feel the same everytime. Even my estilo had same issue and had put good fog lamps to compensate. They were damn good and worked well with main lamps.
What are the options for ertiga here?
Are there better fog lamps or high wattage head lamps? In any case I do not want to exceed the load on battery. That might burn or melt the relays in electric box.
Paragbhai any suggestions from your end?
rajivtelang is offline
Old 28th December 2016, 20:27   #2944
rakesh_r's Avatar
Thanked: 3,150 Times
Please go ahead and install a good 100/90 watt bulbs with a proper headlamp relay. Do PM me if you need the details of the electrician who can do the job.
rakesh_r is offline   (1) Thanks
Old 2nd January 2017, 16:01   #2945
Guys,
My Auto door-lock system at speed of 15Kmph is not activated.
Any idea on how to activate it?
Cheers,
Amey
Old 2nd January 2017, 16:44   #2946
Thanked: 78 Times
Many Congratulations on your Ertiga!! Can't agree more.. Had a similar concern and I went ahead and did what Rakesh has mentioned
Also, consider upgrading your stock fog lamps for additional light. Upgrade to H11 55W from the conventional H8 35W (I think one of the earlier posts by Parag has that info)
Thank you!
Vikram
vikramv4u is offline   (1) Thanks
Old 2nd January 2017, 16:50   #2947
blackwasp's Avatar
Thanked: 26,393 Times
Guys,
In your manual there is a setting for doors (all door opening vs only driver and security ( sensitivity of alarm ). In the same menu you can find the option for auto door lock (enable/ disable ). You have to make use of control stalks coming out of the speedo console.
blackwasp is online now   (1) Thanks
Old 3rd January 2017, 09:48   #2948
Thanked: 71,437 Times
Ertiga Facelift ( code YHA ) due in 2018/19 rendered,
Review: 1st-gen Maruti Ertiga-suzukiertigarenderrbadesign.jpg
Review: 1st-gen Maruti Ertiga-11.jpg
Link
Old 11th January 2017, 11:32   #2949
souravbasu's Avatar
Thanked: 11 Times
Guys,
Cheers,
Amey
How to operate the setting mode:
1) When the ignition mode is “ON” and the vehicle is stationary, push the trip meter selector knob (1) to switch the information display indication to the trip meter.
2) Push and hold the indicator selector knob (2) until the display shows “door”.
3) Turn and/or push the indicator selector knob (2) to select a function that you want to set up according to the above chart.
4) Turn and/or push the indicator selector knob (2) to register settings of the following functions.
Try changing the door settings from the options given below:
Automatic door locking function “d2”:
• d2 - SL 1: Disable the automatic door locking function
• d2 - SL 2: Lock all doors when the vehicle speed reaches 15 km/h (default setting)
Automatic door unlocking function “d3”:
• d3 - SL 1: Disable the automatic door unlocking function (default setting)
• d3 - SL 3: Unlock all doors when the ignition mode is changed to “LOCK” (OFF)
Door locking and unlocking siren “d5”:
• d5 - SL 1: Siren sounds when the doors (including the tailgate) are locked or unlocked by using the keyless push start system remote controller or request
switch (default setting)
• d5 - SL 2: Siren does not sound when the doors (including the tailgate) are locked or unlocked by using the keyless push start system remote controller or request switch.
Source: Page 2-62 of Ertiga User Manual Ertiga_Owner's_Manual.pdf
Last edited by Rehaan : 7th September 2020 at 19:09. Reason: Old post, but editing it to fix a small problem with mobile page formatting :)
souravbasu is offline   (2) Thanks
Old 11th January 2017, 13:04   #2950
Thanked: 115 Times
Has anyone fitted an external tachometer on LXI model? I'm planning to fit one, can someone help with the wiring.
saurabhkum is offline
Old 15th January 2017, 20:59   #2951
arjithin's Avatar
Thanked: 2,536 Times
My Ertiga has got a strange problem for couple of years now. The front driver power window gets stuck (nothing happens when the power window button is pressed or pulled up) occasionally. The only way to get it working again is to switch off ignition and start again.
I have this issue for years now, but never was able to reproduce inside workshop. Maruti did replace the power window switches hoping that is the issue, but it didnt solve the problem. It was frequent ( once in a month or so) during year one and two, then didnt see the issue for a long time ( last 12+ months), but now its happening again. Today it was so severe that it was getting stuck every 1 inch movement or so, but an hour later the window is going up and down without any issues.
Any pointers on the potential cause will be appreciated.
arjithin is offline
Old 15th January 2017, 22:14   #2952
audioholic's Avatar
Thanked: 20,080 Times
My Ertiga has got a strange problem for couple of years now. The front driver power window gets stuck (nothing happens when the power window button is pressed or pulled up) occasionally. The only way to get it working again is to switch off ignition and start again..
I would rather suspect the window regulator to be faulty and not the switch. If there is an issue with switch it should not go away after ignition restart. It will be a faulty regulator that is responsible for cutting out current to the motor when the window is fully rolled down or up. If this is faulty it might cut the motor unnecessarily or might not even let the motor run. Try replacing the regulator/motor assembly and this problem should disappear.
audioholic is offline   (2) Thanks
Old 18th January 2017, 16:30   #2953
Thanked: 30 Times
Need guidance on changing stock headlights for Ertiga SHVS VDI.
Which is the recommended Wattage 55/60 W H4/H8/H11 which can be used ?
Any brand - Osram/Philips etc ?
Is white lights recommended ?
speedkrish is offline
Old 19th January 2017, 23:43   #2954
sms255's Avatar
Thanked: 40 Times
Ertiga Vxi vs Zxi
I have decided to exchange my Wagon R Lxi, which I purchased in Oct 2013, odometer says 22K, with Ertiga petrol.
But I am confused between Vxi and Zxi. Extra features in Zxi are 4 alloy wheels, driver seat height adjustment, rear washer defogger, 2 tweeters, chrome bezel above fog lamp, all of this costs 68K rs more.
Now my question is, are those extra features really helpful ? If yes, can you please help me in understanding why like ally wheels, dealer is saying it adds to the looks plus increases mileage of the car about 1km/l ?
And is the extra price 68k justified ?
One more thing, Vxi has waiting of 45 days whereas Zxi is available with dealer (jan 2017 manufacturing).
sms255 is offline
Old 20th January 2017, 08:05   #2955
blackwasp's Avatar
I think this is the main reason. Except for driver's seat height adjust and rear wash/wipe, the other features are not very critical. If you are satisfied with seat height of Vxi, you can go for it.
Good thing is, on the safety front you are covered - dual airbags and abs with ebd. So you can go for Vxi and save some money.
