Old 27th February 2019, 12:39   #2881
ashishrathi88's Avatar
Thanked: 109 Times
Originally Posted by mukeshgoel View Post
Hi guys,
Handbrake of my Swift Vdi 2013 is not so effective anymore. It starts moving if parked on a steep incline with handbrake fully pulled.
What could be the reason?
@Mukesh : It is because the hand brake cable has loosened up and needs to be tightened.
Its a very easy DIY operation which will hardly take 10 minutes.
This can be done by removing the hand brake panel having one clip on each side and then tightening the brake cable till the slack is removed.
This will reduce the hand brake lever travel which will as a result improve the braking.
ashishrathi88 is offline   (1) Thanks
Old 27th February 2019, 14:28   #2882
mukeshgoel's Avatar
Thanked: 2,396 Times
Re: Review: 2nd-gen Maruti Swift (2011 - 2017)
Thanks. Got it it fixed at a FNG few days after I posted my query.
mukeshgoel is offline
Old 28th June 2019, 19:34   #2883
self_driven's Avatar
Thanked: 3,393 Times
Can any Swift petrol owners confirm the idling RPM when the engine has warmed up, with and without AC?
My car is idling at 900 RPM with AC and 650 RPM without AC. While 900 RPM is alright, I find 650 RPM idle to be on the lower side. Slight engine vibrations are also present at 650 RPM.
self_driven is offline
Old 28th June 2019, 19:38   #2884
Rshrey22's Avatar
Thanked: 716 Times
What's the mileage on the odo? As the car ages, engine mounts weaken and you feel slight vibrations at idling. My dzire also idles at 650rpm without ac. Ignore minor vibrations.
Rshrey22 is offline   (1) Thanks
Old 28th June 2019, 20:41   #2885
Odo is a little under 29k kms but age is almost 5 years.
If your car also idles at 650 RPM, then there should not be a problem. I was more concerned about idle RPM than the minor vibration. Thanks.
Old 28th June 2019, 21:25   #2886
Thanked: 1,816 Times
Mine also idles at 650 rpms. Even I feel its a tad lower and due to it you have to slip the clutch a little sometimes. It also causes vibrations.
Sherlocked is offline   (1) Thanks
Old 28th June 2019, 23:59   #2887
Yes, idle RPM should not be so low. I'll report this issue to MASS on my next visit as my ext. warranty also expires after that and any replacements will have to be paid out of pocket.
Old 2nd August 2019, 17:01   #2888
pranjal1984's Avatar
Thanked: 103 Times
4th year service cost me Rs 7500. Also completed 440kms trip to Cherrapunjee with family and the car performed admirably.
pranjal1984 is offline
Old 28th October 2019, 23:20   #2889
shashank.nk's Avatar
Thanked: 1,066 Times
On a recent highway journey, I noticed the IRVM used to vibrate at speeds above 80 whether in 4th or 5th gear and as a result the mirror wasn't very usable.
What I also noticed was that the in the few seconds when shifting from 4th to 5th, the IRVM was absolutely fine. The vibrations seemed to creep in only when the clutch was fully engaged, if I had my foot on the pedal when shifting up the IRVM was absolutely fine.
Is it a simple IRVM issue or have the mounts given up ? My car is a Swift ZDI now 8 years old with 66k on the odo.
shashank.nk is offline   (1) Thanks
Old 14th November 2019, 22:33   #2890
In my Swift petrol, second gear is not slotting freely while up shifting from first. Second gear can only be slotted by putting the gear shifter to neutral from first.
What could be the issue?
Old 14th November 2019, 22:52   #2891
Thanked: 10,216 Times
If the other gears slot perfectly, it might be the synchroniser rings that have gone bad on your car. Take it to the A.S.S and get clutch bleeding done. If it still persists, it is the synchro rings on their way out.
vishy76 is online now   (1) Thanks
Old 14th November 2019, 23:04   #2892
A lot of Swift diesels have synchroniser issues but this is the first time I'm hearing about this problem in a petrol Swift. Also in Swift diesel, when the synchroniser issue crops up, the problem is in downshifting from third to second, whereas in my car, problem is in first to second.
Old 14th November 2019, 23:12   #2893
The reason why i suggested bad synchro rings is because:
- You are facing issues only with specific gears
- You are having trouble going from one gear to the other, and not slotting from neutral into a gear. If it was the latter, clutch bleeding would have helped, but the fact that declutching is happening perfectly means that your clutch is not at fault. It is most probably the gearbox and synchro rings
This is what my conclusion is. Take it to a service centre. They can judge best. We can only sit here and draw conclusions
Old 14th November 2019, 23:51   #2894
Thanked: 2,389 Times
Infractions: 0/1 (5)
It is undoubtedly the synchronising rings. Maruti cuts corners and uses cheap quality materials. It’s a known issue and I’ve had the exact same issue in my Swift diesel. Please take it to any FNG and they will change the rings and it will be absolutely fine.
Lalvaz is offline   (1) Thanks
Old 15th November 2019, 08:03   #2895
Thanked: 92 Times
Yesterday all of a sudden when I started my Swift petrol of 2016, all the power windows stopped working apart from the one on driver side. I am planning to take it to the SA tomorrow, but just wanted to check in and see what could be the potential cause? There is absolutely no sound or movement when I operate the power windows all over the car.
jphukan is offline
