Originally Posted by abhijeetsng
(Post 4031788)
Yesterday evening while driving back home, it started raining very heavily. All of a sudden the airbag sign on the console lit up. It is now on continuously. How to go about it? Help! |
(Post 4031788)
Originally Posted by Jag4
(Post 4032017)
Have you installed aftermarket horns ? My car ran normally up until 3 years after which the same thing happened. I will be getting it repaired in the coming week. It is a clockspring issue if you after market horns. Use a relay after changing the clockspring. |
Originally Posted by Pancham
(Post 4031972)
Must be a clockspring issue. Get it checked. If that is the case it would around INR 2100 to get it replaced. |
(Post 4032017)
(Post 4032065)
Will get clocks print checked. |
(Post 4031788)
Originally Posted by Akib Khan
(Post 4032135)
i have faced the same issue few years back and as JAG4 said most of the time aftermarket horn is the real culprit. If you have not installed new horn then i recommend you to visit a garage and get your car scanned and all the wirings checked. Remember your airbag will not work as the clock spring is damaged. So get it checked ASAP. |
Originally Posted by hrbheda
(Post 4032124)
If your steering wheel controls don't work then the clockspring is at fault. Hope this helps! |
(Post 4032534)
Not necessarily. When it happened in my car the controls were working perfectly fine. |
(Post 4032534)
(Post 4032124)
If your steering wheel controls don't work then the clockspring is at fault. If they work then it can be various other things. As small as a blown fuse/wire cut or a wheel speed sensor for which the whole hub has to be changed. The sensor and it's tone ring are fixed onto the hub and cannot be opened/changed separately! Don't know what Hyundai engineers were thinking when they designed them! Hope this helps! |
Originally Posted by tsk13
(Post 3513242)
I've a 5 years old i20 Asta Petrol which has clocked over 87k on the Odo. About an year ago, I had the Steering mounted Audio Controls acting weird and eventually they stopped working altogether soon. I inquired from a Local Audio guy for the fix and he reverted in negative since he never undertook this kind of a job. A week ago, my horn refused to blow and upon checking with the Accessories shop, he told me that the Steering needs to be opened and shall cost something about Rs. 1,500. Since this very model has Airbags I headed to Hans Hyundai Service Centre and conveyed my issue to the SA there. They changed the Clockspring behind the Steering wheel which acts as an Electrical Signals Link and both Horn & Steering Mounted Audio Controls started working. Total Cost was Rs. 2054 which also included Wiper Blade Rubber (Rear). I suppose the Steering Controls issue is a common problem hence posting here for the benefit of members at large! |
(Post 4192676)
I am facing a serious issue lately. Whenever I am turning the steering wheel with the car at standstill or at very low speeds, say during a 2-3 point turning corner, the steering is making 'khat khat' noice and is getting stuck intermittently. It even lost the power steering 2-3 times(the light in the dash came up). Anyone faced a similar problem here. Other than that the car is still running beautifully. No other noice or rattle on it 7th year. |
