Re: Pictorial Guide: How to change a flat tyre! Quote:
Originally Posted by iraghava Once the wheel nuts are tightened, lower the jack by turning the handle anti-clockwise and remove the jack from its mounting point.Then take the wheel spanner & fully tighten all 4 wheel nuts, again in the same diagonal order. Attachment 53406 And if need be, please stand on the spanner again! Attachment 53407 And so, you've changed a flat tyre! Remember to keep all the tools backs into the boot & the spare tyre too! |
Another pro tip i learnt from my dad, loosen the nuts, place the scissor jack in position, extend it so its making contact with the vehicle (dont lift it too far up), wiggle it a bit to make sure its secure (incase its on gravel/ not on a completely flat surface) and before lifting it further off, take the spare wheel, and place it under the side of the car. This way if the jack stand fails, the car falls down onto the wheel, so your disc brake rotor/other parts dont get damaged, or worse, any part of your body getting caught under the car. PLEASE INSPECT YOUR SCISSOR JACK FOR ANY RUST, IF IT DOES, PLEASE DO NOT USE IT
You might also think that if you raise the jack higher, youll have more reach, but please dont do this. Jack it up as less as possible, as the higher you jack it, the narrower the jack arms become, and the more likely it is to break/bend and fail. Factory scissor jack stands should only be used in emergencies, for doing diy maintenance etc, please get jack stands, these hold the vehicle in place and are far safer/Pickup ramps to drive the car up on. The spare wheel trick can still be employed in this situation too, if you have spare tyre walls, even better.
Also while placing the wheels on the ground, make sure the wheel face is facing up, and the back of it is on the ground, this wont scratch up your rims
Reason: Trimming quoted post.
