Cyrus, Mag, Hemanth, Zak, Snaronikar, Rex - Thanks guys! Quote:
Originally Posted by Sudipto-S-Team Placing the nut back should be done in a properly aligned way. You run the risk of damaging the thread if you aren't careful and the alignment is wrong. Also with some alloy wheels inserting the nut back is slightly tricky. An easy solution is to use "gooti" wrench where you place the nut in the wrench and then tighten it gradually. |
Correct SST! I forgot to mention that leaving it to the person to improvise on the spot! Quote:
Originally Posted by Sudipto-S-Team For a long time I was convinced iraghava was a tyre dealer. ![Smile](https://www.team-bhp.com/forum/images/smilies/smile.png) |
You're not the only one who thinks that! Quote:
Originally Posted by manjubp I remember reading some where "before removing the flat tyre, keep the spare tyre below the car, such that incase jack slips the car will not be grounded, and will have chance to inser the jack once again. Once the flat tyre is removed, once again place same in place of spare tyre below the car, until the spare tyre repalcement process is completed". |
Thank Manju! And yes, that is do able but I won't like to damage a wheel by putting a car's weight on it! Also, if you are careful enough to park your car on level ground & pull the handbrake & engage the gear that should not happen. Unless your jack fails or your car gets hit by another vehicle. But then again, it does not cost us anything to take one more precaution. Quote:
Originally Posted by benbsb29 Good thread, Ishaan. Thanks for the clarification as well, regarding using two cars for the demo. I thought you got both of them punctured for the demo! LOL!! |
Thanks Benny! Neither had a puncture, the tyre was just removed for demo only! Quote:
Originally Posted by Sudipto-S-Team I have a friend who hails a cab when he has a flat tyre. Gets the driver to change the tyre. Pays him Rs 20 or so. Drives away. If stuck on the highway he says he would hail a truck. I doubt they would stop. But anyway. Different strokes work for different folks. |
Believe it or not but before the days of tubeless tyres, my mother has faced the situation & has been helped out by truckers on multiple occasions. I even bought her a set of Bridgestone Donut tyres twice just because they came with a guarantee that they would be replaced even if you tore them after driving them on a puncture! Gave me some piece of mind! Quote:
Originally Posted by Sudipto-S-Team Talking about DIYs - lot of people don't know how to open their bonnet and check oil/coolant etc. In fact someone should show this also with a pictorial guide ![Big Grin](https://www.team-bhp.com/forum/images/smilies/biggrin.png) |
Now you're just taking the mickey out of me!! Quote:
Originally Posted by lancer_rit I read on Car and Tyre bible that there is such a thing as "tightening the wheel nuts too much" !! It seems to be a problem - so just want to caution that please don't stand on the spanner excessively ;-) Maybe, you don't need to stand on the spanner at all. |
Correct but that applies more to air guns at Tyre Shops then the wrench in your hand. Reason being that unless you're exceptionally strong, the situation where you would manually over tighten a wheel would hardly ever arise. Also, a slightly tightened wheel is more desirable IMO to a loose wheel. Quote:
Originally Posted by lancer_rit One thing I would like to highlight is that alloy wheels these days come with female type nuts which needs a key to apply your wheel wrench. Most important is to keep this key always in your car (and not lose it). A couple of months back, I rescued some folks in the small Kalasa town up in the hills on a Sunday early morning, who had a flat but could not find the wheel key. So, please take care especially if driving to remote places. |
Correct again but these are still rare on cars in India. The one I can recall off the back of my mind is the RS though. |
