Old 14th January 2011, 23:25   #1
Thanked: 52 Times
Lancer D - Rust in radiator, coolant is gone
My lancer diesel has problem in cooling system. After changing engine oil, i casually opened radiator in engine off condition, i could see the vertical pipes dry, i was shocked and poured around 3-4 glass of water. but i have not seen trace of coolant color (green). it is like rust color water.
This problem was before, and i have flushed once and mixed TVS ezicool with water and poured in radiator, but still the color changes slowly to rusty , and now the water level has dropped.
I have no trace of oil in radiator water
No trace of creamy layer or brownish color in oil when i changed oil last day
The temperature gauge shows is just below half mark in lancer gauge, not above half mark. (lancer diesel owners . please help, am i right? )
When i opened radiator cap, there was mud/rust color sediments around cap, and near neck.
if i start engine when radiator cap is open, the radiator erupts water outside and bubbling like air is supplied in.
if i raise little bit RPM, then the water is normal, (not coming out)
The fan is working good.
No leak in coolant system
What could be the problem?
I will post the pictures of radiator cap and color of water tomorrow.
rajivanoj is offline
Old 15th January 2011, 15:39   #2
Thanked: 318,195 Times
Re: Lancer D - Rust in radiator, coolant is gone
The only times I've seen a bone dry radiator in modern cars is when the fan went kaput. Though you claim that your cooling fan is functioning properly, I'd still advise getting it checked.
How old is your car and the radiator? The radiator's internals are definitely rusted. You need to get it re-conditioned or, preferably, buy a new unit.
GTO is offline
Old 15th January 2011, 16:03   #3
nitrous's Avatar
Thanked: 332 Times
Remove the radiator from the car.
Give it to a renowned radiator guy and explain the issue. He should be able to diagnose if there's anything wrong with the rad.
The leak could be at the radiator hose too.
PS: This condition is very bad for the engine. Get it sorted ASAP.
nitrous is offline
Old 15th January 2011, 18:24   #4
dhanushs's Avatar
Thanked: 11,058 Times
Usually coolant oil also prevents rusting of radiator insides. In this case, the car must have run with less coolant, or saline 'water' for a while which has caused the rust.
When you topped the coolant fluid, damage had already been done and hence the rusty colored water. Please get it cleaned up/replaced asap.
This is normal.
dhanushs is offline
Old 15th January 2011, 18:40   #5
Thanked: 52 Times
@ all
as you all suggested, i will contact radiator service on monday, will clean it, also as GTO said, i need to check the fan condition once again.
Is there any problem with gasket??
Old 16th January 2011, 01:27   #6
Thanked: 81 Times
This is an indicator of a leaky head gasket. Are you sure that the engine isn't overheating ?
CrackedHead is offline
Old 16th January 2011, 03:29   #7
dhanushs's Avatar
If the head gasket is leaky wont there be oil in coolant?.
dhanushs is offline
Old 16th January 2011, 10:31   #8
Thanked: 52 Times
@cracked head
The temperature gauge shows just below half way mark, in my lancer D, even with AC on, i dont know whether it is the same normal criteria in lancer diesels, only owners of lancer D can clear the doubt.
@dhanushs
Yes , there is no trace of oil in radiator water, even though i have changed oil 3 days back, the oil is pitch black, not brownish color or creamy color as it will change color if water mixed with oil.
But mechanic say it is indication , that gasket is losing its life. since the water comes out in idle when radiator cap is in open state, and air bubbles coming.
Anyway i am going to take car to another mechanic to know exact problem,
As for cleaning radiator, one mechanic suggests to pour three sachets of shampoo with ariel washing powder in radiator and run car for 2 days, then drain it, all dirt will be flushed, he says so, i am confused. Since radiator service costs more than Rs.500 in given to shop. What he says is right??
Old 16th January 2011, 18:43   #9
Thanked: 52 Times
I have uploaded close up shot of radiator neck and cap.
The video , i have added in youtube
Just after starting cold engine
After 1 minute, the water eruption have stopped. i dont know what is happening.
Old 16th January 2011, 21:10   #10
narendra.vw's Avatar
Thanked: 425 Times
Looking at the video I don’t think any problem with engine head gasket.
Take the car to the nearest service station, remove bottom hose. From the top wash the radiator using pressure water hose . See that all dirt comes from bottom hose. Fit back B/hose & fill the coolant(add lubricating additive for radiator). Before closing the cap run the engine , try to press all hose pipes leading to the radiator. This will help in removing all air locked inside the engine. Close the cap allow the engine to run normal temp. see if fan switches on . If yes then your car fan working fine. Also see the time duration of the fan. If it stops working with in seconds then you have to change the thermostat switch.
narendra.vw is offline
Old 16th January 2011, 21:13   #11
Thanked: 727 Times
The water pump is working fine. Just flush the radiator with a high pressure water jet. Open the coolant return pipe below before doing that. Use a pure coolant with distilled water.
SirAlec is offline
Old 17th January 2011, 19:25   #12
Thanked: 52 Times
@ sir alec & narendra
As you both suggested, mechanic also said the same, but instead he is using WURTH coolant flush, for 30 minutes with removing thermostat, and then drain the water, after he needs to flush with pressurised water from top, He is right on his vision i think so.
He was against cleaning radiator by radiator service shops, since they will remove aluminium locks and after cleaning they again lock it by bending the aluminium again, but he said it will sometime create problem if the person did not do it properly. so i agreed to him. he will flush it tomorrow. will update the result.
Old 17th January 2011, 20:21   #13
nitrous's Avatar
Thanked: 332 Times
Looks like the radiator has had too much water rather than coolant.
Not good.
nitrous is offline
Old 21st January 2011, 21:37   #14
Thanked: 52 Times
Problem is solved i think.
Before:
the temperature gauge will stand just an mm below the half mark in my car, (50%)
After service:
It just stands 1/4th of the gauge not nearing half mark. (25%)
The problem is , radiator got clogged , only half of the radiator was circulating coolant, so mechanic asked to service the radiator, done it. and flushed with Bardahl, to clear engine blocks. So i see improvement in temperature gauge.
I have also done other things as preventive and maintenance measure.
Timing belt change (Gates brand Rs.975)
Alternator belt (Fenner Rs.275)
a/c belt (Fenner Rs.275)
radiator flush (Bardahl Rs.425)
steering boot (Rs.99 one side)
cam oil seal (Rs.126 )
Coolant 2 litre (AC Delco Rs.125/litre)
suspension rubber (Rs.300 two side)
With this i got labour charge of Rs.3000. for all fitting , removing, flushing, etc. (labour includes Radiator service of Rs.1100)
