View Poll Results: Do you feel that a car feels more responsive while driving at night?
Yes, the car definitely feels quicker at night 34 85.00%
No dude, you are imagining things. 6 15.00%
Voters: 40. You may not vote on this poll
Old 8th January 2016, 08:40   #121
tharian's Avatar
Thanked: 8,626 Times
re: Ah, winter time. Engines are feeling better due to cooler air!
Since December weather is more prominent in January in Bangalore this time around, it is a good feeling driving the car in the mornings .
It has been around 14-15 Celsius during early mornings and my car just about reaches the usual coolant temperature just when I am reaching office which is 7 kms away.
The intake temperature does not go over 25c in the same duration.
Eager to rev and smooth while doing so.
tharian is offline
Old 8th January 2016, 09:22   #122
bluevolt's Avatar
Thanked: 3,477 Times
Though engines are feeling better, I have observed significant drop in mileage since I use my car only upto 3 kms to park at nearest metro station and then back to home in the evening. Because the engine is not able to warm up properly, the fuel consumption is bit on higher side.
bluevolt is offline
Old 3rd October 2017, 20:55   #123
SmartCat's Avatar
Thanked: 51,767 Times
Night Driving = Colder Air = More Power?
Has anybody noticed that the car seems to be a bit more responsive while driving on highways at night? Especially if it is a 2 + 2 highway, with moderate traffic that forces you to weave between lanes?
Ah, winter time. Engines are feeling better due to cooler air!-picture-020.jpg
In most cities, the temperature difference between highs and lows is atleast 10 degrees centigrade.
So when we are driving at night, much colder air is entering the engine. So logically, it should increase the power of engine by 5 to 10% - not too different from how cold air intake works.
Ah, winter time. Engines are feeling better due to cooler air!-4368_spectre_cold_air_intake_2006_ford_mustang.jpg
Is it just my imagination or does anybody else actually 'feel' the power difference while driving at night?
SmartCat is online now   (6) Thanks
Old 3rd October 2017, 21:07   #124
R2D2's Avatar
Thanked: 5,849 Times
Re: Night Driving = Colder Air = More Power?
In theory you are right, but I really haven't seen any noticeable difference in day/night of the same season. But the difference between seasonal for e.g. winter and summer performance is noticeable. Also, the AC works better alright.
R2D2 is offline   (2) Thanks
Old 3rd October 2017, 21:14   #125
mayankk's Avatar
Thanked: 8,613 Times
Not sure about nights, but winters, aye.
In theory you are right, but I really havenxt seen any noticeable difference in day/night of the same season. But the difference between seasonal for e.g. winter and summer performance is noticeable. Also, the AC works better alright.
My fiesta used to feel smoother somehow, especially on foggy days. Also, in one consistent-speed run on the moradabad road in winter, the temperature went down to half the regular level while doing those speeds, so the air definitely was cooler. I never felt the engine purr like that day ever again.
mayankk is online now   (3) Thanks
Old 3rd October 2017, 21:18   #126
sada's Avatar
I have definitely noticed the improved pickup in my Alto (800 cc) when the air is cool outside, like early mornings and late evenings. Perhaps it may not be more noticeable in a more powerful car.
sada is offline   (1) Thanks
Old 3rd October 2017, 21:37   #127
Rajeevraj's Avatar
Thanked: 19,120 Times
Yes, there is definitely a difference. I am typically an early starter and start in the 4-5am time-frame from Bangalore- when it is typically quite cool. That initial drive before sunrise 'feels' good and mileage is also higher. Also mentioned by GTO in this thread related to night driving
Advantages of Driving @ Night:
• You’ll usually achieve a higher average speed, despite maintaining a lower top speed. Primary reason = Lesser traffic.
• Lower probability of bullock carts, three wheelers, cyclists & animals on the Highway.
Cooler air = Better engine! The density of cool air is higher than hot air. Thus, you end up with a superior burn, resulting in better performance. The engine feels noticeably crisper at night.
• Higher fuel efficiency due to lesser traffic & cooler air.
• You can see a vehicle coming around a blind corner due to its headlamps (assuming the vehicle has its headlamps running).
• This is down to personal tastes, but I find night driving very enjoyable. The pleasure of empty roads, cooler weather, crisper engine, feeling one with the car and some nice music playing is unmatched. However, safety comes first and it's best to limit night driving to as little as possible.
Rajeevraj is offline   (1) Thanks
Old 3rd October 2017, 21:42   #128
Thanked: 327 Times
Attachment 1681955
From an engineering perspective a car ought to run better at night for two reasons
1) Lower temperature-
At night temperature usually drops by about 10-15 degrees on average. This means that air density would increase by about 3-5 percent. We all know that engines like denser air for combustion.
2) lower humidity-
Since night air is cooler, it is also less humid holding lesser water vapor. water vapor has adverse effect on performance.
All this will have an impact but I am not quite sure how they affect actual performance figures. One of the reasons you "feel the power" is that the roads are usually empty in the night
bullrun87 is offline   (1) Thanks
Old 3rd October 2017, 21:42   #129
Hayek's Avatar
Thanked: 16,950 Times
Cars certainly are more responsive at night - but that's because the AC load on the engine is less, not due to lower air temperature. Car ACs need to deal with cooling a hot greenhouse - and face far higher loads when the sun is out (much more than the difference in reported temperatures that are measured in the shade). Hence cars feel more responsive at night even in cities like Bombay with negligible difference in day and night temperatures in the shade.
Hayek is offline   (3) Thanks
Old 3rd October 2017, 22:27   #130
Thanked: 72,141 Times
Lower ambient temperature = better output horse power.
I do not know the figures for the ICE but a gas turbine - of the sort that powers aircrafts and warships the difference at sea level between 35 degrees and 15 degrees centigrade ambient is 25%. That is to say power output drops by 25% between 15 to 35 degrees ambient or increases by 33% as you move from 35 degrees to 15.
V.Narayan is offline   (4) Thanks
Old 3rd October 2017, 22:33   #131
Dr.Naren's Avatar
Thanked: 17,276 Times
There is very good difference in my S-Cross 1.6 when outside temperature is cooler. Engine feels smoother and more free revving. I love driving the car early morning or at night
Dr.Naren is offline   (1) Thanks
Old 3rd October 2017, 22:40   #132
Nikhilb2008's Avatar
Thanked: 10,177 Times
Absolutely right. The difference is more on turbo charged cars. On my stock Civic, I didnt feel much difference, but with the turbo, it was a world of difference.
Reason: A Naturally aspirated engine sucks in air from the atmosphere and pushes it into the engine for combustion. The temperature doesnt change much in the journey between intake and cylinder.
In a turbo charged car, the air heats up massively when it is compressed by the turbo. This is why we have an intercooler. The intercooler though, can never bring hot air down to ambient air temperatures. So, the air reaching the cylinder is always hotter than the outside air in most situations. This is why in a turbocharged car, there is a reasonable amount of difference.
Nikhilb2008 is offline   (4) Thanks
Old 3rd October 2017, 23:21   #133
airbus's Avatar
Thanked: 3,496 Times
Couple of days back I was talking to a friend who completed Bengaluru - Guwahati - Bengaluru drive in mid 2016. He mentioned about better engine performance at night, so he took majority of his drives during night with extra lighting and reflectors. Another point we discussed about tyre heating under intense sun or high temperature. It appears, cooler temperature at night may reduce likelihood of tyre burst situation.
airbus is offline   (1) Thanks
Old 3rd October 2017, 23:34   #134
tsk1979's Avatar
Thanked: 23,484 Times
Re: Ah, winter time. Engines are feeling better due to cooler air!
Feels are very very good. But actual data and scientific research is even better.
Here you go, a detailed scientific paper researching and providing a mathematical formula for Atmospheric conditions vs Engine performance
http://www.scielo.br/pdf/jbsms/v25n3/a10v25n3.pdf
The atmospheric pressure was observed to be a more relevant
parameter to influence the engine performance than the air
temperature. Road tests confirmed that the acceleration time is
increased with increasing air temperature and decreasing
This is a simplified conclusion. The paper has mutiple graphs on how engines compensate for temperature and pressure.
tsk1979 is offline   (2) Thanks
Old 15th January 2020, 10:25   #135
bluevolt's Avatar
My Baleno's average (as per MID) increased by 2-3 KMPL in winters. Currently, it is 25.2 KMPL.
Even tankful method calculation results in - 22+
bluevolt is offline
