Old 21st November 2010, 09:27   #1
akshay4587's Avatar
Thanked: 4,553 Times
Smoke from Car's Exhaust-Why?
I got End Can(Muffler)of my Accent replaced Last weekend.
My car is usually driven with a Light foot(2-2.7KRPM) 95% of the times,and driven only by me,and not to mention,it has always been pampered with Mobil 1 fully synthetic.
Yesterday early morning,while coming back from chandigarh,i found a nice open stretch,so for a change,i stretched her legs in overdrive.
Suddenly i got a call,and i pulled over to the road side,i let the car idle,and came out for a breath of fresh air and attend the call.
I suddenly sensed burning smell,i was standing near the front left wheel,and i got a mild heart attack,from what i saw,there was smoke all over(infact near the front wheel too).
Immediately i ran and shutdown the engine,and fearing worst,i popped the hood,thankfully everything was like as it should have been,no oil\coolant anywhere,and even the coolant can was full.
I started her,and it came to life normally,then i noticed smoke is coming from the exhaust,i was so heartbroken.:(.
I revved her,and more smoke,and lots of it in blue color,with extreme burning odour.
Checked coolant and engine oil again,and found it to be normal.
slowly i left that place,and 10Kms later i was back home.
I checked it again,but there were no signs of smoke????
i revved it again,and no smoke,all i had was water and water vapours from exhaust.?
Why did it happen?
1)New Exhaust muffler?
2)I had got oil changed sometime back,and i had 100ml of extra mobil1 lying around,and the mech,had added that too to the oil,can it be due to extra 100-200ml oil in the sump???
akshay4587 is offline
Old 21st November 2010, 10:56   #2
manikjeet's Avatar
Thanked: 295 Times
are you sure it was blue smoke. usually blue smoke comes when the engine consumes oil.
it could be the extra mobil1.
and the new muffler will sound empty but never give out blue smoke
do a simple test
start the engine and put your hand on exhaust so as to cover it completely then let it go
see the colour of smoke and hear for a pop sound
now go to the engine bay take out the dip stick and put your finger over it. remove your tum and see for oil traces on it
it no blue smoke comes and no oil on the finger the engine is fine
ps during the exhaust thing white smoke is good sign
manikjeet is offline
Old 21st November 2010, 13:08   #3
akshay4587's Avatar
Manik,i already checked,by covering the exhaust with hand,and then revving it.
There is no smoke,i only get traces of water on hand.
Also,searched around on internet,and asked my mechanic.
The new muffler comes coated with some material to prevent rusting while storage,the smoke comes due to its burning,i just wish its that only.
Old 21st November 2010, 13:35   #4
Thanked: 2,835 Times
Yes that is the only reason. New parts come with a coating as well as plastic wrap. At times while fitting, small pieces of plastic remain inside. When the exhaust is hot enough the plastic ignites.
Aroy is offline
Old 21st November 2010, 15:00   #5
manikjeet's Avatar
Thanked: 295 Times
yes bro i also hope the same
I suggest to let the exhaust fill up and then see
Old 21st November 2010, 15:23   #6
v&v
v&v's Avatar
Thanked: 1,207 Times
@akshay4587 - Since you said blue smoke, it is always advisable to double check.
Get a compression test done, but before that once again drive hard at higher RPM. Check for oil burning smell again/smoke.
it will clear all doubts.
v&v is offline
Old 21st November 2010, 16:13   #7
abhibh's Avatar
Thanked: 39 Times
Early morning ? how early
I doubt there is anything wrong with the car. Can be due to extra oil or fuel.
Similar thing happened in Skoda and you know how such things gives heart attack in Skoda's. Early morning white smoke on pushing hard went back to normal by 10AM. Never happened again.
Check now if you still see blue smoke ?
abhibh is offline
Old 22nd November 2010, 11:16   #8
Thanked: 309,173 Times
I've always noticed a li'l smoke for the first 300 - 400 kms after getting a new exhaust. Been told it's due to the oil & coatings inside the pipes + muffler. I wouldn't worry about it if I were you. Just drive around for a couple of days and come back to update us.
GTO is offline
Old 23rd November 2010, 04:53   #9
Hi ,
It could be due to driving at high speed , as its normal for cars to consume & burn a bit of oil at high speeds ,
also the extra 100ml oil at high speeds could burn out - if you dont see it again , its the extra oil which you put in.
kindly update your Kms on car & year.
passion4cars is offline
Old 23rd November 2010, 23:02   #10
Thanked: 727 Times
Originally Posted by passion4cars View Post
Hi ,
Only you have worn piston ring.
BTW he is using synthetic remember, it made for such high rpms/speeds
SirAlec is offline
