Old 11th November 2010, 18:16   #1
Thanked: 54 Times
My W124 won't Idle
I have a '96 model Merc 124- E220 which is in very good condition. Recently, the without any provocation, the car stopped idling. Acceleration is good and the car starts without any problem with the accelerator depressed. But the moment you lift the leg off the acclerator the engine stops. Any suggestion on this problem.
king-off-road is offline
Old 11th November 2010, 19:06   #2
Jaggu's Avatar
Thanked: 17,295 Times
EDIT: have you taken it to the garage and checked the sensors etc?
Jaggu is offline
Old 11th November 2010, 19:58   #3
Thanked: 20,586 Times
I think you need to get the air and fuel filters checked/replaced. If it still persists, the engine is in for a thorough check.
libranof1987 is offline
Old 11th November 2010, 21:19   #4
Mpower's Avatar
Thanked: 1,735 Times
Like I just told someone else...check, clean and/or replace the ICV.
Mpower is offline
Old 15th November 2010, 10:46   #5
Thanked: 54 Times
I'm not in a position to take it to a competent garage as there's none within a hundred KM radius. The car was recently serviced and filters and plugs renewed. Does ICV stand for Idle Control Valve ? Where is this ICV located in the engine bay. Maybe I can inspect the same. At the moment I've adjusted the idling speed with the throttle control lever. This is not the solution as the engine tends to raise when the aircon cuts out.
Old 9th December 2010, 00:21   #6
Thanked: 48 Times
Re: My W124 won't Idle
Hi
I live in Chennai and I also own a W124 E220 for the last 11 months. If you want I can provide the details of a good garage which I visit. PM me and I shall provide you the details.
vasanthjn is offline
Old 4th September 2019, 11:09   #7
stormsearcher's Avatar
Thanked: 13 Times
Did you manage to fix this problem? Yeah i know its an old post etc., but am chcking up on this issue as my car has run into something similar now.
stormsearcher is offline
