Old 12th August 2011, 19:34   #61
bejoy's Avatar
Thanked: 1,503 Times
Re: Reliable Fiat ECU scanner
Originally Posted by jethari View Post
Hi All
Connected the three pin cable to the bluetooth ELM tool to my fiat siena weekend and using scan-master tried to read the ECU. It connects to the ECU (says ECU connected......), but does not read any parameters. For eg. coolant temp shows -40, engine rpm shows 0. Is it because it is a demo version or does it not support my car?
Hari
Are you using the software on the PC? Try FiatECUScan (FES) that can be downloaded freely from the web. I have not used it with ELM, but the homepage says that is supports it. FES supports most of the Fiat ECUs that uses non-standard OBD protocol.
bejoy is offline
Old 12th August 2011, 19:50   #62
jethari's Avatar
Thanked: 18 Times
I tried Fiat ECU scan as well. It is also not able to connect to the ECU. I selected Palio 1.6 16V from the list of cars as siena is not listed there.
Hari
jethari is offline
Old 12th August 2011, 20:06   #63
bejoy's Avatar
Hari
THe list in FES may not map to the actual ECU model. Check the exact ECU model under the hood. Is it MM or Bosch? Please post the picture of the ECU if possible.
bejoy is offline
Old 12th August 2011, 20:26   #64
jethari's Avatar
Thanked: 18 Times
OK, will do in the morning tomorrow.
Hari
jethari is offline
Old 13th August 2011, 10:23   #65
jethari's Avatar
Thanked: 18 Times
The ECU is MM !AW 49F. I remember trying that option as well. Will try again today. Will keep you posted.
Hari
jethari is offline
