Old 23rd February 2010, 15:01   #1
Thanked: 25 Times
Swift Diesel: Engine oil indication remains on till 3200 rpm
hi
i put this engine oil castrol 5w40 in my suzuki
diesel swift
after this engine oil lamp keep on
when i race the car to 3200 rmp engine oil light goes
off some people tell this oil is not for deisel engine
is this true any solution to remove engine oil check light
regards
narry
narry is offline
Old 23rd February 2010, 17:03   #2
Thanked: 249 Times
I think you got a serious problem that the oil pressure is not enough. Either the oil is not suitable or you got a oil pump issue. Try changing the oil to the recommended oil.
Ravindra M is online now
Old 23rd February 2010, 20:40   #3
R2D2's Avatar
Thanked: 5,849 Times
Originally Posted by narry View Post
hi
diesel swift
regards
narry
It could be due to oil viscosity. What brand of oil have you used? 5w-40 is generally synthetic and should be ok for a diesel. Add only recommended grades and do not experiment with oils.
If the oil light stays on till 3200 RPM which is near the high end of the RPM range for a diesel you run the chance of severe engine damage. DO NOT drive the car till it is checked thoroughly.
Causes in decreasing order of probability:
a) Oil pressure sensor fault or a electrical wiring fault in the dashboard
b) Oil viscosity
c) Oil pump (this is serious)
Rgds,
R2D2 is offline
Old 23rd February 2010, 23:15   #4
Jaggu's Avatar
Thanked: 17,265 Times
As mentioned above it can be a problem with the sensor or the pump, get it checked ASAP. Stick to diesel engine oils, these engines are very sensitive and wrong oil can deliver big repair bills.
Jaggu is offline
Old 23rd February 2010, 23:33   #5
rocky080's Avatar
Thanked: 39 Times
hi nurry did you get your car serviced(washed) when you put in this new oil. If so it just might be that the oil pressure sensor might have got messed up because of the washing. The same thing happened to me last week when i got my Xylo serviced. Mahindra changed the oil pressure sensor free of cost.
rocky
rocky080 is offline
Old 24th February 2010, 00:36   #6
humyum's Avatar
Thanked: 5,843 Times
Whatever the reason, dont keep driving the car. Might be a sensor fault or a Fuel Pump fault. I dont think Engine oil viscosity is the issue here at at all.
Get it checked asap.
humyum is offline
Old 24th February 2010, 11:27   #7
Thanked: 25 Times
thanks all
hi
we solved the problems a rat had eaten wire for engine oil switch spent 3 hours to find it finally the problems is solved
thanks once again for all u help
regards
narry
narry is offline
Old 24th February 2010, 18:16   #8
Jaggu's Avatar
Glad to hear this, but do give the thought of a proper diesel engine oil for your car also.
Jaggu is offline
Old 24th February 2010, 21:09   #9
vigsom's Avatar
Thanked: 29,823 Times
hi
regards
narry
so you'd now need to figure out which oil to use to keep rats away
vigsom is offline
