Old 20th January 2010, 00:59   #16
monster2's Avatar
Thanked: 12 Times
HI Buddy,
I would love to help you out with this as I faced the same and thanks to RK well known for Opel in Hyderabad who helped me out, First of all this usually happens if the head gasket is worn out, next just check with Coolant sensor, which is below the IG Coil, one more this in Corsa there both the fans work that is the A/c as well as Radiator together, as your Mech to connect it directly to the battery and check if it runs at suffient speed, as even if you have no coolant and just water if the fan runs fine then still the temp is maintained, however Kindly make a not Corsa Temp needle reaching close to 100 is queit normal however should be below.
monster2 is offline
