Old 12th December 2009, 00:06   #16
danlalan's Avatar
Thanked: 281 Times
Electrical faults are some of the main reasons for cars catching fire. But how does a car erupt into flames because of that is suprising and how it gets gutted in minutes is even more suprising.
Here are pics of my bro's E that got gutted in flames from an electrical fire near Kharghar. The Back of the car remains intact. Thats where the fuel tank is. Mercedes Benz were asked for an explination but since its been serviced outside and not through a MB service station they couldnt be blamed.
Yea everyone just got out just in time. The good that came out from that is.. A Spanking New E in replacement. Well not free ofcourse. Got a 7 lack disc on the e280
danlalan is offline
Old 12th December 2009, 00:45   #17
Though one keeps their car well serviced and maintain in shape, i feel they need to take extra care in parking their cars and keep away from rats which might mess up with wirings and fuel pipes and lead to unexpected circumstances.
challa is offline
Old 12th December 2009, 05:52   #18
sudharma's Avatar
Also another culprit is the electrical add-ons such as Horns, Alarms, Lights ICE etc. The way the Auto Electricians connect these is much to be desired. Wires joined by twisting them And using Insulation Tapes. And 100s of suspect quality of tapes are in the market which just peels off in the hot and oily atmosphere. I have never seen these guys using any proper crimp connectors and sockets.
The wiring for the ICE are mostly routed along the floor of the vehicle or through the body channels and rubbing of these wires with the metal body parts cannot be ruled out. Also in the engine compartment where the temperature is high, the cable insulation tends to become brittle and crack in due course. There are too many rubber hoses in the engine bay of the modern cars, any short circuit and resultant fire have lots of fuel here ( Petrol, rubber, plastics etc). I don't think most of the Manufacturer is using fire retardent wiring in the cars. Also wrongly rated fuses or absence of them can be a factor in a fire mishap.
If you are having an Electrical / Electronic fuel pump and your fuel line in the Engine compartment ruptures, Petrol will be comtinuously pumped into the the Engine bay till the power is switched off or battery disconnected. On a vehicle with the mechanical fuel pump, as soon as the fuel line ruptures the engine stops and the fuel is cut-off. ( Even though the damage is already done).
Driving long hours continuously won't be a problem as long as there is no fuel leak and or electrical short circuit in the engine compartment.
sudharma is offline
Old 14th December 2009, 09:56   #19
ssengo's Avatar
Thanked: 37 Times
I did this drive with my family in my 4 month old M800. I was driving at the speed of 80-90 km/hr and the fuel capacity is 28 litres (filled up to the brim). As i did night driving, i was not in an intention to stop anywhere in the middle as it was raining outside and unsafe to take a break in a remote place.
But throughout my continuous drive, i was bit upset that i'm not giving a break for my new car and worried if some components would worn out due to this. But luckily nothing happened.
In my 4 month old M800, i have so far done only one change/upgrade. I have replaced my stock headlamps to 100/90 Halonix bulbs with relay and kit done from MASS. Apart from this, i have not done any upgrades to my electrical system. Hope this upgrade will not do any damages to electrical system.
Last edited by Jaggu : 14th December 2009 at 10:37. Reason: Back to back posts, please wait for moderator approval to edit the original post.
ssengo is offline
Old 14th December 2009, 11:31   #20
Thanked: 2,142 Times
Well, since you are saying the car was only 4 months old, it may not have completed its running-in period by then. So the only precautions you should be taking are not to high-revv the engine and no sudden accelerations. Shift into higher gears as early as possible, shift into lower gears as late as possible and always try to accelerate gradually/gently. If the initial running in period has not been completed, try to stay within 80kmph. If you cross this you may be high-revving the engine.
Rest assured, running your vehicle for 4-5 hours does not produce any fire. Of course if you are riding with your family, it may produce some sparks from the backseat
honeybee is offline
Old 14th December 2009, 12:04   #21
I am running 100/90 with relay on my vehicle too. I have heard that 130/100 burns the headlight assembly. However, i wonder if the burning is enough to cause a fire in the car. Can anybody throw a light on this? My car also has LPG fitted in it.
harsha.cs1 is offline
Old 14th December 2009, 12:23   #22
arnabchak's Avatar
Thanked: 1,165 Times
I would say that the most susceptible areas would be a short circuit in the electricals system near the fuel lines.
Another reason may be the LPG cylinders installed from local vendors usings sub standard pipe lines. The lines tend to heat up resulting in the sad event.
arnabchak is offline
Old 14th December 2009, 14:42   #23
ssengo's Avatar
Thanked: 37 Times
I was strictly adviced by MASS experts not to upgrade to 100/130 for a M800 as it might blow up electrical systems. I mostly do night driving ( covered 6000 kms/4 months) and had to upgrade bulbs to atleast 100/90 and i'm quite satisfied with it. BTW, do you own a M800?
ssengo is offline
Old 15th December 2009, 09:25   #24
sudharma's Avatar
M800 and high Wattage Headlight Bulbs.
Some time back My M800 Head lights were upgraded to 130/100 with additional relay and wiring. But after some time the Head light sockets burnt out. I reverted back to 100/90 bulbs and all seems to be ok.
Not only the Sockets and wiring cannot handle the power but also its a heavy load on the Engine ( noticed sudden drop of speed when headl light are switched on) and the battery hardly charges during the night drives and morning starts were difficult.
My advice is not to go for Higher Wattage bulbs on M800. The stock vehicle is designed for optimum performance. Any additional load deteriorated the performance.
sudharma is offline
Old 15th December 2009, 09:26   #25
sudharma's Avatar
You have to be double careful since you use LPG Fuel.
sudharma is offline
Old 15th December 2009, 15:21   #26
SSengo, i own a hyundai accent. I too run 100/90s but i would love to have 130/100 considering i do many highway runs. However, i fear an electrical failure, hence i am refraining from upgrading to 130/100. although i have come across persons on this forum comfortably running 130/100 on their santros, i am holding back only because mine is an lpg fitted car and i have to be a little more careful.
Thanks Sudharma, i am being doubly careful at present. however, i am wondering if i can safely employ 130/100, why not. so i was asking if electrical fire of burnt headlight assembly would be wires and holders turning black or could it actually break into flames?
Old 15th December 2009, 16:44   #27
sudharma's Avatar
Due to overloading the contacts in the connector will start becoming loose and this creates sparking, the metal will melt , any flameable material in contact with this will start burning unless they are made of fire retardant material. Other material such as bakelite etc will char. Since the wires are connected to the connectors, they catch fire, also if the wiring is spliced and insulation tape ( cheap quality ) will also burn. I don't think fire retardant wires are used in the cares. This is a chain reaction. Once the fire or combustion triangle is complete it there will be fire.
The bigger the vehicle, the bigger the electrical load. So the wires used will be of heavier gauge. Similarly the Maruthi 800s power demand will be lower and hence lower thickness wires.
Once in my Tata Sierra the horn relay contacts fused ( Relay contacts could not handle the Twin horn load) I immediately open the Bonnet and tried to lull the horn wire. I got my fingers burned as the wires have become red hot and the insulation has melted away.
sudharma is offline
Old 15th December 2009, 17:32   #28
ssengo's Avatar
Thanked: 37 Times
Harsha, I hope HY Accent is capable of handling 130/100 relays and wiring. But as you say, you have fitted a LPG, extreme caution to be taken. Please check with HY expert to see if your car can be upgraded to 130/100 with LPG. Good luck.
ssengo is offline
Old 15th December 2009, 18:26   #29
Thanks Satish and Ssengo,
The Hyundai auto electrician told me no major issues in trying 130/100 but it might darken the headlight assembly. But still why take a chance types. I guess i will stick on with 100/90 as i am happy with it for now. and the car being 9 years old, i am sure it is out of its youth and wont be too happy with these experiments.
off topic, Satish, i saw your work with your motorbikes and your interest in them. I am really impressed!
Old 15th December 2009, 18:43   #30
Thanked: 81 Times
OT: Have your car checked. The additional load from 130W lamps should not be causing any problems - its only an extra 60 Watts compared to your present set of lamps.
I have done numerous all night drives running 100/90's lamps and a decent ICE setup for 6+ years on my M800 without any problems.
CrackedHead is offline
