I wasn't there when this happened. Sunday, 8th Nov 2009. As heard from my father:
Driving at 100 kmph towards Thane at 7pm on the Eastern Express Highway, my dad heard a 'tung' sound from the rear left wheel of the E280 CDI Elegance. That started it all. Vibration came into existence. A noise (similar to one caused by friction between wheel and brake) could be heard from the R/L wheel in D mode of the tranny. He immediately pulled to the side of the road. However, when shifted into R, a loud 'tung' could be heard but, surprisingly, the car ran very smoothly in reverse. The wheel was as good as new. Shifting into D again, a relatively softer 'thug' could be heard and the vibration and noise came back. Sitting in the car you could only guess that the brakes on the R/L wheel had jammed causing the friction during the running of the wheel. Since the disc seemed ok, my dad guessed that the 'liners' used for the parking brake (commonly called handbrake but for the Mercs, it's the left foot brake) were causing the problem. He feared he may driven the car with the handbrake engaged without realizing and hence the problem arose. He called me immediately. I conferenced the call to the Mercedes Benz 24 hr helpline.
Having described the situation to the technician, he said he could not figure out what the problem could be. He was willing to send the van to where my dad was but that would mean waiting for one hour. My dad seemed unwilling and so he brought the car back home to Chembur/Ghatkopar at speeds below 20 kmph.
We put the car back in my house and called up the Helpline again asking him to send help the next day. I stayed in touch with AutoHangar on phone through Monday and 'help' arrived in the form of a Bolero (Mercedes Benz 24 hr Helpline vehicle) on Tuesday (10th Nov 2009 at 8.30 pm). First, i explained everything to the technician and then did a little TD for him but he just shrugged and said that there was nothing wrong. The driver who accompanied him then drove the car forward and reverse in my stilt which is about 40 ft long. This time i asked the technician to lay on the floor next to the car and look for any abnormal sign near the R/L wheel or underneath the car while the driver did the D and R in the stilt. The technician gasped at what he saw, quickly got up, went and whispered to the driver "Aila! Iska to differential khulke latak raha hai!"
He then explained to me what the problem was, went to the Bolero and got a hydraulic jack. By this time my dad had come home. Shockingly X (the technician) did not know how to use the hydraulic jack so my dad helped him understand the working of the jack. He then lifted the car and went underneath to check the differential. As soon as he touched the differential, a bolt fell to the floor. He then got a tool to fix it back. After trying for 15 mins, he still couldn't fix the bolt back. Then my dad asked if he could see the bolt. My dad was shocked at what he saw. The bolt had broken off!
I have attached some pictures to help give an idea of the broken bolt.
I went underneath the car and looked at the differential. I told the technician that the other part of the bolt was still in the differential.
I have attached a little layman's drawing to help understand the cause of the shearing of the bolt.
The technician then said that he'll have to take the car away. Since there is unexpected torrential rainfall in Mumbai currently, AutoHangar will be sending a flat bed tow truck tomorrow (Thursday 12th Nov 09) to take the car away.
Details-
Car: Mercedes Benz E280 CDI Elegance
Purchase: Feb 2007
Warranty: out of warranty
Mileage: approx. 18000 kms
I have a few questions:
1) This is definitely not a driver's fault but a manufacturing defect which could have led to a fatal accident. This was agreed by the technician. Can i claim warranty from the company citing manufacturing defect?
2) Will Mercedes Benz do this for me out of something called 'goodwill warranty' since they don't have extended warranty on the E.
3) I fail to understand how this can happen to a car like the E! It's supposed to be a VERY safe car. I guess it's sheer bad luck and some bad workmanship on my car (as explained in the drawing).
4) What steps do BHPians suggest i should take?
5) What is the kind of amount i can expect to be charged for this?
TIA!
Order of pictures:
1-4 : the technician getting ready to work
5-6 : the differential cup underneath the vehicle (you can see the broken bolt still stuck inside)
7-9 : the part of bolt that fell off
10 : explanation of a probable reason
