Old 12th August 2009, 16:07   #1
Drive by Wire Technology
Have been hearing about this phrase for a long time now. Basically it replaces mechanical systems by electronic systems for wider applications in a vehicle. Like a hydraulic clutch/brake assist (power brake/power clutch) replaced by an electro-mechanical actuator.
I saw this practically being used in one of the latest KSRTC buses - Volvo 9400's. I happened to look at the footwell of the bus, having accelerator/clutch/brake assembly. There were no mechanical linkages to any of the pedals, but just some kind of sensors mounted on the lower part.
I suppose that some of the cars also use this technology, but dont know the extent to which it is being used (given that it adds costs).
Which cars sold in India and to what extent is this technology being used here?
ajaysurfs is offline
Old 12th August 2009, 16:15   #2
gpa
gpa's Avatar
Thanked: 345 Times
Drive-by-wire technology is in a very nascent stage here in India. Will take a while before it evolves and becomes common.
Word has it that MUL will be introducing this technology on one of their new upcoming models with the new Euro 4 all aluminium 16v DOHC KB series engine.
gpa is online now
Old 12th August 2009, 16:45   #3
R_R
Thanked: 294 Times
The Grand Vitara has drive-by-wire technology, but am not sure if its for all controls or just accelerator.
R_R is offline
Old 12th August 2009, 17:04   #4
jav
Thanked: 66 Times
Most of the new cars available now have drive by wire for accelerator
jav is online now
Old 12th August 2009, 17:06   #5
im_srini's Avatar
Thanked: 491 Times
The Swift diesel comes with an electronic throttle, by extension, cars from other stables that use the multi-jet-diesel engine should come with electronic throttles too. The M16A engine, i.e. SX4, is also controlled by an electronic throttle.
im_srini is offline
Old 12th August 2009, 17:27   #6
ImmortalZ's Avatar
Thanked: 601 Times
All Hondas currently for sale except the ANHC have DBW throttles. I remember a generation of Mercs were extremely criticized for their DBW braking systems which failed often. I think there is some sort of law now in the EU saying that certain systems on a car MUST have mechanical links.
ImmortalZ is offline
Old 12th August 2009, 18:13   #7
hellstar's Avatar
Thanked: 44 Times
Verna CRDis are Drive by wire so does Getz CRDi , I20, Swift DDSi :-)
hellstar is offline
Old 12th August 2009, 18:24   #8
KSM-Vtec's Avatar
Thanked: 447 Times
Well it gets only more and more unreliable & complicated to maintain this way....but i guess thats not a good enough excuse to avoid change and upgrade.
KSM-Vtec is offline
Old 12th August 2009, 18:26   #9
ImmortalZ's Avatar
Thanked: 601 Times
The excuse is emissions, like every other change that is going on.
Old 12th August 2009, 19:02   #10
chaxy's Avatar
Thanked: 18 Times
the safari's too has it for the accelerator. In UV's Scorpio and Innvova too have this.
chaxy is offline
Old 12th August 2009, 22:32   #11
Thanked: 350 Times
The palio also has DBW since its launch in india if i recall correctly which makes it the earliest in India .Also with DBW the ECU is able to get better/faster readings from the potentiometer vs the older mechanical linkage system.
Trust_In_Thrust is offline   (1) Thanks
Old 13th August 2009, 01:48   #12
profold's Avatar
Thanks for starting this thread
Thanks ajaysurfs for starting this thread. I had been looking forward to it.
Just jotting down some random thoughts.
Thus spake wikipedia:
"Drive-by-wire, DbW, by-wire, or x-by-wire technology in the automotive industry replaces the traditional mechanical and hydraulic control systems with electronic control systems using electro-mechannical actuators and human-machine interfaces such as pedal and steering feel emulators."
Is the rubber-bulb honker, standard in pre-war cars which got replaced almost overnight without a whimper by electric horns, the first X-by wire victim :-)? Or the honour of the the first X-by wire should go to the "self" starter, replacing the sturdy and macho crank?
Jokes aside, electronic throttle which does away with direct mechanical linkage from the accelerator pedal is a commonplace. It seems to jell well with the ECU.
If we permit substitution of "replaces" by "partially replaces" in the above wikipedia definition, bits and pieces of x-by-wire is available in many modern cars, even in India . We have central locking, power windows (trivial), power steering, ABS (Brake-by-wire assist), electronic stability control.
In the automotive sector, the motivation for X-by-wire appears to be flexibility in positioning the controls and better performance.
In the downside, electrical systems, unlike mechanical and hydraulic systems do not degrade gracefully and have a tendency to fail without warning.
A complete X-by-wire can create a very unsafe situation. Safety issues may be minor in electronic throttle as one can kill the ignition if misbehavior is suspected. But consider a full steer-by-wire. If it conks out in a highway, the lives of occupants of the concerned and other cars are in jeopardy.
Cost of course is another but less grave downside.
We would like to know (i) the experience of using and maintaining the various X-by-wire components in Indian cars (ii) evolution of X-by-wire application in our home-grown auto industry (iii) world-wide laws, regulations and practices which allows or disallows complete (no mechanical backup) X-by-wire features.
Senior and knowledgeable TBHPians please contribute and keep this thread alive.
P.S.
A bit of history, possibly known by many. The term "by-wire" appears to be used first in aeroplane context as "fly-by-wire" where the mechanical or hydraulic connection between pilot joystick and the controlled surfaces were replaced by electrical connection from stick position sensors. Airbus A320 has it. our very own LCA/Tejas has it. Fly-by-wire allows reduction of weight (hence endurance with same amount of fuel) and better handling qualities. To ensure safety ALL sensor and Electronics are copied 4-times, in a fail-safe configuration so that up to two failures can be safely tolerated. We cannot possibly afford the 4-fold cost in a down-to-earth automobile.
Apologies for the longish post.
profold is offline
Old 13th August 2009, 10:09   #13
neoonwheels's Avatar
Thanked: 1,882 Times
Yes, I remember reading about Petra in the broacher that the car is equipped with drive by wire. Not sure about Palio though.
neoonwheels is offline   (1) Thanks
Old 13th August 2009, 11:33   #14
esteem_lover's Avatar
Thanked: 513 Times
I have literally rode my Yezdi by wire many times when the accelerator cable gets cut. Have to hold the wire & pull to accelerate and push to decelerate.
esteem_lover is offline
Old 13th August 2009, 12:09   #15
Thanks Profold.
Imagine an automobile being driven by a joystick, if the DBW proponents have their way! If any system goes for a toss, god can only save.
Which brings me to another observation. When i was Germany few years back, one of my colleagues (who was physically challenged) used to drive a retrofitted Golf (Automatic). Steering was as usual as with other cars (with a kind of blob for easy maneuverability), however there was a kind of joystick in pace of gear lever - when pushed forward the car used to accelerate and when pulled back it used to brake. There were no pedals to be seen.
So i think in similar circumstances DBW becomes indespensable.
