Old 18th June 2005, 09:25   #1
Bardahl Engine Treatment Oil ???
Hello Frends, I Just Bought A Bardahl Engine Treatment Oil For Old Vehicles Run More Than 50000 Kms.
Its Been Mentioned On The Cointainer To Add Min 10 % To Max 20%.
Should It Be 10 % Of The 330 Ml Of Bardahl Oil Cointainer Or 10 % Of The Engine Oil In The Vehicle.
Amit
shahmotors is offline
Old 18th June 2005, 14:30   #2
snoopy41
Posts: n/a
i would recommend the following procedure for best results,,
first confirm how long has it been since your last engine oil /filter change and which oil r u using,,if it is more than 7000 for an ordinary oil or 10000kms using a synthetic oil,then first change the oil and filter ,,preferably use castrol gtx2 20w50,,if its apetrol car and put the entire contents of the bardahl can ie 330 ml,,which will automatically work out to a ratio of approx 10%,,since most cars capacity is 3-4 litres of engine oil,,am assuming its a petrol car ofcourse,,so be careful abou that
Old 18th June 2005, 17:32   #3
moralfibre's Avatar
Thanked: 14,118 Times
It should be 10% of the oil tank capacity of your car.. so if your engine oil capacity is 3 litres then use 2.7 litres of normal recommended grade engine oil and add 330 ml of this can.. !
moralfibre is offline
Old 18th June 2005, 18:08   #4
hi, thanx for responding. i have purchased the safari just some time back, got it serviced recently , n i did change it with new engine oil n oil filter, after servicing i have driven 500 kms.
i think for a safari diesel the oil capacity is 8 litres ?? so should i add 2 x 330 ml cans of bardahl??
amit
amit
Old 20th June 2005, 12:40   #5
Rice_tuner's Avatar
Thanked: 15 Times
is it the SAME oil treatment for a diesel and a petrol engine? if not...make sure u'v bought the diesel version of the can...
cheers
Rice_tuner is offline
Old 21st June 2005, 09:51   #6
yeah, its the same for diesel, n petrol.
amit
Old 21st June 2005, 15:08   #7
moralfibre's Avatar
amit
amit
10% of 8 litres is 800ml ... divided by 330ml = the number of cans you will require for your car...
do not forget to subtract 800ml from 8 litres while adding the oil...
Conclusion:::>> Use 7.2 litres of the standard engine oil and 800 ml of Bardahl additive...
For best performance after flushing the old engine oil.. pour in 400 ml of Bardahl and then pour 7.2 litres of Engine oil and then again pour in the remaining 400 ml of Bardahl!
Old 24th June 2005, 14:07   #8
hi, thnx for the advice, that sound logical, as the oil will be mixed properly. hey friend how good is the practical effect of bardahl oil on engine perfomance??
i mean before n after.
amit
Old 24th June 2005, 14:26   #9
SUV
SUV's Avatar
Bardhal effect
I have driven a hero honda with only Bardhal in the engine (a bit of engine oil) .. :-) for 20k Km .. no damage whats so ever ;-) but this was couple of years back (actually when bardhal was introduced tin the Indian Market)
Also used the Bardhal on My Sierra - After effect's less smoke, better protection @ higher RPM's & better FE
SUV is offline
Old 24th June 2005, 15:39   #10
DRC
DRC's Avatar
Thanked: 66 Times
need more info
All, any more light on this issue, I am interested,,,,
What is the recommended engine age for using this.?
How does it work technically?
DRC is offline   (1) Thanks
Old 25th June 2005, 00:02   #11
moralfibre's Avatar
Basically all this stuff is solid oil base which has higher thickness (As I say it) which aid in better lubrication due to which some friction noise is reduced and some amount of energy lost in friction is made up for..
I dont know how good Bardahl is but I have used Pyramid engine oil additive in my Zen and it gave quite good outcomes... I am not sure about the side effects like Carbon deposition etc... so please do an analysis before you use it!!
Old 10th January 2007, 10:49   #12
Bardahl Engine Oil Add
Hi guys after getting my palio serviced i just added it with Bardahl engine oil additive,
has anybody expereinced results with it ??
Note from mod: threads merged
amitshah is offline
Old 10th January 2007, 23:56   #13
wolfinstein's Avatar
Thanked: 20 Times
I did notice a smoother engine with STP flush which is similar to bardhal, Also considering that STP costed me Rs.210 and Bardhal is around Rs.900..!
But what is the Bardhal Treatment here being referrd to, You add it to engine Oil and keep running it, won't that reduce the consistency of the oil making it thinner.
wolfinstein is offline
Old 13th January 2007, 01:52   #14
The Wolf's Avatar
Thanked: 75 Times
Bardahl treatment potion is atleast 5 times more viscous than the normal engine oil, how will that account to thinning the oil??
The Wolf is offline
Old 13th January 2007, 12:06   #15
Kaizer Sozay's Avatar
Are we talking about an engine oil additve or a flush here.
also can anyone suggest which is a better engine treatment.
Bhardal or Nulon.
Kaizer Sozay is offline
