Old 19th June 2014, 00:14   #691
sportz_kruzer's Avatar
Neat job...id like to know what "jugaad" is done in the background..(bypassed clima relay! !??).the panel is easy to remove. .two nuts behind the knobs which can be pulled out easily..the ""EC" button activates compressor when off..
sportz_kruzer is offline
Old 19th June 2014, 04:30   #692
Ray32825's Avatar
Thanked: 69 Times
Re: Mercedes W124 E Class Support Group
Guys, if your fuel pumps are buzzing, have the system cleaned and always drain all old/dirty fuel from the tanks or you brand new pumps wont last long.
Ray32825 is offline
Old 19th June 2014, 12:15   #693
abhiram7912's Avatar
Thanked: 77 Times
I don't know what led to this switch being installed. The driver that got this done is no longer working for us. I am still confused about some of the buttons on the dashboard as i don't have the manual.
I also found a new switch on the panel below the steering wheel. it doesn't look to me like OEM Mercedes. it has a single horizontal line, followed by a circle and two horizontal lines. couldn't figure out what it does.
abhiram7912 is offline
Old 19th June 2014, 17:09   #694
DeepakMenon's Avatar
Thanked: 182 Times
Originally Posted by abhiram7912 View Post
Thanks a lot for the help. Will report back once i get the work done. any advice regarding headlamp bulbs? I travel mostly in rural roads with lot of unlit vehicles, people and animals crossing the roads. I am looking at Osram nightbreakers unlimited but they are a bit hard to find where i am as i want to test them before buying them.
That AC button is a aftermarket job; cannot say anything unless I know what is the wiring behind it. Did you add this button??
I wont be surprized if your KILMA is not working, hence this short cut; and maybe your cabin temp sensor is also not working; else you should be able to maintain temp inside using the temp wheels
Lastly, it can also be the dial; they are known sometimes to have loose contact leading to some blower points not working; Pull the dial out and carefully remove the wood veneer; post that you will see the screws that hold the dial. see if you can change it a spare unit and it solves the problem. Else you will have to explore whether it can be opened and cleant
Lights : go with 100/90; works like a charm; but before that ensure your lens is clean and properly levelled
Since engine is cranking; that means key aint the issue. I am not the best in diesels unfortunately ; but check the fuel flow and related items as I mentioned in my post earlier
DeepakMenon is offline
Old 19th June 2014, 17:11   #695
Thanked: 182 Times
KILMA can be by passed, tons of info on net
http://www.peachparts.com/shopforum/...operation.html
Old 19th June 2014, 19:35   #696
Ray32825's Avatar
Thanked: 69 Times
If you need any wiring diagrams or anything else, let me know, I have the manuals, just let me know what year and model. This diagram is for 1990 models from MOD5.
Ray32825 is offline
Old 20th June 2014, 04:53   #697
Ray32825's Avatar
Thanked: 69 Times
Instruments and controls from owner's manual -
Ray32825 is offline
Old 20th June 2014, 13:14   #698
Thanked: 77 Times
No I did not add the button. one of our previous driver may have gotten it done, i was out of country for last 7-8 yrs so don't know what was done to the car in that time and was not able to find any records at home so just trying to fix the car one problem at a time.
I am assuming KILMA is the climate control system ? i will get the system checked and cleaned during the next service.
Old 20th June 2014, 13:18   #699
Thanked: 77 Times
Thanks so much. There are three buttons for #23 i know the bottom one is for air recirculation. Do you know what the two buttons on top does?
Old 20th June 2014, 14:27   #700
Thanked: 266 Times
I have the user manuals for the W124 assembled and sold in India. Anyone is most welcome to contact me for any information or extracts that you may require
53BHP is offline
Old 20th June 2014, 16:35   #701
Ray32825's Avatar
Thanked: 69 Times
Air Conditioning and climate control from owner's manual.
Ray32825 is offline
Old 20th June 2014, 17:24   #702
Hope the above query is solved..Sorry if I am bumping in..my e220s clutch is annoyingly stiff. .doesnt spring back immediately. It takes quite some effort to push it down and it comes back in say in less than a second. .I replaced clutch plate, pp and slave cyl replaced an year back. The clutch pipe is local as I couldn't find oem. Bled the cluch multiple times ..didnt help..could there be a restriction anywhere of any sort? And yes clutch master was also changed a few months ago. ..absolutely no difference :-(
Old 20th June 2014, 18:01   #703
Thanked: 182 Times
W124 clutch should be feather light, now you have basically changed everything that needs to be changed. it sounds like the pedal is squishy and it has always to do with, Leak, air in system, cylinders. I don't not think the pipe should have a huge role to play unless it was way off in diameter
Just two question; what brand was the slave and master cylinder?
How is brake feel?
Old 20th June 2014, 18:16   #704
Ray32825's Avatar
Thanked: 69 Times
If your slave and master cylinder are working fine, it could be your throw out bearing that is sticking on the spindle. When replacing the clutch components, the interior should always be cleaned of debris and grime and new grease applied to the spindle on which the throw out (clutch release) bearing slides. First eliminate your clutch hydraulics before you inspect the clutch internals as the tranny will have to be removed.
Ray32825 is offline
Old 20th June 2014, 18:59   #705
Ray32825's Avatar
Thanked: 69 Times
It's not that difficult to diagnose, just go step-by-step. First of all, it's a hard clutch not a spongy or squishy pedal. So that should eliminate any air in the system, assuming that the bleeding was done properly.
Secondly, when bleeding the system the pedal should not be hard and should travel back-and-forth easily. If this is the case then their most probably is no problem in the master or slave cylinder.
The diameter of the line (hydraulic hose) has nothing to do whatsoever with the performance of the system. The only time the hydraulic line causes a problem is if it develops a slow leak or is breaking down internally causing it to expand and take up the pressure.
Ray32825 is offline
