▲ Go to Top ▼ Bottom
Old 5th March 2019, 20:43   #1861
rakesh_r's Avatar
Thanked: 3,431 Times
Re: All about diesel engine oils
A quick question, nowadays we see lot engine oils that can be used in both Petrol and Diesel engines. For a Diesel engine is is safe to go with such oils or to hunt for one that is specific to only Diesel engines. Question is for my SCross 1.6.
rakesh_r is offline
Old 5th March 2019, 20:49   #1862
hserus's Avatar
Thanked: 9,318 Times
That's the D16AA engine so you need a ACEA C2 5w30 or 0w30. Take your pick of these - 5w30 is fine for hotter climates like India as long as it has ACEA C2 rating.
https://www.amazon.in/IDEMITSU-SN-A5...dp/B07HK6KYRV/
https://www.amazon.in/Liqui-Moly-Mol...dp/B078G7N3TB/
https://www.amazon.in/Mobil-5W-30-Fu...dp/B00SFNNTSE/
hserus is offline   (1) Thanks
Old 6th March 2019, 11:16   #1863
rakesh_r's Avatar
That's the D16AA engine so you need an ACEA C2 5w30 or 0w30. Take your pick of these - 5w30 is fine for hotter climates like India as long as it has ACEA C2 rating.
Many thanks for the recommendations. I also found one from Amsoil-
https://www.amazon.in/Signature-Synt...s=amsoil+5w-30
But it is ACEA E9, E7, ACEA E6, will this be suitable considering the recommended is ACEA C2?
Also found one more from Liqui Moly-
https://www.amazon.in/Liqui-Moly-Lon...4YSWENDKBWXART
rakesh_r is offline
Old 6th March 2019, 11:43   #1864
hserus's Avatar
The amsoil is fine but your fuel economy will go for a toss. A bit overkill for smaller diesel engines. You want amsoil check their 5w30 European Car Formula.
ACEA C3 should also be reasonable but on the safer side go for C2 oils.
ACEA C2 Stable, stay-in-grade Engine Oil with Mid SAPS-Level, intended for use as catalyst compatible Oil at extended Drain Intervals in Vehicles with all Types of modern Aftertreatment Systems and High Performance Passenger Car & Light Duty Van Gasoline & DI Diesel Engines that are designed to be capable of using Low Viscosity Oils with a minimum HTHS Viscosity of 2.9 mPa*s.
ACEA C3 Stable, stay-in-grade Engine Oil with Mid SAPS-Level, intended for use as catalyst compatible Oil at extended Drain Intervals in Vehicles with all Types of modern Aftertreatment Systems and High Performance Passenger Car & Light Duty Van Gasoline & DI Diesel Engines that are designed to be capable of using Oils with a minimum HTHS Viscosity of 3.5 mPa*s.
Old 11th March 2019, 15:58   #1865
maker_of_things's Avatar
Thanked: 181 Times
Hey.
Looking for an engine oil for my dad's 2014 Tata Aria 2.2L Varicor engine.
I was initially looking at the Shell Helix Ultra 5w40 that I use on my Linea 1.4L Fire. But, given that the manual states a API-CH4+MB228.3 I was wondering which engine oil would be best suited for my dad's car.
It's been about 9-10 months since the last oil change from the ASC. I also noticed some black soot on the exhaust tips. What could be the cause of that?
Nikhil
maker_of_things is offline
Old 11th March 2019, 16:15   #1866
hserus's Avatar
CH4+above is -
Mineral - Shell Rimula, Caltex Kixx etc the sort of mineral oils that come in a 7.5 liter bucket
Synthetic - Mobil Delvac 1, Amsoil 5w40 CK4
Don't use SHU 5w40 that's API SN/CF and ACEA A3/B4, great for petrol cars and light duty diesels, maybe not so much for a 2.2 varicor.
Soot on the exhaust tips = too rich fuel / injector clogging etc.
Originally Posted by maker_of_things View Post
Hey.
Nikhil
Old 11th March 2019, 17:36   #1867
sumzup's Avatar
Thanked: 154 Times
Hey.
Nikhil
You could also try the Castrol Edge titanium range which works good to. It is fully synthetic too and I've been using this personally over the past 7 years so can vouch for it. Cheers
sumzup is offline   (1) Thanks
Old 11th March 2019, 17:45   #1868
hserus's Avatar
That is not an api ch4 or higher oil so while it is a good oil it is not fit for his purpose.
hserus is offline
Old 11th March 2019, 17:46   #1869
mercedised's Avatar
Thanked: 449 Times
Hey.
Nikhil
I had Tata Aria and always used Castrol GTX Diesel API CH4 as recommended by Tata and had no problems costed around 310 per liter.
mercedised is offline   (1) Thanks
Old 11th March 2019, 19:00   #1870
sumzup's Avatar
Thanked: 154 Times
Hey Hserus, not to question your knowledge, but AFAIK with my limited understanding Castrol Edge pro is an SN range engine oil and has been recommended for vehicles made after 2010 and CH4 is for those between 1998-2002 to meet those emission standards.
Also, what I remember reading is that SN is a grade that provides benefits as: High temperature deposit protection for pistons; better sludge control; better seal compatibility and after-treatment compatibility and hence IMHO can be supplemented in those cars that require CH4 compliant oils.
sumzup is offline
Old 11th March 2019, 20:06   #1871
prithm's Avatar
Thanked: 713 Times
I was rummaging through reviews between Shell vs Mobil 1 and found something interesting. Thought this might contribute to collective knowledge of this thread.
https://rotella.shell.com/en_us/medi...t-results.html
https://www.mobil.com/en/mobil-delva...-synthetic-oil
prithm is offline
Old 12th March 2019, 05:11   #1872
hserus's Avatar
It is sn/cf right?
SN is the latest in a series of API standards for petrol engines. S for spark.
CK4 is the latest in the API standards for Diesel engines, C for compression.
So the fact that you are using a SN rated article matters very little. To complicate things most such oils also comply with ACEA standards for dual use petrol / diesel oils which some car manufacturers (Toyota, most Europeans, Ford diesels etc) expect rather than the API ones.
But if a car says it needs CH4 or higher you need a full fledged diesel oil not one of the petrol / diesel ones.
Mobil Delvac 1 for synthetic CI4+, Amsoil Turbo Truck for CK4, various mineral diesel oils which Tata expects which these days are generally CI4+
Here you're comparing Mobil CK4 with Shell Rotella CK4 - both these aren't available in India just yet. Only Shell Rimula R4 (CI4+) and semi synthetic HX5 Diesel 15w40 (plain CI4) so far, and Delvac seems to still be CI4+. True that formulations and additive packages may make a well formulated Mineral better than a Synthetic blend (semi synthetic).
https://lubes.mobil.com/AP-English-L...ac-1-5w40.aspx so this isn't the Delvac you're talking about unfortunately. At least I haven't seen any CK4 Delvac as yet in the Indian market.
Old 15th March 2019, 09:47   #1873
Although my knowledge on oils has been enlighten with this ongoing thread, but it has left confused.
Oil change is due for my punto MJD. Now the option is either to stick to Selenia WR 5W40, as OEM oil OR switch to another brand.
But, unable to figure out which brand confirms to ACEA A3/B4 - Fiat 9.555535-N2 or API CF4 ? My concern is, I don't want to use an oil which is too higher in specifications which can lead to engine problems. Also higher specifications engine oil will not make much difference to the perfomance.
Besides Maruti recommends Mobil Super MGDO 5W40 which confirms to Fiat 9.555535 standards, but the oil change interval in Maruti with MJD's is 10,000 kms, while fiat recommends oil change at 15,000 km.
Hserus, your thoughts please
ashagl is offline
Old 15th March 2019, 10:21   #1874
hserus's Avatar
Use any 5w40 a3/b4
Shell Helix Ultra 5w40 or Idemitsu in that rating
hserus is offline
Old 15th March 2019, 12:31   #1875
Thanks hserus
I am contemplating between Liqui Moly Leichtlauf High Tech 5W-40 which is complies with A3/B4 and Fiat 9.555535-N2, but this product is not easily available.
Technical litreature: https://pim.liqui-moly.de/pidoc/P000...40-33.0-en.pdf
VS
Liqui Moly Leichtlauf HC7 5W-40, this complies with A3/B4, but not Fiat 9.555535-N2
Read Technical litreature: https://pim.liqui-moly.de/pidoc/P000...40-22.0-en.pdf
This one is easily available
ashagl is offline
