Closed Thread
Old 17th April 2005, 00:47   #1
karthik247's Avatar
Thanked: 30 Times
whats Supercharged and Turbocharged??
could someone tell me the diff.. btw supercharge and turbo charge...which one gives a more increse in power??
karthik247 is offline
Old 17th April 2005, 00:53   #2
Thanked: 2,757 Times
Both cases refer to forced induction by ramming in the fuel-air mixture. In the case of a turbocharger this is achieved by a turbine that runs off the exhaust gases (hence the 'turbo lag' - the engine has to be churning out a decent speed to generate the exhaust pressure required to run a turbo).
In the case of the supercharger, the same is achieved by a turbine running off the engine's drive - off the driveshaft.
In both cases, the turbine creates more pressure to drive in the air fuel mixture.
As you can see, I'm a bad trainer....
Steeroid is offline
Old 17th April 2005, 01:05   #3
turbo_lover's Avatar
Thanked: 9 Times
http://www.team-bhp.com/forum/showth...r+supercharger
topic has already been discussed .
turbo_lover is offline
Old 17th April 2005, 10:02   #4
Rehaan's Avatar
Thanked: 36,049 Times
Also see www.howstuffworks.com for an explaination of what a turbochanger/supercharger is.
Topic closed
Rehaan is online now
Closed Thread
