Old 20th December 2008, 00:12   #1
Loss of power in 1st gear
My UVA has done about 11 k kilometres now.
In heavy bumper to bumper traffic, if I've been alternating between 1st and 2nd gear for some time, there is sometimes a momentary loss of power in 1st gear.
This happens just when after I engage clutch and accelerate to get the car moving from a standstill. Does not happen when the car is moving. The engine keeps running but the car just doesn't respond and the engine vibrations die down to idling level.
If I disengage and engage clutch again, the problem disappears.
It has happened only a few times so am wondering if it is worth spending the minimum of two hours I will need to go to the service centre.
Any ideas anyone?
straightdrive is offline
Old 20th December 2008, 08:26   #2
headers's Avatar
Thanked: 563 Times
it will happen if you leave the clutch before revving the engine!
headers is offline
Old 20th December 2008, 09:29   #3
rjvora_2000's Avatar
Thanked: 57 Times
with you. but i believe this should be checked from garage.
rjvora_2000 is offline
Old 20th December 2008, 11:42   #4
esteem_lover's Avatar
Thanked: 513 Times
Could be a case of clutch overheating ? Do you ride the clutch ? try to avoid that.
esteem_lover is offline
Old 20th December 2008, 11:45   #5
vikram_d's Avatar
Thanked: 1,188 Times
Get the clutch play checked. Sounds like the clutch is little loose. Is it a hydraulic clutch by any chance?
vikram_d is offline
Old 20th December 2008, 12:11   #6
Thanks for the opinions, guys.
I know, however it seems that's not the case here. The engine doesn't stall but just doesn't respond to the accelerator for a moment. And it is a recent problem with no change in my driving style.
No, I don't ride the clutch. Am particular about that too.
No, as far as I remember the UVa doesn't have a hydraulic clutch. Thinking back I am wondering if the problem is more to do with the accelerator or fuel transmission.
Looks like I had better play safe and go get it checked. Cheers.
Old 22nd December 2008, 10:02   #7
the_maassk's Avatar
Thanked: 7 Times
Just guessing here - but its possible that your fuel cutoff (closed to open loop, happens when you leave the accelerator) is not sync'ed with the throttle position sensor properly. So, if your foot relaxed on the accelerator for a moment, it would cut the fuel and then it would again take a moment to go into closed loop when you press the accelerator.
Gurus can advise. (I may be completely wrong here! - let me know).
the_maassk is offline
Old 22nd December 2008, 10:34   #8
aaggoswami's Avatar
Thanked: 3,000 Times
Not a guru, but I get the same feeling. Either its clutch or it is some problem related to fuel or ignition. I think that the chances of clutch being the culprit here is less but the real issue is fuel cut off.
aaggoswami is offline
Old 22nd December 2008, 10:45   #9
hyper123's Avatar
AFAIK, the system goes into open loop only at 3/4ths throttle and WOT, other time it is in closed loop. When you let go off the A pedal, the IACV controls the idle RPM and the air flow.
hyper123 is offline
Old 22nd December 2008, 10:56   #10
the_maassk's Avatar
Thanked: 7 Times
I have a ScanGauge II installed on my U-VA. From what it reports - at least on my ride, the system goes into open loop at 3/4 throttle AND every time I release the accelerator, if I am on the move (and using engine braking to slow down; clutch not depressed). If I hit the clutch while I am coasting on momentum, the system goes into a closed loop.
Old 12th September 2021, 12:42   #11
loss of power while cold startng
Hundai accent petrol 2002
There is a loss of power when cold starting th car. It starts and then keeps spluttering. Pressing accelerator does not rev up engine and it continues to splutter. Occasionally it will rev up and then fall back to spluttering.
This phase lasts maybe 5-10 mins (have not timed it) and then engine picks up and drive is normal. Restarting after driving a bit is normal and splutter free.
I read another thread about engine intermittent 'drag' but that is different in that the loss of power is after normal running.
Is there something about startuip phase that can cause this problem? (Actually is not startup phase since it lasts for 5-10 min). The car will only crawl during this time with the spluttering engine supplying minimal power.
Is there anything that needs 'warming up' in a petrol car?
diytry is offline   (1) Thanks
Old 12th September 2021, 15:26   #12
Thanked: 174 Times
Re: loss of power while cold startng
I too have faced the same issue in my alto k10. I never really bothered about it as it is very infrequent - happens on some very cold rainy mornings.
The issue is ia very similar to what has been described by op. Pressing the accelerator does not rev up the engine - if you put the car in 1st gear and try to move it, the car stutters and stalls (even if you floor the accelerator pedal). The solution is to keep the car in neutral for around 60-90 seconds, and then it starts behaving normal.
Like I said, never really bothered about the issue given it’s barely an inconvenience. But would nonetheless appreciate if anyone can highlight what is the cause for this.
ACe_10 is offline
