Old 18th December 2008, 02:08   #1
kuttapan's Avatar
Thanked: 27 Times
Crankcase ventilation - What does it do to the engine?
We have been discussing crankcase ventilation in the following thread - http://www.team-bhp.com/forum/long-t...ml#post1072827 Page 26 onwards and suspecting this to result in a dirty intercooler. Looks like the technical Guru's have not been visiting that thread, hence this one, so that we can know more about PCV and it's effects.
I did my share of googling and came up with this link - Tutorial topic which clearly explains why crankcase ventilation is needed.
Question is, does a closed loop PCV(Positive crankcase ventilation) system result in a dirty intercooler?
kuttapan is offline
Old 18th December 2008, 10:24   #2
Jaggu's Avatar
Thanked: 17,293 Times
Opened up the plastic engine cover this morning looking for the line that ventilates the crankcase. Could not find it. Does the DDiS have such a system? Where is it? Can some one help?
Try retracing the plumbing from Turbo side and you will get to know if there is a provision in DDis
Jaggu is offline
Old 18th December 2008, 11:56   #3
DKG
DKG's Avatar
Thanked: 1,659 Times
A closed loop would mean the gases are fed back into the intake system. As the blowby gases carry oil vapour chances are if its not filtered (clogged or inadequate filter)it would contaminate the turbo and the intercooler. To prevent that eventuality I should think the system may need periodic maintenance
DKG is offline
Old 18th December 2008, 20:21   #4
rippergeo
Posts: n/a
Will try and do that on my next service.
@lone ranger- thanks for the thread and the Tutorial.
Old 18th December 2008, 23:59   #5
kuttapan's Avatar
Thanked: 27 Times
Can someone do this and confirm, please? With so many DDiS complaining of losing the turbo whoosh, I am wondering if there is more to it that meets the eye.
kuttapan is offline
Old 19th December 2008, 00:40   #6
mclaren1885's Avatar
Thanked: 46 Times
Infractions: 0/1 (10)
Probably, one should try just cleaning the EGR to see if it is clogged or something. Often, performance drop could be due to this. I have heard just by cleaning the EGR made a lot of difference on a car in Bombay.
mclaren1885 is offline
