Old 12th December 2008, 09:07   #1
archat68's Avatar
Thanked: 642 Times
Driving with choke on - what damage can occur?
I have a carb Zen. In the morning I often has to use choke to start the car and warm it up. What the problem is - on a few occation I forgot to push the choke to its normal position and drove the car with it - though not graet distances - mostly 1 - 1.5 Km. After which I realized the mistake and corrected it.
My question is what damage can occur to the car if driven with choke on apart from fuel wastage?
archat68 is offline
Old 12th December 2008, 09:20   #2
Thanked: 311 Times
No damage. Just that your car is running 'richer' and making you poorer!
anupmathur is offline
Old 12th December 2008, 16:01   #3
Raccoon's Avatar
Thanked: 116 Times
Hehe... ya, and whats more, since the air-fuel mixture will be far off the stoichiometric optimal, it will create more deposits in the engine.
Raccoon is offline
Old 12th December 2008, 16:49   #4
toiingg's Avatar
Thanked: 308 Times
Apache Indian will become very happy with you. "Chok De"
toiingg is offline
Old 12th December 2008, 17:41   #5
Thanked: 311 Times
Come on now! He said 1.5 kms! Surely that will not adversely affect the engine in any way!
Last edited by Rehaan : 12th December 2008 at 18:20. Reason: Lets still to "official" smileys only please. (Also it was an externally hosted image ;)
Old 13th December 2008, 00:08   #6
Raccoon's Avatar
Thanked: 116 Times
Well, he did mention "on a few ocasions", so deposits will build up. Also, even a small bit may foul your spark plug... maybe a small chance, but still a possibility! Bottomline is a vehicle should no way be driven that way.
Raccoon is offline
Old 13th December 2008, 00:43   #7
kuttapan's Avatar
Thanked: 27 Times
Plug will become a bit sootier than usual, but if your engine is otherwise good condition, and you drive long stints, the soot should be burnt away.
Other than your pocket getting lighter a bit, not much harm done. Emissions are another matter, though.
kuttapan is offline
Old 13th December 2008, 01:40   #8
Tejas@perioimpl's Avatar
Thanked: 9,764 Times
I've done that a few times ages ago and all i got was decreased FE....
I think the last time i drove a car with a choke was 1999! Damn, it's been a while!!!
Tejas@perioimpl is offline
Old 13th December 2008, 05:36   #9
sudev's Avatar
Thanked: 3,250 Times
Damage to your wallet will occur.
IAC if it is for a km or two after starting - this is almost the recommended procedure as you are to use the choke till engine temperature comes in to normal operating band. That said why would you need a choke start in Kolkata? Is your engine running weak compression?
sudev is offline
Old 13th December 2008, 09:48   #10
archat68's Avatar
Thanked: 642 Times
O.K point taken.
Its a 2000 carb Zen - so I need to use a bit of choke to warm her up. Otherwise too much vibration and knocking in the morning.
archat68 is offline
