Ceramic turbines are used to reduce the interia of the turbine and because they have longer life spans . they are made to take high amount of mechanical stresses, rapid temperature changes, vibrations , rapid cooling too. they work even at 1400 degrees. the use of ceramics is for increasing reliability .
also rally cars change their turbos, cams and gaskets etc so often because they use very limited amount of oil for cooling their engines . that results in excess wear and tear of their engine components . the main thing that do not cope with the misfiring systems are the turbo intakes(headers) even though they are coated with ceramics to reduce heat transfer and reduced friction resultng in increased volumetric efficiency of the fluid . they tend to expand n contract so much that they crack or no more remain as a constant area duct to the gas .
plus with so many sponsors shelling out money why would you not change ?:-):-):-)
Basically its not possible to determine the stress conditions of various indivdual components in a system in turbine etc . Their trying to employ plastics reinforced with glass to make turbines better since they are lighter and also the thermostability is better over a increased temperature range . plastics housings and compressor wheels are used because they have better creep resistence to temperatures .
creep resistance,Best stiffness at high temperatures,Best fatigue resistance and reduced cost and reduced weight are the main advantages Note from the Team-BHP Support Staff : Please use the "edit" button if posting within 15 minutes of the first post, instead of creating another back-to-back post
Reason: Back to back posts
