Old 26th November 2019, 11:58   #9481
coolkurt's Avatar
Thanked: 1,718 Times
Re: Honda Civic : Maintenance, Service Costs and Must dos
Update on the PS pump issue:
The China sourced pump that I'd installed in 2016 finally gave way. I scoured the market and the original costs Rs 19k while Ghai gave me a quote of Rs 4200 for the China import.
Went for the latter as I don't intend to keep the car for very long. The power steering is back to being super smooth.
Originally Posted by laluks View Post
My experience of the mount from Ghai's was also not good. So I decided to cut open both the mounts. Ghai's internal design was having much lesser chambers for oil compared to original one. I guess I had posted the comparison somewhere in this thread. But I was happy with the bush kit he gave for the suspension.
If it's the mount that you're talking about when we met in Delhi, the design has changed. The new one has lasted for more than 70k for me
coolkurt is offline   (1) Thanks
Old 26th November 2019, 18:32   #9482
sarathlal's Avatar
Thanked: 5,529 Times
That was why I advised sharathlal, if the car is a keeper to go the HASS way
Thanks! And here is the engine mount surgery thread of yours
https://www.team-bhp.com/forum/techn...ml#post3654390 (Honda Civic : Maintenance, Service Costs and Must dos)
sarathlal is offline   (1) Thanks
Old 30th November 2019, 13:19   #9483
Thanked: 74 Times
I am planning to get a pre owned manual civic. What all should i get checked in the car,any common problems?I plan to get a complete scan from honda before buying the car.
jayanttalwar is offline
Old 1st December 2019, 09:28   #9484
sumeethaldankar's Avatar
Thanked: 3,485 Times
This has been discussed many times on this thread buddy but here goes.
1. Engine mount.
2. Power steering rack and pump leakage.
3. Cooling coil for the ac.
The above are the most common issues the Civic has. Rest are regular like any other vehicle eg bushes, joints etc. All the above at HASS are expensive to fix, independant garage is the way to go. Honda's mounts are better but cost 10k a pop.
Good luck. Try to get a single owner car if possible.
sumeethaldankar is online now
Old 1st December 2019, 11:37   #9485
ashishrathi88's Avatar
Thanked: 109 Times
1. Engine mount.
+ Underbody for any damages as the car is very low slung and chances of scrapping the underbelly is likely.
AC Condenser coil issues also come up in this generation of Civic and has been highlighted by multiple owners in our forum. So, a peek at it is also essential.
Good luck with buying! IMO go for a car which is less driven and well maintained even though it would be 30-50K costlier than a less maintained one.
You will enjoy ever mile with a grin on your face. This 8th gen Civic is a gem.
ashishrathi88 is offline
Old 1st December 2019, 20:01   #9486
Thanked: 97 Times
Driver side seat belt buckle is not going in smoothly in my Civic. It gets locked in after multiple attempts using a lot of force. Something is either broken or dislodged inside the buckle.
Took it to HASS. They told me that it would need to be replaced. I paid an advance and asked them to procure it since it was not available. They have placed the request but haven’t received the part even after a month. Since it has an electrical connection for seat belt indication, they can’t use a normal buckle. Haven’t tried other workshops and part vendors.
Any suggestions?
Highflyer is offline
Old 2nd December 2019, 09:46   #9487
saket77's Avatar
Thanked: 13,447 Times
Originally Posted by Highflyer View Post
Driver side seat belt buckle is not going in smoothly in my Civic. ----Haven’t tried other workshops and part vendors.
Any suggestions?
Though I am not 100% sure but I think the belt buckle should be a common part across many cars since the seat belt design looks almost identical. Also, all new generation cars come with the provision for electronic indicator. You should try a spare part shop and get any OE/ good brand buckle. You can easily check if it engages/ matches your seatbelt design as it can be checked without fitting the part to your vehicle.
Saket
saket77 is offline   (1) Thanks
Old 2nd December 2019, 10:13   #9488
Thanked: 97 Times
Saket
Thanks @Saket77. They tried to fit the buckle from other Honda cars but none of them are of the same fit. I was quite surprised myself since I believed commanality of this part for cost saving etc. Will try spare parts shops.
Any other suggestions?
Old 2nd December 2019, 10:55   #9489
sgiitk's Avatar
Thanked: 4,799 Times
@Highflyer; Most spared for the Civic are imports. For example the wipers. So I am not that shocked.
sgiitk is offline   (1) Thanks
Old 3rd December 2019, 17:26   #9490
Thanked: 97 Times
Thanks @sgiitk. Searched on YouTube about seat belt buckle issues. Used WD-40, Silicone Lubricant and a screw driver to work the parts inside the buckle. It is working perfectly now. Wondering why it didn’t occur to me earlier. After all it has mechanical parts inside that might have got rusted or jammed.
People at HASS never tried to look at it from this angle. They were straight up for replacement.
Is it an issue of integrity, repair philosophy or couldn’t care less attitude?
Highflyer is offline   (1) Thanks
Old 3rd December 2019, 18:25   #9491
Honda advisor once said to me they have a "replace and not a repair" policy. They wanted to replace my Civic's power steering pump and rack once for a 1 lac rs, I said no thanks.
sumeethaldankar is online now   (1) Thanks
Old 3rd December 2019, 23:31   #9492
iTNerd's Avatar
Thanked: 1,217 Times
For those of you who thought retrofitting the steering wheel controls was difficult or impossible, here is a sneak preview in my Civic
Honda Civic : Maintenance, Service Costs and Must dos-imageuploadedbyteambhp1575396057.873495.jpg
More later...
iTNerd is offline   (1) Thanks
Old 4th December 2019, 06:20   #9493
KK_HakunaMatata's Avatar
Thanked: 1,007 Times
More later...
Please give more details and where to get the exact sizes.
KK
KK_HakunaMatata is online now
Old 7th December 2019, 12:38   #9494
iTNerd's Avatar
KK
Did the followings:
1) Ordered part #36770-SNA-A12 from AliExpress - https://www.aliexpress.com/item/3290...71254c4d69gj9G
2) De-assemble the steering wheel making sure Battery (-ve) terminal is disconnected so that airbag can be removed.
3) The part #36770-SNA-A12 comes with both Audio controls (left) and Cruise Controls (right) - all in one harness.
4) Just after the clock srping, there is a white harness. For my Civic, it only have one wiring - that of the horn at position 10. We need to add pins for the position 3 and 4, which are for audio controls.
Honda Civic : Maintenance, Service Costs and Must dos-steering-wheel-conector.jpg
And you need to wire these two with that of the audio unit connector harness at position 6 and 7. Note that, as our civic already have audio controls at rear arm rest, these 6 and 7 are already connected. So, you will have to disconnect and re-use these positions to connect with the position 3 and 4 of the steering harness.
Honda Civic : Maintenance, Service Costs and Must dos-audio-unit-connector.jpg
The steering harness only contains one pin at position 10 for horn. So, you will need to source the pins from elsewhere or purchase another equivalent harness to extract the 2 pins.
Here is an excellent video that would help you
The steps are easy once you know the pins diagram of the harness. The steering controls hardly costs Rs 1500, though it needs a lot of patience and time to disassemble and complete the circuit. I was replacing my headunit to Blaupunkt New York 750 and this was a good opportunity to install the steering controls as well, with the help of professional audio expert. So, if you don't feel confident of doing it yourself, take help from an expert as that will help you avoid accidentally breaking things.
I wish I could have done this retrofit 10 years when I bought the car.
iTNerd is offline   (7) Thanks
Old 7th December 2019, 13:27   #9495
sgiitk's Avatar
This is the standard corporate policy with all vendors. Replace & not repair is the buzz word. This is why as my cars are getting old I am off the corporate ladder.
sgiitk is offline   (2) Thanks
