Old 8th April 2010, 18:24   #691
manim's Avatar
Thanked: 918 Times
60K Service
I have fixed an appointment for the 60K Service tomorrow (Civic-AT).
Transmission-fluid and Brake-fluid will be changed for the first time.
Delivery was promised early evening.
I plan to spend the whole day near my car.
(wonder if I am allowed to, the service staff may kick me out?).
manim is offline
Old 8th April 2010, 21:50   #692
ImmortalZ's Avatar
Thanked: 584 Times
Mirror replacement was INR 423/-, all inclusive.
ImmortalZ is online now
Old 9th April 2010, 08:51   #693
rr_zen's Avatar
Thanked: 401 Times
Thats pretty cheap I must say. Hope the quality of the mirror is as good as the one that came with the car.
rr_zen is offline
Old 9th April 2010, 09:08   #694
vasoo's Avatar
Thanked: 246 Times
Originally Posted by mukeshgoel View Post
I also got it (fender lining) changedlast week only. It came down at its own and started to touch front left wheel and in the process got damaged.
Costed me Rs.1500 incl. labour and all taxes.
I replaced the fender lining yesterday and it cost me the same, about Rs1452 inclusive of parts cost and installation. There was a slight misalignment of the left fender which was corrected.
vasoo is offline
Old 9th April 2010, 09:13   #695
ImmortalZ's Avatar
Thanked: 584 Times
Original Honda OEM replacement. It's identical to the one that came with the car.
@sgiitk : Maybe that's why they haven't called me for my next service. It's due on Monday.
Old 9th April 2010, 09:56   #696
sgiitk's Avatar
Thanked: 4,793 Times
I always believe that it is better to get the wheel alignment, balancing and rotation done at a competent tyre dealer at specified intervals than leaving it in the hands of the A.S.S.
I fully agree. Rotation should be part of service, and ensure it is done. One trick - make a small mark on the spare and see whether it appears!
As for alignment with more and more cars with rigid rear axles many tyre shops do not align the rear wheels. My last two main cars (Accent and before that Esteem) had IRS. The last time I took the Accent in the chap did no do the rear, and was arguing with me that it is not recommended. His alignment jig also did not have the settings programmed.
PS: I have a Civic AT on order hence am paying particular attention to this thread.
sgiitk is offline
Old 9th April 2010, 13:57   #697
rr_zen's Avatar
Thanked: 401 Times
Good thought but not sure if the A.S.S includes the spare wheel in the rotation, all the more since the newer Civics have a non-alloy spare wheel.
Thats news to me. I changed all tyres on my Esteem two weeks back and the tyre dealer indeed did the alignment for the rear wheels as well. Maybe this is something that one needs to watch out for.
Again, how confident are we with the A.S.S doing the alignment for the rear wheels esp since it does not happen in the customer's presence ?
Congrats ! I thought you already owned one. Is it a new one or a used one that you are looking at?
rr_zen is offline
Old 9th April 2010, 14:39   #698
That's reasonable. I first thought you might be talking about the whole mirror assembly.
I had a bike smash the driver's side mirror indicator (the 3 LEDs still worked fine) and leave the electronic mirror adjustment damaged (it was manually adjustable though). The actual mirror itself had just come loose - I took it to Honda to place it back for me.
Eventually replaced the mirror assembly for 6.5k (they can't open it up & it's not possible replace just the transparent indicator cover).
koshyjohnuk is offline
Old 9th April 2010, 15:17   #699
shuvc's Avatar
Thanked: 353 Times
Sounds like a pretty fair price for a fully motorised mirror assembly with LEDs. The Baleno mirror assembly (SGP) costs around 5.5K !
shuvc is offline
Old 10th April 2010, 11:31   #700
ImmortalZ's Avatar
Thanked: 584 Times
Coincidentally, the Civic rear suspension is independent, but not adjustable. You need aftermarket camber plates to adjust the rear.
I did an alignment and balancing at an outside shop for the first time a couple weeks back. The whole thing was out of whack. Pretty obvious that the A.S.S never did the alignment and balancing that they were charging me for.
Old 10th April 2010, 17:56   #701
rr_zen's Avatar
Thanked: 401 Times
I am not surprised. IMO the A.S.S's forte is not wheel alignment and balancing and hence we are better off getting it done at a reputed tyre dealer outside and in front of our eyes.
rr_zen is offline
Old 10th April 2010, 22:03   #702
mkc15's Avatar
Thanked: 89 Times
Does this noise occur when you're standing still? If not, your tyre might have developed a flat spot. It shouldn't, with ABS... but that's worth checking out.
After careful observation, I found that the cut-cut noise comes only when the car is up the ramp and turning right, with front left climbing the curb. Seems to be either some steering issue or suspension. How do I diagnose ?
mkc15 is offline
Old 11th April 2010, 18:19   #703
manim's Avatar
Thanked: 918 Times
60K Service over
60K Service over.
Car is nearly 3 years old.
Total amount paid - Rs.6,721 (inc. taxes)
breakup (inc. taxes):
Parts:
Synthetic engine oil - Rs.2,362
AT Oil - Rs.1,120
Brake fluid - Rs.315
Oil filter - Rs.155
Air filter - Rs.820
Washer - Rs.19
Labour:
60K service - Rs.1,214
4 Wheel balancing - Rs.330
Wheel alignment - Rs.386
Car is great! Hoping to enjoy it till 2 lakh kms!
manim is offline   (1) Thanks
Old 11th April 2010, 19:29   #704
trrk's Avatar
Thanked: 34 Times
If at all you do alignment (anywhere), insist on a print out. I did get a printout of the alignment done at Peninsular Honda.
trrk is offline
Old 12th April 2010, 09:11   #705
ImmortalZ's Avatar
Thanked: 584 Times
Another possibility is a drive shaft issue. Get it checked ASAP. If the boot is torn, then every KM you drive is significantly reducing the life of the CV joint.
