Originally Posted by flipsyde Which car is short of problems? Lauras were plagued with poor A S S and AC problems. Not to forget the DSG boxes conking off around 70-80k km mark. Verna with its vague steering. i20's with the AC and steering issues. Linea with GC issues, rusting, AC problems and clutch trouble. Why even the big guns like Mercs and BMWs have their fair share of problems like SBC in the E270, electronic problems in the early A6s etc |
When I decided it was going to be the Civic I was fully aware of the knowledge that I am buying a Jap, so it's basically 15L INR for the engine and loose change for everything else. And I must say again (have put it on record in my ownership thread) that the "everything else" is worth far more than loose change. Case in point is the steering. I was also perfectly OK with the wheelbase + GC thing, although the car underwent some damage initially before I could fully learn to handle this aspect. No issues now, after 1.5 years and 24800 kms.
However, what I wasn't prepared for was the following -
1. Squeaking clutch pedal in 15 days (before the 1st service)
2. Rattling roof panel in a few more days' time
3. HASS *refusing* to accept that there is a problem, sometimes (I can live with incompetence but not without empathy/acknowledgement)
4. The more complex/costly bits seemingly going out of peak working condition so soon (well within warranty itself, leave alone extended warranty)
If you notice, 1-3 aren't major issues arising out of the complexity of the vehicle. And after spending 15+ these things rankle. Regarding 4, I did mention that the 800 was far less complex, so it's OK and you raise very valid comparisons indeed. Point #4 is a simple expectation reset that I need to do, I guess.
And finally, I still love driving the car except when roads are really bad. That's what counts at the end. Like Prof. said I've tuned my driving style to suit this car's quirks (mainly GC and rear suspension). For example, I'll stomach it and go slow without pushing if I think the road surface isn't ideal and not work myself up over it. This attitude change is still a work-in-progress.
Quirks are different from (perceived or real) malfunctions. One hopes things can be better but that doesn't imply that current behaviour is faulty. Sub-optimal, perhaps, but not faulty.
Originally Posted by mayankjha1806 I am a surprised reading this, did you get the suspensions checked, although my Civic is newer but i have taken with full load (Four adults + Luggage) over 1500Kms long drive which includes fast 4 lanes highway and bad yet to tared roads and never the rear gave a feeling that its going to step out of the way.
The speeds we did were much higher that 90, you could look at my TL for more details. Never did the car scrape or felt wobbly at any speed on any terrain. |
The rear stepping out behaviour that I've observed is not speed-dependent. It's about the rear wheels hitting a bump mid-corner or edging a rut/ridge etc. I've wilfully made the rear skip sideways even at 40-ish kmph. One just needs to find the right imperfection on the road.
There are absolutely no issues on good (or even half-decent) roads usually.
I've had the misfortune of navigating the car on roads like Gajendragarh - Kushtagi - Sindhanur, where trucks were zig-zagging to avoid craters and tractors were driving with their left wheels off the road because the earth beyond the road shoulder was smoother than the road! The car sailed through brilliantly with nary a hit to its underside.
These aren't the issues at all. What I've observed with the rear are 2 very specific situations (4/5 pax + luggage and quick manoeuvres/overtaking; rough roads which can make the rear tyres catch the edges of these imperfections and skip sideways). Like I said earlier I will treat this behaviour as sub-optimal and not faulty. I never mentioned these even once to HASS because they really can't do anything about these. The fix, like you've all pointed out is better rubber and suspension bits. That time shall come.
Originally Posted by jatinpatel @mayank that might be because your is the face-lifted civic with changes to the mounting points to rear shocks it might be that Honda might have tweaked the rear suspension geometry a bit or they might have stiffened the shocks.
Mine is an 07 pre facelift
suspension is in top nick got it checked and re-torqued at Honda itself. |
Mine's a post-facelift (July 2010 mfg.) car. Tyres and suspension are absolutely stock.
Originally Posted by smartcat What Jatin is saying is true. Civic is tail happy - the rear end loses grip before the front does. Although, I consider this trait to add to the fun factor, rather than feel nervous. Because of the tail happy rear, Civic will rarely understeer in corners - the front end simply digs in. |
Surprisingly, I've encountered understeer as well even when not carrying too much speed into the curve or accelerating too hard out of the curve.
This was a curve en route my daily commute in Hyderabad. I always had to back off the throttle a little and turn into the curve a bit more than I started off with. Perhaps it's a reducing radius curve and I didn't really notice it, or it could just be the stock tyres (which I think are fairly good, truth be told), or maybe I just chickened out every time.
![Smile](https://www.team-bhp.com/forum/images/smilies/smile.png)
I definitely don't think I used to carry too much speed into this corner.
Net-net - considering FWD and neutral toe at front and the insane power surge at those easily attainable high revs - I'm happy with the car's front-end's behaviour. The steering is to die for.
Originally Posted by laluks And about the GC, I guess every practical person had know this before putting his money on to the car. And there is always ways to handle that. I can say that from experience. |
GC is a non-issue like I said earlier. In fact I never even "blamed" Honda for not "fixing the GC" with the facelift because I am convinced that that was not the intent behind the facelift. And you can't beat geometry/physics.
spadix
