Re: Revving the engine.. How often do you do it With all due respect, unfortunately, that is not true. In an oil cooled turbo charger, the feed line is directly connected to it and its the job of the oil pump to ensure the oil supply is met. The pump does not have the AI to distinguish between revving in neutral or revving up under load. Oil flow to the turbo charger is constant via an oil restrictor.
What is true though is that one should NOT rev a turbo charged engine and shut it off immediately as the oil pump which in most of the cases is mechanical, shuts of the oil supply to the engine and thereby to the turbo oil feed and that can cause the turbo to fail if this cycle is repeated over and over again.
Ideally, just like its recommended to let the engine idle a bit before moving, its recommended to let the engine idle a bit before shutting it off.
The new age CRDI turbo diesels love to be driven hard, and one should stretch its leg whenever possible to have the engine/exhaust clear of soot.
Hope this helps! Quote:
Originally Posted by pganapathy If you have a turbo charged engine, NEVER, rev an engine in neutral. The reason for this is that your turbo is spooled up with the revving, but engine oil is not circulating. Understand a good turbo can rev as high as 100,000 RPM and you can understand what damage can be done if there is no lubrication for long periods of time.
What I will suggest is take the car out maybe one night a week and find some long and empty roads and do a drag or two. Should be satisfactory  |
