Old 14th July 2009, 12:18   #901
bantejas's Avatar
Thanked: 30 Times
Originally Posted by smsrini View Post
When my car went for the 30k service, the SA advised that they've been asked to retrofit the tail gate lock / latch with a larger latch, which apparently fixes the rattle once and for all.
You've got to pay for the retrofit, and it costs around 400 for parts, and 300 for labor.
got it installed on my car today. will post some pics and the exact cost tomorrow.
Unfortunately dont have a pic of the latch before the retrofit.
I have got this fixed and it is working fine. If a person is not bothered about the looks then the spare wheel can be removed. But will the Safari owners do that?
bantejas is offline
Old 14th July 2009, 14:12   #902
Thanked: 462 Times
Originally Posted by maheshmenon View Post
Kind Attn.:- Mr. Mahesh Menon
We are in receipt of your email dated 11.07.09.
We would like to inform you regarding your query that Mobil Delvac Mx oil is not tested and approved by Tata Motors. The use of the same will nullify the warranty.
If you wish to use Mobil, then you can go for Mobil Super 1000 TM. This is CH4 oil which is tried and tested by Tata Motors. This is approved and has a drain interval of 15000 kms. The oil is available in all the Tata Authorized Dealership / Service Center. Please use this oil instead of Delvac.
Thanking you
For Tata Motors
Customer Care Team
Mumbai
So now I am one confused consumer sitting on 10L of Delovac MX
Attaching the specs for Mobil 1000 for your ref and decision. If they find non-approved oil usage, warranty stands VOID.
What rattles, I dont have rattle in any doors with OEM fitment itself.
dadu is offline
Old 14th July 2009, 16:21   #903
simply_sunny001's Avatar
Thanked: 19 Times
then you are one lucky dude(or dadu) and maybe you never have to travel on bad roads.
but its a regular problem with 3 Safari's we have in our family.
simply_sunny001 is offline
Old 14th July 2009, 16:51   #904
jkdas's Avatar
Thanked: 1,492 Times
Originally Posted by nitrous View Post
BEWARE Bosch Wiper buyers:
Have a look at my post here:
http://www.team-bhp.com/forum/1381474-post235.html
I use 20/20 as 22/22 was longer
Just got a jar of Delvac MX from the Mobil Main Distributor (Affiance Enterprises) in Chennai. I was Rs. 680/-per litre +VAT. For a 10L jar, it cost around Rs.1780/
It's Given on Pg. 148 of the Manual
what now!
I just used it and many does at TBHP !
Originally Posted by simply_sunny001 View Post
I was once suggested to fix 2 latches instead of one and that helped for a couple of weeks but then back to square one.
Hope this new solution of Fixing bigger latch works for longer time.
Please keep us updated about it as time progresses.
I dont have rattles just squeaks coz the small latch cant carry the weight. I found a solution though: keep a thick paper on top the beading on which the gate rests.
Edit: think Focus, a TASS centre, uses the Mobil as I remember my SA saying so. I think he just read Mobil on the can I brought and not the correct name.
Edit: Hallelujah! Saved
Thanks Mahesh.
jkdas is offline
Old 14th July 2009, 16:59   #905
Thanked: 41 Times
Hi Dadu,
I did read the same document before I went in for Delovac, But if you read the Delovac Brochure, what appealed to me was that it not only "Met" but rather "Exceeded" API - CH-4 standards (that required by Tata ). Also what caught my eye was (I Quote) :
Features and Benefits :
Modern high output diesel engines including those using EGR technology generate higher levels of soot and run at higher temperatures than older, naturally aspirated engines, which significantly increases the demands on engine lubricants. These engine designs reduce oil consumption, resulting in less fresh oil makeup to replenish depleted additives. Top piston rings are located higher on the piston bringing the oil film closer to the combustion
chamber where higher temperatures increase thermal stress on the lubricant. Higher fuel injector pressure and retarded timing improve exhaust emission control, but also increase engine temperatures and increase soot loads, including those engines operating with EGR.
The key benefits include:
-Reduced low temperature sludge build-up and high temperature deposits
-Outstanding thermal and oxidation stability
-Extended TBN reserves Improved soot handling and extended drain intervals
-Reduced oil consumption and wear protection Maintains viscosity in severe, high temperature service
-Stay-in-grade shear stability
-Excellent low temperature pumpability Easier engine start-up and reduced wear
-Superb resistance to corrosion Longer life of critical wear surfaces
See the whole brochure here : http://www.mobil.com/USA-English/Lub..._mx_15w-40.pdf
maheshmenon is offline
Old 14th July 2009, 17:33   #906
nitrous's Avatar
Thanked: 329 Times
I'm willing to relieve you of your DelOvac MX .
nitrous is offline
Old 14th July 2009, 17:51   #907
Thanked: 41 Times
what now!
So have I now. My only concern was that most auto manufacturers will look for small reasons to deny you warranty replacements in case something happens however irrelevant this may be, just to shrug off their responsibility.
Sorry pal that will have to be drained now!!
Old 14th July 2009, 17:54   #908
Thanked: 462 Times
Hi Dadu,
Yes, I understand all that, but the key words here are
"If they find out"
"During the Warranty period"
I am not saying Delovac is bad or something, just focus on the keywords and decide.
dadu is offline
Old 14th July 2009, 19:46   #909
Thanked: 41 Times
"If they find out"
Yes there is no contesting that
But my idea was that assuming we can find enough Bhp'ians who can vouch for this product (or Mobil Delvac 1 5W40, the synthetic equivalent ) we may be able coax Tata Motors to atleast test the products & consider approving the same.
Old 14th July 2009, 19:58   #910
jkdas's Avatar
Just dont ask them to check oil soon after you fill up. Drive few 100s and then
Think that should make it tough to find which oil it is unless they do a lab test !
jkdas is offline
Old 15th July 2009, 06:03   #911
Thanked: 985 Times
As long as the oil meets minimum API specs laid down by the manufacturer, I don't see any problem.I think the fault lies with TASS and their service advisers who just do NOT understand the technicalities when it comes to oils.
I had faced the same issue with M & M as well (when I owned a Scorpio).
I have been using Delo-400 in my 2.2 for past 38K kms without any problems whatsoever.
If the service advisers had their way,there would be only two brands in India:Castrol & HP ;-)
rb2399 is offline
Old 15th July 2009, 06:32   #912
Thanked: 1,790 Times
[quote=maheshmenon;1382405]
I had also mailed Tata on Saturday regarding their view on Delvac and their response is as below:
Thanking you
For Tata Motors
Customer Care Team
Mumbai
How little things change! When I bought my Palio 1.6 GTX, I got a similar answer to my query about using Mobil 1 0W-40! I was told to use the Fiat oil sold in the service center. I then shot off a mail to Fiat South Africa, they gave me a green light. Not that it meant anything in legal terms, because any warranty issues would still be a India matter.
Car companies are staffed by bureaucrats and not enthusiasts, remember that, and use your judgement. But I would not use synthetics to extend the company recommended drain interval at any time, and you will find that Mobil makes the same recommendation even for their long drain oils. In any case, I believe that oil inside a car, and more so in a diesel, expires by kms as well as time, and I would always change the oil in 6 months, regardless of kms done.
With age and experience, I have come to the conclusion that any recognized local brand oil that meets the API spec is good enough if changed regularly along with the oil filter, and that begs the question about expensive brands. Sure, if you can afford it, use it for the mental satisfaction, but I now believe that the effect is more in the minds of the enthusiasts than in the sump of the engine As is the case with other products in our lives that are backed up by psychologically clever marketing.
Fyi, I use Castrol RX Super Plus in my year old Pajero. Engine seems to love it, and it is reasonably priced taking into account the 8 litre sump capacity as well
Sawyer is offline
Old 15th July 2009, 08:13   #913
Thanked: 985 Times
[quote=Sawyer;1384654][quote=maheshmenon;1382405]
Thanking you
For Tata Motors
Customer Care Team
Mumbai
HDEO oils like Delvac MX & Delo-400 do not cost a bomb (~20-30 Rs. more than Castrol Or HP).These oil are not synthetic but come very close to synthetic oils when it comes to protection of an engine at a fraction of cost on account of excellent additive packages.
The properties of these oils are far superior (TBN,kinematic viscosity at 40 degrees & 100 degrees) as compared to others in the league.The effects of using these oils will be visible in the long run when one encounters issues like sludge formation.Delo-400 has the highest level of detergent ppm (nearly twice that of Castrol GTX diesel) which helps in dispersing the soot.So why not pay ~ 150 Rs more per oil change to save ourselves from costlier engine jobs in the future?
Maybe you should try Delo-400 in your Pajero to feel the difference ;-)
rb2399 is offline
Old 15th July 2009, 08:29   #914
Thanks, will look it up. Note though that the Castrol I use is more advanced than their GTD. I still maintain that the difference between regularly changed two good and correct grade oils, if it exists, will be found so far in the future, that it is hard to make a call at this time. And at that time, it will not be easy to isolate any one reason for the state of the engine. And other factors such as ease of availability, possibility of spurious oils, inventory turns to be sure of getting reasonably fresh stock also comes into play. And in any case, everyone from IOC onwards imports the additive packages anyway.
Sawyer is offline
Old 15th July 2009, 13:34   #915
Thanked: 41 Times
Sorry a fault, it was Rs.160.80/- per liter + VAT and total was Rs.1773/- for 10L jar
Luckily Manipal Motors (now known as Bhooma Motors, god knows why the name change) allowed me to get the oil of my choice. So delvac Mx it is
