Old 24th March 2009, 14:01   #706
Thanked: 311 Times
Originally Posted by dadu View Post
Premium or additive once is a quarter dont harm, they help clean nothing else.
Dadu, help!
What is this supposed to mean?
anupmathur is offline
Old 24th March 2009, 14:06   #707
Thanked: 462 Times
Originally Posted by anupmathur View Post
Dadu, help!
What I meant was that if you are really skeptical about using additives, you might reduce the usage to one tankful every quarter.
They help to clean.
Adc has been on premium for a full 1.5 years with no ill effects.
dadu is offline
Old 24th March 2009, 14:26   #708
They help to clean.
HPCL R&D and IOCL R&D suggest that you should run atleast 100 Kms on these "Premium" fuels for them to do their "job".
I cannot quote names but they inform the same in all their seminars.
kingshukt is offline
Old 24th March 2009, 23:04   #709
Well or the case may be that your hose was perfectly fine and when you asked them to check they applied their usual method of Shaking and pulling up the hose to check if it is not coming out and it became loose in process.
Exactly what seems to have been the case, so the learning is once again, what ain't broken, do not fix
After all this, I still have to say that Concorde/Tata guys whatever may be their expertise, do deserve the mention that they follow up well on their service.
Today my vehicle was picked up from office and delivered back at the end of the day, mid-day I received a call from them saying they are gonna change the headlight assembly on both left and right, reason being some water visible inside, I hadn't asked them to look for that as I had never noticed it in the first place and there they have done it, 6.5k under warranty, feels good to see a company standing by their products at least, there ain't many to tell of if I think hard.
So I might as well turn the stereo volume up a notch and drown a few noises, knowing that the guys are doing the best at their level to keep me running.
I was again told during service to follow the normal diesel route that I have been doing after almost 7 months of turbojet initially and so is the advice from a friend working for TML.
aburagohain is offline
Old 25th March 2009, 11:14   #710
Thanked: 462 Times
Can you ask your friend the reason for this advise ??, or is it a generic perception.
dadu is offline
Old 31st March 2009, 13:06   #711
asejwal's Avatar
Thanked: 27 Times
@Dadu
Hello there! Brother, I feel I have this 'krr-krr' noise issue with my 2.2Vtt too. However, this is very pronounced when vehicle is idle and only appears to have reduced considerably in the 4th gear. In fact, it is very similar to the 'tappet sound' of my Sierra - once my mechanic had 'tuned' my Sierra in such a manner that it had a very harsh 'tappet' sound. He said that he had 'advanced' the engine to get a good mileage. I asked him to go easy on mileage and reduce the sound and then he was able to do as instructed. This sound from my Safari is almost the same.
First, is it the same 'krr' sound that has been discussed on this thread earlier?
Will it subside with time because my Safari has only done 380 kms till date?
Lastly, please suggest that does adding a very small quantity of engine oil to a tankful of diesel (as advised by my mechanic for my Sierra) help in keeping the engine smooth in a Dicor Dafari as well?
(If this 'krr' sound dies down, my Safari's engine noise will be smooth man...alongwith the turbo whistle, it drives you MAD...)
asejwal is offline
Old 31st March 2009, 13:53   #712
Thanked: 462 Times
Originally Posted by asejwal View Post
@Dadu
It seems to be something different to what was discussed here as the "Krr" noise does not come under idling.
Dont put any engine oil etc, use an additive like system D but that too after running for around 1-2k.
Since your is a new safari, get the noise checked at T.A.S.S at your first service/checkup (1500km/ 1month)
dadu is offline
Old 31st March 2009, 17:02   #713
Unlike a Sierra, Safari 2.2 has hydraulic tappets. I was informed by TASS that these (tappets) cannot be adjusted. Yes , I have a very (please note the VERY) small tappet noise right from the beginning. I only way I can get to the root of the noise is by opening the tappet cover and this I am not going to do so on a new vehicle.
So I live with it.
Old 1st April 2009, 03:03   #714
Shyamtanu's Avatar
hydraulic tappets are expected to be better. I used to adjust it in my bike... if you reduce the fuel flow to such minimum that the engine just remains alive, then the sound is more, and this enhances efficiency, reduces idle speed, and kills the engine faster... boy, one should not put the engine on diet control.
Earlier model used to have tepet as a spring fitted pin... hydraulic stuff are expeted to be smoother, you could try asking for a adjustment of idle fuel intake tuning, if you wish. Is the rpm showing the normal one or is it slightly less than expected?
Shyamtanu is offline
Old 1st April 2009, 17:15   #715
chaxy's Avatar
Thanked: 18 Times
all sounds will settle with more usage of the vehicle. My 2.2 purrs like a cat now.
chaxy is offline
Old 1st April 2009, 21:01   #716
Shyamtanu's Avatar
Just wondering, how many kms one should have on the odo to have a 2.2 VTT settled in or run in? Not asking about TML specification but from the experience of people owning it?
Old 2nd April 2009, 08:24   #717
harjeev's Avatar
Thanked: 292 Times
I drove mine for 900 kms, then got an oil change.
After which I took it on a 1000 kms highway trip during which for the 1st 500kms I kept my speeds to a max of 70-80 kms, not crossing 2k on the RPM. Thereafter it was normal driving.
harjeev is offline
Old 2nd April 2009, 18:51   #718
Shyamtanu's Avatar
With that last post.. I became a proud BHPian.. hurray!
Thanks for the info Harjeev, as it looks, I am still bent on the beast... but the recession is not a right time really to spend a fortune... so I shall mostly hold on for now.
Back to the topic, I have another query... how much problem does one face to operate the CD player, as it disturbingly placed near the gearshift? From ADC's posts, I really do not want to take my eyes off the road for the sake of changing CDs/shifting between controls. I shall need to check it myself while I take the test drive, but what do you guys think?
Old 2nd April 2009, 19:07   #719
Abhiknov's Avatar
It is tought to operate the head unit especially in gear 1,3 n 5 for obvious reasons. Dont buy a unit with a fancy display cause trust me, unless u're 4 feet tall there is no way you can search for tracks by looking at the song name on the display. The thing is just too low on the dash.
Also be careful while buying units with pendrive support cause i've broken one borrowed pendrive when the 5th gear shift banging straight into the drive. Since then i've shifted to really micro sized pen drives.
best solution is to go for a remote on the steering. I'll just go the parking and click a picture for u. wait.
Ya done that. The remote on the steering is the best option fr sure.
The Tata Safari 2.2L Technical / Problems Thread-p1060109.jpg
The Tata Safari 2.2L Technical / Problems Thread-p1060110.jpg
Abhiknov is offline
Old 2nd April 2009, 19:44   #720
adc
adc's Avatar
Thanked: 2,290 Times
Look what that situation was and what you are trying to generalize is completely different - I was using the handheld remote of the Pioneer in the dark and other factors were there. For the actual generalization, Abhiknov has described it reasonably well.
Whats the solution - get a remote on the steering or like I did now for this overnight Kol-Gangtok journey today, dont use a remote, just press directly on to the knob and play whatever it plays!!
adc is offline
