Old 17th May 2012, 08:13   #4366
condor's Avatar
Thanked: 16,382 Times
re: The Tata Safari 2.2L Technical / Problems Thread
@Speedy Racer - is it a 2.2 or a 3.0 ? How much has it run ?
condor is offline
Old 17th May 2012, 09:50   #4367
smsrini's Avatar
Thanked: 427 Times
Originally Posted by SPEEDY_RACER
Hi All,
i am recently hearing from my driver who is driving the vehicle in India is complaining that quite frequently when he is driving the vehicle he is feeling a loss in power(not regular) and some times the vehicle is not moving beyond 80kmph is there some thing which i have to see before taking it to the service centre.
the vehicle will not be driven for next 1 month after sunday as the driver is going on a holiday for 1 month and i will come to India in June, so wanted to check is there some thing which the driver can Check or take it to the local work shop and get it checked before taking it to the Service centre.
Check if the engine check light is on indicating a limp back home mode, which essentially means something wrong.
If no indication, ask him to rev hard to clear up any carbon buildup in the egr.
Put system d with diesel, as per recommendation to help clean up any clogging in the fuel system.
Also ask him to check if there is any knocking kind of sound which indicates injector clogging..
Either way, getting the vehicle checked is a good thing to do.
smsrini is offline
Old 17th May 2012, 10:46   #4368
rajismine's Avatar
Thanked: 281 Times
Originally Posted by SPEEDY_RACER View Post
Hi All,
Seems like signs of something wrong with the Turbo. Drives tend to switch off ignition immediately after stopping and that may be one reason, if at all
Get it checked...
rajismine is offline
Old 17th May 2012, 11:00   #4369
ankur_gupta10's Avatar
Thanked: 51 Times
Hi All,
Rev car in idle and check if it is going to high RPM,s, or if there is unusual smoke. This might help pinpoint the problem. If the issue is not reproducible, the service engineers have the tendancy to shrug it off. Also keep a check for engine light, when this happens. If light comes then it is good, as the event is then recorded in the ECU, and service center has to do something about it.
ankur_gupta10 is offline
Old 17th May 2012, 11:42   #4370
SPEEDY_RACER's Avatar
Thanked: 266 Times
Yes, yesterday the check engine light has come when i asked him about this.
also he said that when the vehicle is in Idle every thing seems to be fine, pickup, Smoke etc, but this problem is not repeated or comes regular, it h
come yesterday when the vehicle was coming from my home town, and it came once in home town.
he is going on a leave only on this week end so once i am back i will take it ASC.
Get it checked...
Turbo is not yet a problem because it kicks quite good as per his analysis, i was thinking bad fuel or the supply is not good.
let me check the pipes which goes into the turbo, they might have been blocked.
SPEEDY_RACER is offline
Old 17th May 2012, 12:03   #4371
rajismine's Avatar
Thanked: 281 Times
Another thing you may check is the Alternator Regulator,
Happened with me once. Car will occasionally loose power @ about 50-60kmph and chk engine would come on and then disappear in few moments
The TASS checked battery voltage via multimeter and ran diagnosis. It was the alternator regulator which had gone bad and was overcharging the battery,
The regulator was changed and everything returned to normal
regards
Rajeev
Old 18th May 2012, 03:01   #4372
Thanked: 266 Times
Hi All got it checked and the defect has been identified as EGR value.
so ordered it getting it replaced once the item is arrived in Bangalore ASC.
i will get it changed once i am in bangalore
Old 18th May 2012, 12:27   #4373
somubj's Avatar
Thanked: 16 Times
Not sure if this was posted before, but is it possible to change the recline angle of the middle row seat? Basically, increase the angle by a few degrees. Current posture is not good for long drives.
somubj is offline
Old 18th May 2012, 12:56   #4374
Thanked: 266 Times
Yes its very much possible. as i had implemented the Third Row so for making the leg room i made the angle bit vertical.
lets take it was 90 degree's of incline, we made it to 80 degree.
and we can make it even more, just a matter of clamps which will hold the current lock position and move it further and then fix the lock on the clamp.
will try to post a picture of the clamp.
Old 18th May 2012, 13:27   #4375
somubj's Avatar
Thanked: 16 Times
Thanks, yes a picture will be very useful. I went for a long drive some time back and got complaints from the passengers that the rear set was not that comfy, i tried it and turned out that because of the wicked angle, it was difficult to relax.
I noticed that the seat rests on some plastic part and the lock, will there be any modification required to these?
somubj is offline
Old 18th May 2012, 14:39   #4376
Thanked: 266 Times
its a 3.0 ltr, and it has run 1,00,000 kms, regularly serviced
Old 18th May 2012, 14:43   #4377
Thanked: 266 Times
no modifications required on locks or plastic parts, just create a 2 plates and remove the existing bolts which are on the seats and then install the new plates. also make the similar holes and place the locks on the new plate and fix. it.
will try to source the picture as i dont have them with me now. but if you can give me a ping in June end i can show it to you on my beast.
Old 18th May 2012, 15:01   #4378
condor's Avatar
One of the causes can be the rail pressure sensor.
condor is offline
Old 18th May 2012, 19:20   #4379
Lukeskywalker's Avatar
Thanked: 1,243 Times
My Safari (62k on odo) was in the workshop for the longest time since my ownership, all of 14 days, cause :
There was water seepage in the footwells from the HVAC system, fault was diagnosed to be a faulty thermostat, but the real problem which caused the delay in the workshop was a cracked plastic hinge in the recirculation flap mechanism, this was causing the flap to get stuck between open and close.
Now, Tata Motors do not have spares of the mechanism, so a warranty claim was raised for complete blower motor assembly, the claim was approved for "blower motor only" when there was absolutely no fault with the blower motor, I was given the option to get the assembly changed on my cost, it cost ONLY 14k, I asked them to take a hike. Imagine paying 14k for something which would not cost more than 20 bucks.
Then the workshop called me one fine day and said the issue is resolved and they have "repaired" the recirculation flap mechanism. I told them if their idea of "repair" was to use superglue to fix a broken part then I will not accept it, immediately the status went from "job done" to "we will have a relook".
Finally, the A.S.C took the help of Subros the OE supplier and sourced the small plastic part, all this took them 14 full days. The damage to the pocket = 4300/- (2k for removal and refitting of dashboard and a thermostat)
The problem of water seepage seems to have stopped for now, will have to see over a period of time.
Lukeskywalker is offline
Old 18th May 2012, 19:34   #4380
Thanked: 266 Times
the issue was identified as a EGR value, its the 2nd time i am replacing it after my owner ship in last 2 yrs.
