Old 13th December 2008, 12:18   #406
ram.west's Avatar
Thanked: 32 Times
thanks mahesh!! No time to go to the service centre . Stuck in a tight schedule in office. Hope to go soon .
And folks anyone here had problems with the door pads. Mine seems to be coming off quite often!!!! whenever i shut the door the whole window rattles like its gonna break!!
ram.west is offline
Old 14th December 2008, 16:06   #407
Thanked: 41 Times
15 k Service
Guys,
Just got the truck out post the 15 k service, the mechanic at TASS advised me to get back the vehicle at 20k to replace the Gear - Box Oil, (only after 5000 km!!!) subtract that to the next service interval of 7500km, that means the truck will be in service at every 5000km, I found that absurd.
Pls comment.
maheshmenon is offline
Old 14th December 2008, 17:38   #408
Thanked: 2,752 Times
Originally Posted by maheshmenon View Post
Guys,
Pls comment.
Transmission oil change is at 20k. You might as well ask them to carry out the next service then and rework the intervals from there on.
Steeroid is offline
Old 18th December 2008, 11:26   #409
smsrini's Avatar
Thanked: 427 Times
Power Steering Leakage
About 3-4 days back noticed a leak on the sump guard. Since there were no other visible symptoms, did not bother much. Yesterday noticed that the entire power steering assy was swathed in oil and a muddy oil stain starting from the assy down to the right arm and chassis.
Surprisingly the p/s oil still shows close to max level in the oil container.
smsrini is offline
Old 18th December 2008, 19:58   #410
himanshugoswami's Avatar
Thanked: 2,628 Times
man!! i am AMAZED at the number of problems listed in this thread.`
it seems that the build quality of the 2.2 is a bit below that of the 3.0 as well. and the worrying bit is that the niggles and problems are there right from teh first batch to the latest vehicles.....
Cmon TML, u can do better!
himanshugoswami is offline
Old 18th December 2008, 20:24   #411
smsrini's Avatar
Thanked: 427 Times
Turned out to be a washer gone bad Replaced FOC. Had to pay for 0.5 ltr of PowerSteering Fluid.
smsrini is offline
Old 23rd December 2008, 12:06   #412
jkdas's Avatar
Thanked: 1,492 Times
2.2L too has heated external rear view mirrors. Just found about it last day.
jkdas is offline
Old 23rd December 2008, 12:14   #413
Only on EX and VX which have rear defoggers. It is mentioned in the manual too
kingshukt is offline
Old 24th December 2008, 00:04   #414
wheelsNsqueals's Avatar
Defogger yes. But heated ORVMs? Where?
wheelsNsqueals is offline
Old 24th December 2008, 09:30   #415
jaysmokesleaves's Avatar
Thanked: 1,460 Times
Can you explain how it operates ? I failed to find such a function.
jaysmokesleaves is offline
Old 24th December 2008, 09:35   #416
Backlit switches for ORVM adjustments ?
Hello all,
Can someone please confirm if the internally adjustable ORVM switches are backlit illuminated at night when the lights are switched on?
After my vehicle came back from the TASS with a new left ORVM, the ORVM switches on the driver door are not backlit when i switch on lights at night.
I dont remember if they were backlit(illuminated) earlier. Can someone please confirm this in their EX/VX ?
Thanks,
J
Old 24th December 2008, 09:38   #417
suman's Avatar
Thanked: 281 Times
Not as far as I can remember but will double check this tonite
suman is offline
Old 24th December 2008, 09:49   #418
Thanked: 32 Times
1. When the rear defogger is switched on, the ORVMs automatically heat up as well.
2. The ORVM adjuster switch is not backlit. Only the power window switches are backlit + the power window lock switch (glows green if locked)
hrag is offline
Old 24th December 2008, 10:36   #419
When you switch on the defogger (with the switch on the dash) the heater on the ORVMs are also switched on.
Old 24th December 2008, 12:15   #420
I do not have a power window lock switch in my EX. Is it supposed to be there?
Can you please post a picture?
So i guess its an integrated function. Ive never had the opportunity to notice.
