re: The Tata Safari 2.2L Technical / Problems Thread Quote:
Originally Posted by tsk1979 If your vehicle is under standard or extended warranty, it has to be given.
The HVAC hot air control setup is lousy in the safari, Many times hot air flap does not close. Ask them to open it and fix it for you, if not fixable replace entire center console under warranty
Vertical alignment adjusts both headlights. If one headlight is misaligned, the workshop will adjust it using screws to bring it on level with the other. then you can use the in cabin adjustment
No its not normal. Whenever service light comes, it logs an error code in the ECU. Ask TASS to diagnose and fix the problem. Many times service centers keep delaying, and when vehicle is out of warranty they will repair it and fix you with a huge bill |
Today got back the Safari and am satisfied so far. Following things done: 1. Alternator repaired under warranty. (Though the Advisor told that he personally argued with the manufacturing company and got it done. Just a personal touch he showed because always its he who attends my vehicle there. I dont mind it, thanked him).
2. He told, some flap was not closed properly in AC vent, they adjusted it. Yes, there is remarkable change in the cooling. Actually, I realized it late. Cooling was perfect when it was new. For past some time it got declined. Must have been due to that hot air , now its cooling fast and thick.
3. They checked ECU with Software, and told that they have refreshed it, there is no problem or error now. On my way driving back from the workshop, I could feel discernible change in engine sound and smoothness both. It feels so nice now. I hope service light must stop coming now.
4. They did some adjustment in headlight alignment, but, yet to check if it improves.
5. Also there was leakage from oil filter. I have noticed it, have taken it for fixing next day only. Some rubber seal in filter was cracked. Replaced filter and topped-up engine oil (only this item was charged Rs. 1061/-including taxes and 2 litrs oil).
But, in fixing Alternator, Autocop's wires seem to have been disturbed, its not working. Realized it after coming back. So shall call Autocop person on Monday/Tuesday. Till then have to do central locking manually.
Rest seems well now. Changing of headlight bulbs is left, will do it as and when budget permits. Thanks again Tanveer ji for valuable advise, otherwise I could have ignored the ECU and AC vents checking issues.
