Originally Posted by amitk26 Well no this theory hold true if you buy Diesel from IOCL pump in BS2 town and compare with Shell in BS4 area . ALL PSU Companies are also required to sell same ULSD in BS4 cities.
In-fact the PSU share the distribution network and it really does not matter if you buy from IOCL or BP or HP. Also Relainace and Essar are two big refiners and thier distribution network does not consume the production so PSU marketing companies also off-take some Diesel from reliance ( other then export)
Lubricity of fuel just affect the fuel pump bearing and you have more chance of finding Kerosene mixed Diesel at un-naamed IOCL pump then shell so mystry remians :-) for those who believe IOCL is better.
I have found no difference if the Diesel is pure , Only in cases where I filled from unknown pumps in middle of nowhere had problem when pure kerosene was filled in :-) |
Well ULSD quality and properties will depend on the refinery,the processes,additives etc.Here is an example of a diesel standard http://www.environment.gov.au/atmosp...ndex.html(This is governed by national laws and only an illustration).
There is wide margin for variations in these properties as is evident from the standards.The lubricity property (% of supfur) is limited only by a maximum value of .46 mm as per the standard under reference.
I am really not sure if oil PSUs share their fuel cos each has it's own refineries so logically they will share only if one has a shortage.Do you have data supporting it?
Diesel lubricity will affect the life of your fuel injection system.Please read below.
All diesel fuel injection equipment has some reliance on diesel fuel as a lubricant. The lubricating properties of diesel fuel are important, especially for rotary and distributor type fuel injection pumps. In these pumps, moving parts are lubricated by the fuel itself as it moves through the pump—not by the engine oil.Other diesel fuel systems—which include unit injectors, injectors, unit pumps, and in-line pumps are partially fuel lubricated.The lubricity of the fuel is an indication of the amount of wear or scarring that occurs between two metal parts covered with the fuel as they come in contact with each other. Low lubricity fuel may cause high wear and scarring and high lubricity fuel may provide reduced wear and longer component life.
The lubricity of diesel fuel can vary dramatically. It is dependent on a wide variety of factors, which include the crude oil source from which the fuel was produced, the refining processes used to produce the fuel, how the fuel has been handled throughout the distribution chain, and the inclusion of lubricity enhancing additives whether alone or in a package with other performance enhancing additives.A 1998 review paper on fuel lubricity worldwide2 showed that diesel fuel in the US and Canada is some of the poorest lubricity fuel found in the entire world.
Source : http://www.biodiesel.org/pdf_files/f.../Lubricity.PDF
I have noticed considerable difference when i had to fill in Shell diesel. |
