Old 14th December 2009, 23:58   #1591
richie4u's Avatar
Thanked: 521 Times
My car is come to its first service.What want to know is what do they typically do at the first service of the safari??.Also I want to know If there are any checks,changes that i ought to ask them at the first service from the TASS guys.Please advise.
richie4u is offline
Old 15th December 2009, 08:48   #1592
harjeev's Avatar
Thanked: 293 Times
Hey Guys
I need advise and fast
I got my safari serviced @ 25k kms (approx) and now the vehicle has run for 39k kms. So effectively it has climbed 14k on the ODO and the normal service schedule is 15k kms.
As my extended warranty is in force (bought the vehicle in Nov 2007), at how much kms should Ii get it serviced. I do not want the extended warranty to get lapsed!
Pl Help
harjeev is offline
Old 15th December 2009, 09:15   #1593
Originally Posted by harjeev View Post
Hey Guys
Pl Help
The service schedule is 15K Km or 1 year whichever is earlier.
For Nov 2007 Safari the schedule will be (assuming that you drive exactly 15K Km / year)
- 1st service Dec '07 (ODO 1500 Km)
- 2nd Service Nov '08 (ODO 15K Km)
- 3rd service Nov '09 (ODO 30 Km)
- 4th service Nov '10 (ODO 45K Km)
- 5th Service Nov '11 (ODO 60K Km)
But the condition "15K Km or 1 year whichever is earlier" would mean that you would have finished all the 5 services in the 1st year - if yr running were 60K Km in the 1st year itself.
Hope this clarifies the doubt.
kingshukt is offline
Old 15th December 2009, 10:38   #1594
tsk1979's Avatar
Thanked: 23,018 Times
HOw come you serviced at 25K kms?
Anyways 15000kms are over now, so get it serviced now(at 40K)
tsk1979 is offline
Old 15th December 2009, 10:51   #1595
bj96's Avatar
Thanked: 1,446 Times
Originally Posted by richie4u View Post
My car is come to its first service...what do they typically do at the first service of the safari...
Owner manual service booklet/schedule will have the points mentioned. However, get the engine oil + filter changed, even if, it is not mentioned in the manual or TASS says not required. Also hoist the car on the jack and walk underbelly- try to find some oild leakage. If nothing there all fine.
Originally Posted by ThE Godfather View Post
if this thak thak sound is normal.This sound comes in first, second and reverse gear only
I hope sound is not from steering system or suspension. Those gears you mentioned, transfer huge torque on drive train- sound could be from clutch release bearing or improper clutch setting driving the shaft sudenly. Get it checked. Experts may have some other angle too.
cheers,
-BJ
bj96 is offline
Old 15th December 2009, 11:23   #1596
Thanked: 41 Times
Originally Posted by dadu View Post
Sticky !!!, even oil wont remian sticky after being burnt out due to the engine heat, I hope its not the rubber grommet of your engine cover, melting down (not unusual). No spares available for that rubber grommet.
The rubber grommet melts off and normally sticks like a piece of chewing gum on the metal stud to which it mates. Highly unlikely that in ran till the engine.
The grommet is not available, but the whole cover has to be replaced and it costs upward of 2k !
Originally Posted by Rahulk76 View Post
Dadu, its sticky in nature and diesel aint sticky even if it is filled with grim. The grim was cleared with high pressure wash and then air dried. After that it came back again. I only hope that injector no1 from where its most evident doesnt have a leaky O-ring or worst tar and grim due to injector blowby. More havoc here Diesel-Central.com the technical source for Diesel Truck information, Truck Pulling, and Drag Racing
Did you check the Oil Filler Plug 'o-ring' for condition?
maheshmenon is offline
Old 15th December 2009, 11:50   #1597
Thanked: 463 Times
Please tell me if this thak thak sound is normal.This sound comes in first, second and reverse gear only
Its from Clutch Throwout bearing/ arm, usually it increases if you have had a clutch change and factory fitted ones have very minimal noise. TASS has scratched their heads over it and have even done a gearbox and clutch overhaul(R&D) for a member here with no positive results.
Hey Guys
Pl Help
Kingshuk is spot on.
but if you got your service done beyond 1 year/ 15k kms at any point of time you can throw you extended warranty out, it will never be honoured.
Oil doesnt remain sticky once burnt, so even if its leaking its not the same sticky material rahul has, thats why I was suspecting the rubbers
dadu is offline
Old 15th December 2009, 11:51   #1598
abbey4u's Avatar
Thanked: 118 Times
Has any one tried petronas urania in tata safari. It's CI4. any input would be appreciated as i am planning to get the same as my next oil change
abbey4u is offline
Old 15th December 2009, 12:29   #1599
@Dadu, This sound is from day one. I have shown them vehicle several times, all they do is, do some changes in Center Pin, and then say "Aini awaz ta normal aa bhaji" (This much sound is normal)
Should I ask them to open the clutch or something? I know if I will ask TASS guys again they will again open the center pin and will do s ome changes with it.
ThE Godfather is offline
Old 15th December 2009, 12:43   #1600
Thanked: 463 Times
They grease it, but this is not from the centre pin. Currently the solution for Throw out bearing noise is not known.
dadu is offline
Old 15th December 2009, 12:44   #1601
harjeev's Avatar
Thanked: 293 Times
Hey guys
The last service was done at 25422 kms on 11th February 2009. So I guess that I should get the next one done either in December'09 or January 2010 whenever I breach the 40k kms schedule!!! SoI have another 1k kms to go.
Thanks for the advise guys!!!
harjeev is offline
Old 15th December 2009, 12:52   #1602
Will this cause any harm to the clutch or other components?
Old 15th December 2009, 13:36   #1603
If the noise is from the clutch release bearing, then NO it does not cause any harm as per information available till date.
I suggest that you follow Jaysmokesleaves policy - Do not touch whatever is not broken.
However, if the sound really disturbs you, please check the propellar shaft for play + connection at the engine and differential end for play. The only other thing that comes to my mind is the differential itself, but that would be taking the matter too far.
Old 15th December 2009, 14:34   #1604
LionX's Avatar
Thanked: 1,120 Times
Yes, I am using Patronas Urania Supremo in my safari along with OWS220 engine protector. I felt marginal difference in the engine vibration and noise. Go ahead with the plan .
LionX is offline
Old 15th December 2009, 14:57   #1605
@Dadu, there could be any replacement? I mean can I ask them to replace something under warranty?
@King, thank you for the information.
