Old 5th December 2009, 11:08   #1546
Thanked: 463 Times
Originally Posted by kingshukt View Post
and that IMHO is the job of the vaccuum accumulator.
Yes, but when it doesnt have enough to keep up with the city braking conditions where does it go ?? (you can say the pump should do the job, but in this case it isnt doing the job) thats the reason for additional tank and now they have come up with a bigger accumulater.
dadu is offline
Old 5th December 2009, 11:13   #1547
The reasoning is correct but there is no sense in having 2 accumulators.
We have already agreed that there is a softball size spherical vaccuum accumulator (fixed on the firewall).
This link also mentions spherical accumulator .
kingshukt is offline
Old 5th December 2009, 12:45   #1548
Thanked: 716 Times
However I am trying to reconfirm from TM (innocently) as to what the black cylindrical container is ?
better not ask them mechanics at T.A.S.S calls it "Air box" and told me it is for braking now that is rough equivalent to the component in trucks.
amitk26 is offline
Old 5th December 2009, 13:42   #1549
Trucks have air brakes. The "compressed air" is stored in 1-2 mini-bullet(s) like components at the side.
My earlier post gave links for vaccuum assist brakes, Vaccuum brakes (as in trains) and air brakes (as in Trucks).
Old 5th December 2009, 17:38   #1550
Thanked: 463 Times
Yes, unless they could figure out how to work with only 1 sufficient one.
Good news is that now they have only one . The tank is gone.
dadu is offline
Old 5th December 2009, 20:31   #1551
Rahulk76's Avatar
Thanked: 235 Times
Steering Wheel Centering
Guys,
  1. Why is it so very difficult to have a perfectly centered steering wheel on a tata safari 2.2. ?
  2. Is it due to loosely engineered steering system ?
  3. And finally how to have that perfect (not like honda ) steering center ?
Personally I find it extremely shoulder paining to drive 100kms everyday with steering wheel off its standard marks. This even gets worse when a wheel alignment is undertaken at TASS or any other place. All they do is take off the steering wheel, rotate the center pin a little left or right and then tighten it up and then its moove time for shoulders . It is even worse some times
Rahulk76 is offline
Old 5th December 2009, 21:01   #1552
mercedised's Avatar
Thanked: 425 Times
Originally Posted by Rahulk76 View Post
Guys,
The same thing was happening with me before, But nowadays whenever i get the wheel alignment done i tell the guy not to centre the steering but to tilt it towards the opposite direction in which it normally tilts.
mercedised is offline
Old 5th December 2009, 21:27   #1553
Thanked: 41 Times
@Maheshmenon: what is a misaligned (turbo) hose
There were instances of the hose sliiping out of place reported here, so thats what mahesh is talking about.
Yup in my case it seems that the small hose that can be seen in the lower right side (inlet???) was mis-aligned. It was corrected but the problem still seems to be there. Can the EGR can be suspect now?
Already done a leak check on both the turbo hoses too so that is ruled out.
maheshmenon is offline
Old 6th December 2009, 11:30   #1554
Rahulk76's Avatar
Thanked: 235 Times
Mahesh, request more details on the location of the same
~rahul
Rahulk76 is offline
Old 6th December 2009, 11:45   #1555
v&v
v&v's Avatar
Thanked: 1,207 Times
BHPians,
I have two queries,
1. During my second service , i enquired with SA about greasing point in safari. He said the 2.2 doesnt have any greasing points only the center pin is greased. is this true or there are more points.
2. I want fix trumpet(Minda) horn in my beast. Want to keep the existing one and have this horn as additional (Two wiring or switch). Advice how to go about it. Does any one suggest the good shop to get it done in around delhi or ncr.
v&V
v&v is offline
Old 6th December 2009, 13:13   #1556
mercedised's Avatar
Thanked: 425 Times
Originally Posted by v&v View Post
BHPians,
I have two queries,
v&V
There are three greasing points in TCIC, donot know about DICOR one.
Old 6th December 2009, 16:37   #1557
KVS
White paint mark on Black Safari
Few months back I went to attend my cousins house warming function in a WIP construction society.
As per the instructions of the security guard I parked the vehicle. By the time I returned I see all the white marks on the car. Initially I thought they are white wash marks. But I realised these are white paint marks.
I tried using Diesel to clean the marks, but it is of no use. In one of the visits to the TASS, the service person said he will get them removed with the help of 3M guys. They used turpentine and it became mess. You can see the smudged paint marks in the first photograph. Fortunately they stopped after trying one mark itself.
The Tata Safari 2.2L Technical / Problems Thread-paint-marks-1.jpg
The Tata Safari 2.2L Technical / Problems Thread-paint-marks-2.jpg
The Tata Safari 2.2L Technical / Problems Thread-paint-marks-3.jpg
I got the waxing and polishing done from the 3M, but they are still there.
Can the expert suggest how to get rid of these marks?
KVS
KVS is offline
Old 6th December 2009, 17:12   #1558
abbey4u's Avatar
Thanked: 118 Times
not sure, but you can try nail polish remover. Let us know if that works
abbey4u is offline
Old 6th December 2009, 18:35   #1559
mercedised's Avatar
Thanked: 425 Times
KVS
Hey!! so it happened with you too.
I too got same type of paint marks when my house was in the process of painting.
I tried every kind of rubbing to get rid of them but at last the simplest method worked.
"One day i tried to remove it by scraping with my nails and to my fortune, the paint mark was removed without any type of scratches, It was after that it took me some 1/2 hour only to get rid of those paint marks."
Old 7th December 2009, 02:46   #1560
RSKSafari
Posts: n/a
If its an external paint you can try paint thinner to remove it. I had the same issue some time back. Just bought paint thinner (easily available in every paint/hardware shop).
Take little thinner on a small piece of cloth, rub the affected area. Immediately clean with a dry cloth. DO NOT RUB HARD, a gentle swipe will be enough, as if you are wiping a mirror.
Just be careful with its use, it feel cool if you touch it, but will give burning sensation on prolonged exposure. Best is wear a glove (also available in the same shop).
Let me know if it works. If you in Bangalore, I can give you a demo I have some thinner left from the last time
Ravi
