Old 31st July 2008, 13:23   #1
DCEite's Avatar
Thanked: 3,479 Times
Outside air entering cabin even with a/c in recirculation mode.
The a/c of my car throws outside air even in the recirculation mode. This is more noticeable when the vehicle in vicinity is emitting large amount of smoke, and it enters my cabin even in the recirculation mode.
Can it be related to the fact that my a/c servicing is due. It has not been serviced for the past 4 years.
DCEite is offline
Old 31st July 2008, 13:27   #2
JayD's Avatar
Thanked: 2,615 Times
I'm experiencing the same problem in my matiz, I had the whole system checked, and there are no leaks apparently, also, the fresh air vent is closing properly. Its a major irritation when driving past dumpsters especially!!
JayD is offline
Old 31st July 2008, 13:30   #3
Thanked: 311 Times
To an extent ALL cars take in some amount of external air.
The only thing that needs to be verified is whether the recirculation and fresh air flaps are doing their job properly.
anupmathur is offline
Old 31st July 2008, 13:32   #4
DieselFan's Avatar
Thanked: 260 Times
As time passes the beading which fills in the gaps in the door becomes ineffective and lets in outside air and sound.
DieselFan is offline
Old 31st July 2008, 13:38   #5
srishiva's Avatar
Thanked: 2,260 Times
It could be through the door beads. In one of my previous cars, you could feel the cool air entering through the door latch mechanism when driving fast.
srishiva is offline
Old 31st July 2008, 14:02   #6
bblost's Avatar
Thanked: 17,936 Times
If air can come in, it will also go out
Use a couple of smoky agarbathis inside the fully closed car.
A person outside keeps a check to find where the smoke cames out from.
bblost is offline
Old 31st July 2008, 14:41   #7
Thanked: 2,735 Times
Simple cost effective solution. But use a container to hold agarbathi & its ash in order to avoid messing up carpet/mats.
sukiwa is offline
Old 31st July 2008, 14:44   #8
Vid6639's Avatar
Thanked: 44,134 Times
well as far as i know the outside air almost always comes in even if the ac is in recirculation mode. The only thing the recirculation switch does is provide a direct path.
That's why the higher end cars have the plasma filter, pollen filter and what not to clean up the outside dirty air as much as possible before it enters the cabin.
example: the captiva has a pollution filter.
Vid6639 is offline
Old 31st July 2008, 14:44   #9
esteem_lover's Avatar
Thanked: 513 Times
I dont think it is a good idea & i dont believe it will work either. As suggested by anupmathur check if the air intake flap operates correctly. The car cabin is not air tight, there will be places where smell/sound can come in.
esteem_lover is offline
Old 31st July 2008, 14:45   #10
wanderernomad's Avatar
Thanked: 1,296 Times
Nice idea, totally innovative but would it work if one wants to check if the flaps are doing their job or not? Depending upon the make of the car it might be a long wait.
wanderernomad is offline
Old 31st July 2008, 14:49   #11
tsk1979's Avatar
Thanked: 23,484 Times
Its the outside air flap. With time and dust lodging etc., it starts leaking. In most cars you need dashboard removal for cleanup and realignment. Don't have any idea about WagonR though.
tsk1979 is offline
Old 1st August 2008, 22:41   #12
Path_Finder's Avatar
It could be because of bad or dirty flaps. In many of the cars where this is controlled thru the soft switch, it could also be some problem in the system. I had the same problem – the first time I reported, they gave back saying there is no problem. Next service I insisted on a thorough check and then it turned out be some relay problem after replacing which now it is fine.
Note from TBHP support: since it contained various [FONT], [COLOR] and [SIZE] tags. Posting with such text formatting should be avoided on Team-BHP as it is inconvenient for members to read post. Kindly go through Announcements section before proceeding.
Thanking You for your anticipated co-operation
The Team-BHP Support Staff
Path_Finder is offline
Old 2nd August 2008, 10:54   #13
viper's Avatar
Thanked: 20 Times
The most common suspects would be the fresh air flap and the grommets through which the hoses, cables etc are passed thru the firewall. Unless you want to use the fresh air option i would suggest a simple cost effective permanent solution to that problem.
Go to any Ac mechanic/repair shop and ask him to seal of the fresh air flap with heatlon, This is what I have done in almost all my indian cars. Should not cost you more than Rs50/- including labour. Time taken 10-15 mins max.
Viper
viper is offline
Old 2nd August 2008, 12:56   #14
toiingg's Avatar
Thanked: 308 Times
But if we seal it, that means we can never use the AC in fresh air mode. Correct ?
toiingg is offline
Old 2nd August 2008, 14:36   #15
danlalan's Avatar
Thanked: 281 Times
Originally Posted by viper View Post
Viper
HAd the same problem with my Ikon. Went to the a/c mech and he did seal the fresh air flap. Its a very simple process.
@toiingg if your need fresh air....Power your window down!!! and up again!!!
danlalan is offline
