Old 14th July 2014, 16:26   #121
Desmosedici's Avatar
Thanked: 622 Times
Re: Airconditioning in the Gypsy
Originally Posted by anupmathur View Post
True, but you might someday decide to take a trip to the Himalayas up North, especially Ladakh! That is, in fact, what the Gypsy would call 'home'!
Yes. Totally agree. Waiting for that plan to happen someday. Will think of the heater option then for sure.
Desmosedici is offline
Old 28th November 2014, 08:39   #122
caged_nomad's Avatar
Thanked: 53 Times
Hi I recently had an air conditioner fixed on my 2000 model 1.3 mpfi Gypsy.
I had two queries
1) what is the normal power loss for a sanden 507 compressor for a well kept (recently rebuilt) engine
2) I get the feeling that the air conditioner is draining the battery really quick, I am running the stock alternator and battery in addition to a baleno radiator and electrical fan setup! have any of you needed to upgrade either the battery or the alternator to cope with the additional load?
Cheers!
Abhi
caged_nomad is offline
Old 28th November 2014, 21:09   #123
Thanked: 311 Times
Originally Posted by caged_nomad View Post
...I am running the stock alternator and battery in addition to a baleno radiator and electrical fan setup! ...
You could try to set up the electric fan to come on via a thermostat so that it does not run needlessly all the time.
Have you also increased the fan size for the radiator fan?
anupmathur is offline
Old 9th December 2014, 13:52   #124
Thanked: 53 Times
Thanks for the tip, the problem was diagnosed to improper earthing, and I believe it has been sorted out! (perils of building a car long distance )
Sadly it could not be road tested as the rear door hinge gave way and the door unlocked it self.
Old 20th July 2015, 13:24   #125
cool_dube's Avatar
Thanked: 4,689 Times
Hi guys,
A question unconventional to this thread - what would it take to 'remove' the a/c setup from a Gypsy? Would there be any chances of compromising on the reliability front? Would it be as good as the 'stock' state, viz. before the a/c was fitted?
Regards...
cool_dube is online now
Old 20th July 2015, 14:22   #126
vdm
Thanked: 26 Times
Hello everyone,
1. Do we get OE A/c in the gypsy?
2. What's compressor does it come with?
3. Does the OE A/c comes with heater?
The gypsy is ex-army 413 and didn't have any blower or compressor. Consulted the A.S.S. but they were ignorant about it.
Can anyone please help me with this.
vdm is offline
Old 20th July 2015, 16:03   #127
Thanked: 622 Times
Originally Posted by cool_dube View Post
Hi guys,
Regards...
Yes, you can. An AC install doesnt include any modifications to the engine or its internals. But i am wondering why would you want to remove the AC. Any specific reasons?
Originally Posted by vdm View Post
Hello everyone,
1. No. Gypsy doesnt come with AC from the factory. It has to be retrofitted.
2. No Compressor. But most people use the Sanden Compressor.
3. No. But while retrofitting the AC, you can include the heating coils as well and make provision for the same.
Cheers,
Raj
Desmosedici is offline   (2) Thanks
Old 7th July 2016, 10:05   #128
KkVaidya's Avatar
Thanked: 835 Times
Originally Posted by COUGAR View Post
I have just acquired a UNICLA controller: the kind that comes with the blower unit.
I have a smiliar AC controller in my 1993 Contessa Classic. Off late it seems to give problems. Can you help from where did you source this controller? I want one.
KkVaidya is offline
Old 25th May 2018, 21:23   #129
Thanked: 30 Times
Is there a place in Bangalore where someone can fit an AC in a Gypsy? Any leads would be much appreciated.
sawan_dubey is offline
Old 28th May 2018, 10:42   #130
I had airconditioning added in my Gypsy by Wecool back in 2014. Here's their location in maps: https://www.google.co.in/maps/place/...5!4d77.6091392
benkoch is offline
Old 18th March 2019, 13:59   #131
Vmax1200's Avatar
Thanked: 781 Times
My Gypsy had overheating issues after installing the AC. Last week I placed the AC radiator below the floor pan. The cost was 2,500 for the pipe and 1,000 for labor.
Now no overheating issues
Attaching the picture for reference
Vmax1200 is offline   (1) Thanks
Old 18th March 2019, 14:59   #132
Turbanator's Avatar
Thanked: 31,040 Times
I don't think overheating issue will go with this. I too have similar setup but am not happy. Also, get a steel screen mesh, it will save the cooling coil from any stones/ chips.
Turbanator is offline   (1) Thanks
Old 22nd March 2019, 19:03   #133
sanjeevkanjoor's Avatar
Thanked: 24 Times
Hello,
I have fixed a Superking AC compressor in my 1.3 MPFI gypsy.
I am facing an overheating issue and also the power of the engine(lag in picking up speed even in second gear) reduce if the AC is switched on!.
Is the Power lag due to wrong selection of compressor?.
What will be the best brand of compressor to resolve the power lag to an acceptable limit?
sanjeevkanjoor is offline
Old 22nd March 2019, 21:29   #134
Vmax1200's Avatar
Thanked: 781 Times
Originally Posted by sanjeevkanjoor View Post
Hello,
I am using used Maruti Esteem compressor. It has decent cooling and negligible power loss. The total cost for the installation was Rs 11,000.
For the overheating issue, you have to place the AC radiator under the car.
Vmax1200 is offline   (2) Thanks
Old 20th August 2019, 01:09   #135
Bump-Stop's Avatar
Thanked: 64 Times
Hello everyone, I've recently installed an ac in my MPFI gypsy. Although I do not face any overheating issue, needed advice on following:
1. Once the engine has warmed up to its operating temperature, and I stop / idle due to traffic, engine trips due to load once compressor comes on line.
2. Above does not happen on a cold engine when idle rpm is slightly higher.
3. It has been suggested by someone to increase idle via the throttle body screw. Not really sure if this would be the correct way to address the issue.
4. Any way to resolve the issue via ECM or other means? If so please do share elaborate steps.
Thanks &
Best regards
Bump-Stop is offline
