Old 24th July 2008, 21:49   #1
finneyp's Avatar
Thanked: 400 Times
Is Oil filter and Fuel filter different?
In my last Service (27 K kms), I noticed two seperate entries for Filters in the Bill:
Fuel Filter: Rs.126
Oil Filter: Rs.154
So far I thought Fuel & Oil filter are same thing, was suprised to notice that these two are separate filters, can the BHPians confirm the same?
finneyp is offline
Old 24th July 2008, 21:56   #2
toiingg's Avatar
Thanked: 308 Times
Indeed there are two filters.
AFAIK One between the petrol line (between the tank and the engine), to stop any solid particles (rust etc) from entering the engine.
The second is for filtering the engine oil in the engine bay.
toiingg is offline
Old 24th July 2008, 22:01   #3
Thanked: 37 Times
Both are different, we change oil filter every single time oil is changed. Fuel Filter will be changed once in 30,000km and interval varies slightly for every car. Fuel filter has to be changed If we suspect we filled really bad fuel.
Today I changed changed engine oil and oil filter for my Matiz and used engine flush since its old car suspecting there should be lot of deposits inside.
This is what I know Hope I am right.
Ravi.
ravibhat is offline
Old 24th July 2008, 22:22   #4
aaggoswami's Avatar
Thanked: 3,000 Times
Yes they are different.
As the name suggests, Fuel Filter is for filtering the fuel imputirites.
The Oil filter is for clearing any grit.
aaggoswami is offline
Old 24th July 2008, 23:55   #5
RedMM340's Avatar
Thanked: 34 Times
Not if you have an oil burner, a.k.a. a diesel. Then the fuel filter is an oil filter.
RedMM340 is offline
Old 25th July 2008, 00:08   #6
CrAzY dRiVeR's Avatar
Thanked: 78,820 Times
Back to topic, he is having a Palio 1.2 petrol and hence the bill is justified. The prices seem reasonable too!
CrAzY dRiVeR is offline
Old 25th July 2008, 00:28   #7
drpullockaran's Avatar
Thanked: 388 Times
Smiley is important.
The smiley is very important here in the above post. He is just pulling your leg as diesel engines are also called oil burners. There are separate filters for fuel and oil in diesel engines too. Serious.
drpullockaran is offline
Old 25th July 2008, 01:19   #8
RedMM340's Avatar
Thanked: 34 Times
Come on, I thought that the original post was a leg pull! Of course the oil filter is different than the fuel filter!
I paid Rs. 79.11 for the oil filter and Rs. 124.44 for the fuel filter plus 12.5% tax at the dealer. So your oil filter price of 154 is a bit on the high side.
RedMM340 is offline
Old 25th July 2008, 10:09   #9
Thanked: 2,735 Times
@ finneyp
Oil filter needs to be changed every time engine oil is changed. Oil filter price is on high side unless it's special oil filter, please check what brand was used during change.
Fuel filter need not be changed that frequently unless fuel used was of inferior quality. Check Palio manual for change interval of fuel filter.
sukiwa is offline
Old 25th July 2008, 10:40   #10
Thanked: 463 Times
Fp, it was surprising you had that doubt even after so many posts, but we all learn someday
dadu is offline
Old 25th July 2008, 11:45   #11
finneyp's Avatar
Thanked: 400 Times
Thanks guys for the confirmation!
This was the first time Fuel filter was replaced in my car, hence the doubt arose!
finneyp is offline
