Old 20th June 2008, 21:13   #1
bluestraveller's Avatar
Signs saying "No engine brakes" - Why?
I have seen sign boards that say "Do Not Use Engine Brakes" on quite a few roads on the US. I have never really understood this but my closest guess would be noise pollution? Can anybody elaborate?
bluestraveller is offline
Old 20th June 2008, 21:57   #2
aah78's Avatar
Thanked: 3,409 Times
noise & slip
Yes, you've understood correctly. That's a warning for trucks.
It's mostly due to the loud noise that engine brakes produce when engaged but the warning may also be displayed in case there's a chance of slipping (eg. icy roadways).
For technical details on engine brakes, you can look up Google.
Ever heard a sudden loud noise - like a machine gun going off inside your head - while driving on the freeway? That's the semi in the next lane using his engine brake.
aah78 is offline
Old 21st June 2008, 00:27   #3
Thanked: 9,250 Times
Here are couple of you tube videos on jake braking trucks.
Sankar is offline
Old 21st June 2008, 19:49   #4
Randhawa's Avatar
Thanked: 361 Times
Engine brakes with trucks is something to do with opening the exhaust valves to TDC to slow down the engine hence reducing the brakes without actually applying the brakes.
Randhawa is offline
Old 23rd June 2008, 03:54   #5
noidaboy's Avatar
Thanked: 268 Times
According to the 2nd video it does sound like machine gun being fired.
noidaboy is offline
