Old 24th April 2008, 22:11   #1
zoomingbhat's Avatar
ABS light comes ON after 150kmph
Hi Guys,
I had done Bangalore Nandi Hills a fortnight back.I took my car over 150 on the 6 lane highway several times.
Now once the speed crosses 150 The ABS light on the instrument panel comes On and it dosnt go Off even when I lowered the speed. I had to switch of the engine and again start for the Light to go off.
I don't know what is the problem of is this done for a safety purpose for a speed above 150. Anyone facing a similar issue.Please help.
My Car is Accent Viva petrol with ABS.
zoomingbhat is offline
Old 24th April 2008, 23:36   #2
jaysmokesleaves's Avatar
Thanked: 1,466 Times
Go straight to hyundai and get it checked. If ur regularly doing 3 digit speeds its best not to take a chance with the brakes. If the abs fails you will still be able to brake but braking distance will increase.
jaysmokesleaves is offline
Old 24th April 2008, 23:39   #3
Thanked: 71 Times
Is it? I have read on other forums here that ABS does not reduce braking distance.
alto99 is offline
Old 25th April 2008, 00:05   #4
Thanked: 306 Times
Same happened with me. Ealier I had VIVA the abs and Hand brake lights come when I exceed speed excess of 160 km/hr. But similar thing happened with my Swift which also has ABS. Maybe the abs stops working after that speeds.
low_bass_makker is offline
Old 25th April 2008, 00:43   #5
shuvd's Avatar
Could be a problem with the ECU. Try re-setting it. If that fails, go to Hyundai A.S.S and do a scan. ABS should function at all speeds.
shuvd is offline
Old 25th April 2008, 01:10   #6
abhik's Avatar
Thanked: 13 Times
LBM a safety system is surely not designed to give up on you when you need it the most.
abhik is offline
Old 25th April 2008, 03:39   #7
aah78's Avatar
Thanked: 3,409 Times
That's a debatable issue depending on what sort of situation you're facing - while having to brake.
ABS (Anti-lock Braking System) is designed to do just that - prevent your wheels from locking up!
The braking distance also depends on a lot of external factors - some of which include the condition of your tyres, and the road surface you're driving on.
aah78 is online now
Old 25th April 2008, 08:00   #8
clevermax's Avatar
Thanked: 2,897 Times
That's right. Since rolling friction is better than sliding friction, breaking distance reduces significantly in slippery surfaces due to ABS.
Some people think that breaking an ABS car in all circumstances has better breaking effect than a non-ABS car. It is not like that. Both breaking effects are exactly the same if the wheels are not locking up. ABS kicks in only when wheels are just getting locked up.
clevermax is offline
Old 25th April 2008, 09:01   #9
May be because some cars are unbreakable while some are not. Jokes apart,I suppose ABS will increase the BRAKING distance in extremely slippery conditions,all though it provides better control over steering the car.
aravindwarrier is offline
Old 25th April 2008, 10:01   #10
Thanked: 463 Times
Rightly, ABS helps you to maneuver better under sudden braking conditions. It does not increase or decrease the braking distance.
In fact in the Safari manual its clearly mentioned that ABS will not reduce braking distance.
But all this is and for this thread
dadu is offline
Old 25th April 2008, 10:05   #11
Alfa_Kilo's Avatar
Thanked: 13 Times
A well calibrated ABS will stop the vehicle in a shorter distance than it would take with the wheels locked up. But some drivers can accurately modulate brake pressure in non ABS vehicles to keep the tyres rotating, manage to stop the quickest. This is called threshold braking.
ABS is less effective on loose surfaces.
Alfa_Kilo is offline
Old 25th April 2008, 10:10   #12
Thanked: 31,078 Times
Probably the sensors can't keep up with the speed - might be dirt on the sensros
ajmat is offline
Old 25th April 2008, 10:54   #13
The light comes on as soon as I cross 150 but the hand brake light i have not come across.
And this light goes of only when I stop and restart the engine.
Btw how to reset the ECU I have no idea
Old 25th April 2008, 11:04   #14
Rahulkool's Avatar
Thanked: 2,125 Times
You have get it done in the service center i guess, they will connect the scanner to the ECU and can reset it
Rahulkool is offline
Old 25th April 2008, 11:08   #15
bblost's Avatar
Thanked: 17,967 Times
disconnecting the battery for some 15 mins will reset the ECU.
please correct me if I am wrong.
bblost is offline
