Old 23rd May 2012, 21:30   #436
bluevolt's Avatar
Thanked: 3,477 Times
Re: OEM car battery life - How long did your OE battery last?
So after exactly 5 years and 1 month and 19 days the battery packed up and refused to start the car (WagonR). Got it checked from a battery shop and found two cells dead.
Replaced with Amaron Flo battery with 4 year warranty (2 year replacement + 2 year pro rated) for Rs. 3100 after giving the old battery for Rs. 500.
Similar Exide battery was for Rs. 2600 only but got the Amaron as the current one lasted for 5+ years.
bluevolt is offline
Old 23rd May 2012, 21:44   #437
Thanked: 43 Times
My car batteries lasted like below,
Car no.1 - 4 years
car no.2 - 4 years
Car no.3 - 3years and 3 months
Car no.4 - Just 2 weeks old and still running
nandans2005 is offline
Old 2nd June 2012, 17:10   #438
jeganatu's Avatar
Thanked: 1,102 Times
Originally Posted by informmaha View Post
I have a chevy beat petrol and its 1 yr and 10 months old now. It has covered 11000K approx and it has not rested even for a day from the day it was bought, atleast we have driven it for a minimum 2 kms ( I am insisting this point not to make assumptions that, may be the car might have been rested for some days or weeks or months) and the OEM battery went dead just after the warranty period, in 14 months. So in here the battery is not used to a great extent or no case of not using it at all. When inquired about that in exide and in chevy service center, they told warranty is for 1 year ( I was in an assumption that warranty was 2 years for OEM batteries) and I need to replace it. I was so frustrated with exide at that time and would I go on a replacement with exide again? nooooo way. I have experience with amaron living for 7.5 years in our old santro, so without doubt went for amaron battery now.
Hey I think Oem battery will carry 1.5 year warranty, Chk your battery warranty card with the Manufacturing date on the battery. And details in the car manual for confirmation about warranty dates.
jeganatu is online now
Old 2nd June 2012, 18:17   #439
informmaha's Avatar
Thanked: 41 Times
Yes I checked with that and it was 1 year.. And before checking I also called up exide customer care and got the details of the nearest dealer and they also confirmed that its 1 year. I never give up before a fight and the fight for this is over
informmaha is offline   (1) Thanks
Old 2nd June 2012, 23:32   #440
Thanked: 43 Times
So, today after 5 years and 4 months, and 94165 Kms (Verna Diesel), my OEM EXIDE battery breathed its last. It was giving subtle indications in the last couple of months - by means of the prolonged cranking during cold start. It was more pronounced in the last couple of weeks. Finally, the car completely refused to start this morning.
Got an Amron as the replacement (18 months warranty) for 4.2K after exchange.
vivekkr_99 is online now
Old 19th June 2012, 11:12   #441
pjbiju's Avatar
Thanked: 1,133 Times
The Amaron OEM battery in my Swift VXi has completed 6 years and 2 months now. Frankly speaking I never had the battery checked unless the service center was checking it during routine servicing.
pjbiju is offline
Old 19th June 2012, 11:33   #442
gpa
gpa's Avatar
Thanked: 345 Times
Originally Posted by gpa View Post
Update: The car was left idle for about five weeks without the -ve terminal being disconnected. Last Thursday, I started the car and with some effort it roared to life. However in the evening on the return drive from work, the cranking was noticeably heavier with more effort being needed. Went home and checked the static volt reading and it read 12.2 volts.
Removed the battery and gave it to a local guy for a recharge for 24 hours and then refitted it. Static reading after the charge had jumped to 12.7 volts and the guy said the battery will be good enough for a few months more so long as I drove the car regularly.
Will wait till the onset of winter before I change the battery.
Guess, I will have to eat my own words. I don't think the battery will last till winter. I have been driving the Alto for the past few days in city traffic and I have noticed that despite running regularly, the cranking takes a bit more effort now. Plan to replace the battery by the end of this month.
This is the OEM Exide battery which came with the car and is now four years and a month old.
gpa is offline
Old 21st June 2012, 12:27   #443
invincible7's Avatar
Thanked: 173 Times
Somehow missed this thread, OK here is one question I would like the ans on. Apologies if this has been discussed earlier, couldnt find it.
How long will the battery last (OEM with the car) with a good ICE ?
eg - 2 amps, speakers and sub using 2 independent 4 AWG kits.
invincible7 is offline
Old 21st June 2012, 20:22   #444
R2D2's Avatar
Thanked: 5,849 Times
Batteries are like incandescent bulbs - you never know when they will die. Like a bulb flickering before it dies or when it goes 'pop' when switched on, there will be subtle signs of impending failure.
There are TBHPians whose OEM batteries have lasted anywhere between a few weeks right up to 6-7 years. It's a proper hit and miss. My experience has ranged between 2-4 years.
As for the load that you have described - it all depends on your alternator's capacity (which car do you have?) and driving conditions. In highway driving conditions the battery will remain charged as the alternator supplies all the power required, in slow bumper to bumper traffic with AC, your stereo may drain the battery. Powerful alternators have no issues supply power even at low RPMs.
Guess, I will have to eat my own words. I don't think the battery will last till winter. This is the OEM Exide battery which came with the car and is now four years and a month old.
Any battery over 2.5-3 years old needs to be monitored closely for signs of weakness.
An OEM batt @ 4 years is living on borrowed time. To avoid getting stranded when you least expect it, have it changed ASAP. Rains put a heavier load on the electrical system as wipers, AC/heaters and lights are switched on whilst driving especially in the city at low RPMs.
Originally Posted by prashant316 View Post
That is an interesting point sir. If an at car does run out of battery, is there any other way to get it started?
Not an automatic. You must jump start it. If a manual transmission, then you can choose to push start though that it is not recommended. Jump starting is the way to go in both cases. Keep a set of cables handy if your battery is old.
R2D2 is offline   (1) Thanks
Old 22nd June 2012, 08:54   #445
Thanked: 173 Times
The car in question is Maruti Swift and its driven 7 days 90% times with just one day of idle period at max. The daily run is over 70-80 kms easily.
Old 22nd June 2012, 09:18   #446
R2D2's Avatar
The Swift (assumed petrol) should have a ~45A alternator, while the Swift diesel has a more powerful one. You shouldn't have any issues with the kind of running your car does.
R2D2 is offline
Old 22nd June 2012, 19:16   #447
Thanked: 173 Times
Got the battery checked at the battery wala, was showing signs of weakness after testing.
It lasted me exactly 3.5 yrs, still has some juice left and it now moves into the older car, was an Amaron brand only.
This time went with Amaron FLO with 2+2 yrs warranty.
Old 23rd June 2012, 22:02   #448
thoma's Avatar
Thanked: 1,486 Times
OEM Amaron replaced with Amaron Flo for i10 after 4 years with 27k on the odometer and lots of start stop usage.
thoma is offline
Old 23rd June 2012, 22:24   #449
Thanked: 249 Times
Mercedes E250 Diesel W124 Series :
Amaron 74 DIN Battery replaced today after 6 years !! It was still going OK but changed it to be sure "just in case".
Incredible performance of the battery I must say.
Ravindra M is offline
Old 23rd June 2012, 23:07   #450
Gansan's Avatar
Thanked: 5,917 Times
Mine is an OEM Amaron battery; now three years old and counting.
Gansan is offline
