Update to my A/C Issue.
The issue never got resolved properly till now and they keep changing the heating unit at every service (thanks to extended warranty).
I had got my car serviced on Mar 23rd at Lathangi Ford. Got the car back and I could hear a tuck-tuck sound from under the dashboard. Traced it to the heater solenoid. Aparantly, the service guy had by-passed the heater (exactly what dashoin talked about) inorder to solve the A/C problem and conveniently forgot to inform me. Quote:
Originally Posted by dashoin Before anything else, check the coolant in the car. The diverter valve uses the coolant for the heating function. If it is broken ( most likely), coolant would have also leaked out.
In case you would like to check it out yourself, look towards the RHS of the engine. You will see 2 rubber hoses going towards the cabin. The valve would have broken off at the point where the pipes end.
In case you can get it replaced under the Maintenance plan or warranty, it would be better to go to Ford ***. In case your car is not covered under any of these and you dont want the heater, join the 2 hoses together. One of the hoses also has connections for coolant temperature - it will continue to work even after you bypass it.
I had it replaced once outside - after that bypassed it and have run like that for about a year now without any problems - except missing the heater in Dilli ki sardi. Seen a few more cars with the valve bypassed. |
Went to Lathangi today to get it resolved. I had already spoken to Mr. Venkat, the service manager yesterday and he assured me a quick turnaround. But this morning, had to wait 30 min for the work to start. The time taken for the actual work was under 10min, but to get the bill and car delivery, there was another 45 min wait .
In short, I had to waste 1hr 15 min for a 10 min job, not to mention the time taken to drive across bangalore to reach the service center.
Does anyone have any high level contacts at Ford India? I want to give them a piece of my mind. Also, I want to suggest a quick service desk where they can sort out minor issues without making the customer wait for hours.
Apparently, Metro Ford is also similar. I had stopped there to get the wiper blades replaced and the service adviser said it'll take him a min of 45 min to get it replaced and give back the car. Went to an outside accessory shop and finished the job in 2 min.
