Old 17th March 2008, 15:07   #1
Skoda-Octavia (2.0 Petrol) - Steering Wobbling
I have a Skoda-Octavia (2.0 Petrol); the car is about 4 years old. I have done 50 K servicing recently and immediately before that the tie-rod of my right-front wheel was bent. This was replaced by the dealer. Post which I have done a complete wheel alignment check and found everything was perfect until recently I figured out that while doing high-speed > 100 KMPH the steering wobbles. My A.S.S adviced me to change the complete steering column which will cost atleast 45 K. Just wanted to know if this is due to the steering or some problem in suspension. Just FYI when my tie-rod was bent steering was shaking vigorously while I was driving to my A.S.S.
Please help.
Thanks and Regards
dibbasu
dibbasu is offline
Old 17th March 2008, 15:30   #2
vikram_d's Avatar
Thanked: 1,188 Times
Check wheel balancing. This is the most common culprit for high speed steering wobble.
vikram_d is offline
Old 17th March 2008, 15:31   #3
Thanked: 31,073 Times
Sounds like you hit a big pothole. Since the wobbling happens at a particular speed, have you tried wheel balancing ? Might be worth spending Rs 1000 rather than 10's of thousands!
ajmat is offline
Old 17th March 2008, 15:59   #4
PatienceWins's Avatar
Thanked: 981 Times
It seems like wheel balancing issue. Get the balancing done.
PatienceWins is offline
Old 17th March 2008, 19:06   #5
Thanks to all of you. I will get the balancing done and let you alll know the result.
dibbasu is offline
Old 17th March 2008, 20:03   #6
Xehaust's Avatar
Thanked: 82 Times
Also happens when your tyres need changing if they are wornt out or very old (say 3 yrs or more).
Happened to my Astra when i went over 70. It happens at different speeds with different cars and different circumstances. Got the tyres changed and its perfect.
(Dint know much about cars at that time )
EDIT: Have your tyres been changed since you bought your car?
Xehaust is offline
Old 17th March 2008, 20:30   #7
iraghava's Avatar
Thanked: 281 Times
Also while getting the balancing done ask the dealer to also check the tyres & to ensure that none of them have any sidewall bulges in them especially the wheel which took the impact which led to the bent tie-rod.
In all probability whatever caused the tie-rod to bend might also ahve caused a sidewall bulge leading to balancing issues at high-speeds.
iraghava is offline
Old 18th March 2008, 19:31   #8
45K is too much for steering column. The price is for steering column alone or steering column with rack?
Ramesh75 is offline
Old 19th March 2008, 15:50   #9
dinu2506's Avatar
Thanked: 975 Times
I too believe it could be either due to
1) Wheel balancing
2) One of the tyres might be having a bulge
dinu2506 is offline
Old 19th March 2008, 15:56   #10
spadival's Avatar
Thanked: 29 Times
Didnt you get the wheel balancing done along with the wheel alignment check? You can get it done at an independent tyre shop rather than the A.S.S. Sounds like your A.S.S is trying to pull a fast one on you.
spadival is offline
Old 19th March 2008, 15:57   #11
Wheel balancing my friend balancing , Get it chked
nicejits is offline
Old 2nd April 2008, 19:18   #12
Got the balancing done; the problem has reduced a bit. But it still exists. Worst part is when the car is not running or steering lock position when I push a steering wheel a little then I can feel some sound like something has been broken inside the column. Any clue?
dibbasu is offline
Old 2nd April 2008, 23:44   #13
shuvc's Avatar
Thanked: 359 Times
How did the tie rod get bent?
@razor4077 had a 2.0 octy in his family. IIRC he had also mentioned that the steering was wobbly above 120. He might be able to give some inputs.
shuvc is offline
Old 3rd April 2008, 00:17   #14
I was hit by a rail fish-plate which was on the road. But it was changed.
dibbasu is offline
Old 3rd April 2008, 23:46   #15
JayD's Avatar
Thanked: 2,615 Times
Check the wheel rim for any bends. Or is it done while balancing??
JayD is offline
