Old 7th March 2008, 19:06   #1
shineshine's Avatar
Thanked: 44 Times
A small difference between DDiS and 1.3 MJD.
I just observed an interesting thing...
The fiat 1.3 JTD (MJD) multi-jet direct injection system is supplied with fuel via a common-rail system at a pressure of 1600 bar, whereas in SWIFT DDiS it is 1400 bar (Taken from Swift Brochure).
How it happened? Any clues?
shineshine is offline
Old 7th March 2008, 21:09   #2
gr8guzzler's Avatar
Thanked: 87 Times
Where did you get the specs for Fiat 1.3 MJD from? Can you post it here?
gr8guzzler is offline
Old 7th March 2008, 21:45   #3
1100D's Avatar
Thanked: 4,116 Times
Dont Worry, wait for the 1.3 MJD application of the Palio to hit the roads, you could see a reduction in the boost pressure of that as well. For indian condition cars are detuned.
1100D is offline
Old 10th March 2008, 23:05   #4
simplythebest's Avatar
Thanked: 11 Times
Can a remap of the engine increase the pressure?
Or will the pump itself be different.
simplythebest is offline
Old 12th March 2008, 13:34   #5
Thanked: 268 Times
What difference does this pressure difference make on the road ?
mithun is offline
Old 14th March 2008, 00:54   #6
moralfibre's Avatar
Thanked: 14,426 Times
Something more about the engine that I learned yesterday. The rocker arms of the car made brittle. The rocker arms would break away thereby saving your valves from bending. I don't have much technical detail but was taught this by guys who underwent training at Fiat Ranjangaon before the Palio 1.3 MJD was launched.
moralfibre is offline
Old 14th March 2008, 01:48   #7
hellspawn's Avatar
Thanked: 9 Times
Infractions: 0/1 (10)
Why would they break i.e.under what circumstances have they provided this so-called safety feature.
hellspawn is offline
Old 14th March 2008, 03:18   #8
1100D's Avatar
To prevent hydrostatic lock, in event of the engine sucking in water while negotiating a waterlogged area. Its better to break the rocker arm than break everything else.
1100D is offline
Old 14th March 2008, 08:32   #9
Thanked: 11 Times
Interesting... is this a feature only on the indian version?
Old 14th March 2008, 10:00   #10
rider60's Avatar
Thanked: 56 Times
one OT question, can the same pete's box be used for both these cars? i mean they have the same engines right? any leads on this? after all we are talking about engine comparisons right?
rider60 is offline
Old 14th March 2008, 10:09   #11
Thanked: 321 Times
More compressed fuel means efficient burning which converts to more fuel effiency.
Ajaybiz is offline
