Old 16th February 2008, 01:09   #1
Thanked: 57 Times
Which Radiator flush?
I have to flush my Indica cooling system, which are radiator flush solutions available in the market?? I want to use this as the tata service cneter told me that they well remove the radiator and give it to some one to pressure clean and they do not have flush.
Please let me know what to use...
Last edited by Rehaan : 16th February 2008 at 05:03. Reason: Please use 1 or 2 punctuation marks at a time instead of 13.
dinar is offline
Old 16th February 2008, 04:58   #2
OWS or bardahl man , if you know of anything else let me know
cyneverdie is offline
Old 16th February 2008, 06:40   #3
moralfibre's Avatar
Thanked: 14,424 Times
ABRO is more easily available. I have tried it and it is good. Anything from STP should also be available. Let me know if you would like me to get it for you to Goa if its unavailable there. I am coming on 22nd and leaving on 23rd.
moralfibre is offline
Old 16th February 2008, 07:47   #4
arpandiv's Avatar
Thanked: 62 Times
Why do we need to use a radiator flush?
At What intervals?
arpandiv is offline
Old 16th February 2008, 14:17   #5
Thanked: 57 Times
Hey thanks dude..your coming down for just one day ????
At What intervals?
It keeps the cooling system clean, hence efficient,usually the service center should do it at around 30-45 k,but they do not do it, and tend to clean it by using pressurized water.
dinar is offline
Old 16th February 2008, 15:59   #6
moralfibre's Avatar
Yes I am coming down for just a day (sadly). You want me to pick up radiator flush for you then?
Old 16th February 2008, 18:17   #7
arpandiv's Avatar
Thanked: 62 Times
how does sludge etc form into the radiator system in the first place?
arpandiv is offline
Old 16th February 2008, 18:43   #8
moralfibre's Avatar
It isn't usually sludge, mostly there are deposits of rust in the cooling system. Best way to minimize damage inside the radiator is by adding distilled water rather than tap water.
Old 18th February 2008, 03:57   #9
firstly you have to use distilled water or your just asking for it.
2ndly at least with maruti s and MOST cars , you have to flush and replace coolant every 20 000 km or 1 year AT LEAST.
The OWS FLUSH i strongly feel is the best followed by tectaloy
Old 18th February 2008, 06:36   #10
moralfibre's Avatar
It isn't an option. You MUST use distilled water. But if you see most of the service centers they would use tap water.
Old 18th February 2008, 22:07   #11
Thanked: 57 Times
@ Moralfibre, thanks but I got the thing here... will try to meet up when your down.
dinar is offline
Old 18th February 2008, 22:13   #12
Thanked: 57 Times
It's not sludge, it's simple what happens to metal when immersed in water???????? Rust, this flush solution is used to remove the rust from the system and keep it clean.
coolant solution and distilled water help reduce the formation of rust but still there is some amount of rust formed.
so it's advisable to flush the system.
dinar is offline
Old 23rd October 2008, 20:51   #13
adityamunshi's Avatar
Im getting cycle fast flush for 200. Info here : Cyclo :: Products That Work.
Or i can get 3m radiator flush. Any experiences with either??
adityamunshi is offline
Old 23rd October 2008, 21:11   #14
Thanked: 57 Times
I have used this one, and it works really nice.
dinar is offline
Old 23rd October 2008, 21:52   #15
gd1418's Avatar
Thanked: 729 Times
If you are using coolant and replacing it at regular prescribed intervals then pressure cleaning is the best method to remove deposits & scales in the radiator.
The best way is to remove the bottom most hose of the radiator and then remove the cap of the radiator and put pressurised water in it. It shall thus remove all residue from the engine block as well.
BTW, I used ABRO radiator flush in my Scorpio at its 75K kms service for the first time. Then very carefully examined the drained coolant and also filtered it through a cloth. Not a single particle of any deposit or scale or sludge. I've been regularly replacing the coolant at every 20K kms.
gd1418 is offline
