Old 10th January 2005, 15:06   #1
amitoj's Avatar
Thanked: 3,499 Times
Different types of Clutches ...?
I guess there have been a lot many discussions on the clutch and how it works and how to make it work.
But whats a performance clutch? How is it different from a race clutch? How are both of these different from a normal clutch?
My car has done 90+K kms, running on the same factory fitted clutch. Is it time for me to change the clutch? I am told the average life of clutch plate is 60K kms. How can i find out whether i need to get the clutch plate changed?
Amitoj
amitoj is offline
Old 11th January 2005, 08:57   #2
speedsatya's Avatar
Thanked: 741 Times
amitoj ,
wat the heck r u talking.
that ur using the same clutch for 90k kms.
maruti shud give u an award for good driving.
regarding the diff types of clutches we both r in the same boat.
speedsatya is offline
Old 11th January 2005, 10:03   #3
Domnic's Avatar
Clutch, well the different types of clutch (stock,pro-stock,street-race,performance,turbo,triple-plate) etc etc do serve the same purpose. To push all the power from the flywheel to the wheels, without slippage.
When we add more power to the engines, stock clutch assys cant take the load and tend to slip and loose part of the power, This is why we use perofrmance clutch's.
The difference between the stock and performance ones are the Cover Assemblies. The stock one can only clamp the clutch and flywheel with a certian amount of pressure. Performance ones have higher clamping force which clamp the clutch disc and flywheel better. So there is less slippage and total power is delivered to the box.
Now, Clutch discs, Stock clutch discs are usually made of Asbestos based compunds, though they have started using fibres now due to EPA regulations. Performance clutch plates use many types of compounds from fibres to CF. The best clutch assy's now in making are the Billet Carbon clutch's, They consist of 4 plates, one loading and cover assembly. These plates are similar to the ones used in F1. These plates cost around 1.5lakhs. These plates have a 650+ Torque Cap.
Dom
Domnic is offline
Old 11th January 2005, 11:55   #4
lamborghini's Avatar
Thanked: 5,933 Times
cool
now why didnt anyone tell me about this before ???
i just got my palios clutch replaced yesterday
how much are performance clutched for anyways
lamborghini is offline
Old 11th January 2005, 11:58   #5
Thanked: 320,987 Times
Lambo,
For regular driving, stock clutches are the best bet. I have driven Toyotas with performance clutches and they can be very harsh and snappy in power delivery (a pain in bumper to bumper traffic).
They are best left for usage in competitions.
GTO is offline
Old 11th January 2005, 12:08   #6
Shan2nu's Avatar
Thanked: 127 Times
Hmm just wonder, will a Civic Type R's clutch fit on a Vtec? Now the Civic is a powerful car producing around 197bhp. Surely that clutch has to be 10 times better than the one on the Vtec. So, instead of buying a performance clutch, if i can fit that cluth onto my car, wont it be better (considering that my car hasn't got any power upgrade)?
Shan2nu
Shan2nu is offline
Old 11th January 2005, 18:04   #7
Domnic's Avatar
True, performance clutch's are very difficult to drive in our indian conditions.
Shan it is possible, infact let me know if you are coming to bangalore or bombay, i have a honda surprise for you.
Dom
Domnic is offline
Old 11th January 2005, 19:07   #8
z klasse's Avatar
Thanked: 29 Times
Dom
You got a Centerforce clutch?
z klasse is offline
Old 11th January 2005, 21:14   #9
speedsatya's Avatar
Thanked: 741 Times
wat clutch will fit the zen,and how much wud it cost
Old 12th January 2005, 01:26   #10
Domnic's Avatar
The surprise you mean??... no no, its more than a clutch.... will let all you guys know shortly. And yes i used to use centerforce clutch's now only exedy on all my cars.
Exedy performance or turbo clutches are made for your car. They range from 8k to 15k. Else for a zen, pick up the esteem flywheel, and load an esteem clutch assy, should be more than enough for a stock zen, as the esteem clutch is larger and more area to grip. Pick up the Valeo genuine imported or the SGP imported ones which are pretty good.
Dom
Domnic is offline
Old 12th January 2005, 08:23   #11
z klasse's Avatar
Thanked: 29 Times
No no no dom. I wasnt saying about the surprise. I was just asking if you were using that clutch cause it makes alot of difference. Expensive stuff but worth it as u can use it for 40k kms without any hassles.
z klasse is offline
Old 12th January 2005, 09:31   #12
Domnic's Avatar
Hello,
Oh ok, well i dont use centreforce, though they are good for the price. I prefer the exedy's. They are a bit more expensive but work far better than the centerforces
Dom
Domnic is offline
Old 7th April 2010, 13:29   #13
sdp1975's Avatar
Thanked: 1,278 Times
Are there any clutches apart from hydraulic clutches? The hydraulic clutch is the most common type we hear of ? I'm talking of passenger vehicles here, not sports.
Just wanted to know about the different types of clutches used in vehicles.
sdp1975 is offline
