Old 8th January 2008, 10:27   #16
jat
Thanked: 7 Times
Originally Posted by arunnn View Post
I have seen many cars parked with the Wipers folded up. Is there any advantage of this practice ( other than during washing). Will it help in any way to improve the life of wiper blades.
-Arun
It is followed all over the world especially in dry areas.
As wipers are not used for sometime, dust settles where the wiper is resting on glass. This dust hardens up and may not be cleared with general cleaning. Later, when it is used, it may scratch the glass. To avoid this, the wipers are folded up.
jat is offline
Old 8th January 2008, 10:36   #17
bblost's Avatar
Thanked: 17,894 Times
In apartment parking complexes there usually is atleast one car that has not been used for a real long time and may also have its wipers down.
Try to get the wiper up, you will find that its slightly stuck to the glass.
bblost is offline   (1) Thanks
Old 8th January 2008, 10:38   #18
ram_hyundai's Avatar
Thanked: 53 Times
see the right explanation for the same is that when its a hot day the rubber portion of the wiper when in contact with the glass would be over heated.a couple of such ocassions would be enough to harden the rubber of the wiper.more over ,in the case of cars idle for a longtime,the dust accumulates on the wiper.this will also add to the deterioration of the life of the blade.
its always better to fold the wiper when not in use for a couple of days.
ram
ram_hyundai is offline
Old 8th January 2008, 10:40   #19
Thanked: 321 Times
I think both reason's are correct, my car waser keeps them folded upwards during washing and i have to unfold them before driving.
Ajaybiz is offline
Old 8th January 2008, 11:14   #20
The folding of wipers is a good practice even during the monsoon season. This would free flow of water from the wind shield as well as it would abstain prolonged exposure of the wiper blade with water which can bring down its life.
A soft dry wiper blade gives optimum cleaning hence it is good to fold the vipers.
star_is_here is offline
Old 8th January 2008, 11:36   #21
ashthedivx's Avatar
Thanked: 24 Times
ram
i second that....
ashthedivx is offline
Old 8th January 2008, 11:39   #22
akash_m's Avatar
Thanked: 102 Times
Come on all of you! There's no technical reason for leaving the blades up.
It only symbolises that your car has been cleaned! This way you can tell even from 10th floor that it has been cleaned for the day by the cleaner. Many car cleaners even fold your side view morriors out along with wipers to depict that the car has been cleaned.
akash_m is offline   (1) Thanks
Old 8th January 2008, 11:42   #23
benbsb29's Avatar
Thanked: 14,181 Times
Maybe the increased air resisitance with the blades folded up helps keep the vehicle stationary, working as an alternative braking system.
On a serious note, the others have already mentioned the reasons.
benbsb29 is offline
Old 8th January 2008, 12:12   #24
Thanked: 194 Times
Keeping the wipers UP can also be dangerous!
I have known of many instants when the wiper has snapped back to position and Cracked the windscreen on the modern cars where the spring tension is high! So beware. and dont allow the cleaner to put it up while cleaning. he should just lift the wiper arm with one hand and clean the glass below the wiper with the other, and let the wiper rest back in position.
scooby05 is offline
Old 8th January 2008, 13:17   #25
normally_crazy's Avatar
Thanked: 543 Times
Well the rubber will harden even in upright position guys !!
If the wipers melted and stuck to the glass - we would have many wind screen changes Dust can accumulate but lifting the wiper and blwoing the dust is a solution. Also wipe the blades with a wet cloth before getting them back in position. That should be fine.
Actually its dangerous to keep wipers in upright position as Scooby has rightly said and there is a real danger of people walking past just tap the wiper and make it fall on the windscreen.
typically you should change the wipers just before monsoon every year.
normally_crazy is offline   (1) Thanks
Old 8th January 2008, 13:20   #26
vnabhi's Avatar
Thanked: 2,425 Times
That's a good one
Perhaps another reason could be that it prevents dogs from taking a leak on the car's tyres, as they may think someone else is on the job.
vnabhi is offline
Old 8th January 2008, 14:14   #27
President's Avatar
Thanked: 190 Times
Wiper Blades
Although, I too follow or rather initiated the practice in my society of keeping the wipers up on a stationary car, years ago, I sometimes do think the harm being caused on the spring of the wiper arm. Will it not lose its tension slowly day by day?
Scratching my balding head!..........
President is offline   (1) Thanks
Old 8th January 2008, 23:07   #28
esteem_lover's Avatar
Thanked: 513 Times
Yeah & please buy only Bosch or Syndicate wipers as they are the best, IMHO.
esteem_lover is offline
Old 23rd January 2008, 19:18   #29
Edsel Rulez!'s Avatar
Thanked: 33 Times
Forget keeping the wiper up while parking, I realised there are folks who keep it up while driving! I spotted this dude last week at the Four Bungalows signal in Andheri West, Mumbai. Maybe he wanted to give someone the finger and the wiper came in handy?
Edsel Rulez! is offline
Old 24th January 2008, 00:29   #30
motorheadinc's Avatar
I see lots of humor running around here.
would like to add my thoughts too.
Maybe the blades are taking a break from work.
I would go by the opinion on dust. the fine particles can actually scratch the glass.
motorheadinc is offline
