Old 2nd May 2009, 18:21   #106
kalaks2000's Avatar
Dry Ice in Bangalore
Hi Folks,
Has anyone tried this method of removing dent with dry ice in Bangalore. I tried to locate some dealers and they don't have the dry ice here..need to look at far of places at Malleswaram and localities. I stay on airport road...any suggestions..
kalaks2000 is offline
Old 8th August 2009, 15:39   #107
arjyamaj's Avatar
Thanked: 316 Times
Right, so I had a look at this thread a few days back (I have a few dents which arent worth the MASS estimate given to fix them). The theory seemed to be sound- that metal will contract when cooled rapidly.
So I went to the local ice cream guy (one of those cycle cart guys) and asked him about dry ice. He explained that they get it from the supplier factory in Badarpur (I live in Delhi) for free of cost. So I asked him if he could get me some- as luck would have it, he had some with him right then and was happy to gove me some.
So I came home and tried the dry ice rubbing bit. I have three dents- one is a scratch dent- from a cycle that fell on the car, one is a slight depression where a bike barely bumped me and a third is a large scraping deformity made by a ^&%^$@! drunk driver.
I tried on all three dents. Unfortunately, it didnt work. I remained at each for atleast 10 mins- tried rubbing gently, tried a bit of pressure too (melting point decreases with pressure)- nothing happened. The dents are still there, happy as ever.
arjyamaj is offline
Old 8th August 2009, 16:01   #108
Thanked: 1,793 Times
Hmm, so this is another myth. Silly question, but it was dry ice that turned directly to vapour? And the way it is supposed to work is to just hold it in direct contact with the dented metal to supercool it for it to jump back into place, using a piece of cloth to keep your hand intact.
Has anyone else gotten this to work?
Sawyer is offline
Old 8th August 2009, 17:11   #109
arjyamaj's Avatar
Thanked: 316 Times
@ sawyer- that's right, CO2 cant exist in the liquid form at normal atmospheric pressure. Which is why it sublimates directly from solid to vapour (much like napthalene balls).
I guess it is a myth. Unless if I'm doing it wrong?
arjyamaj is offline
Old 25th May 2010, 12:34   #110
Thanked: 18 Times
Anyone using Dent King?
Has anyone of ever used Dent King or is aware of it? This product is from Wonder Brands and being advertised a lot on Tele-shopping channels. Here's the link to this product on wonderbrands website:
Products
This product reportedly removes any small/medium sized dent (they call it pop-a-dent). I am actually thinking of purchasing it; however, the general reviews on internet about this product are not very encouraging.
Any light thrown on this matter would be highly appreciated.
sheetumanu is offline
Old 25th May 2010, 12:39   #111
condor's Avatar
Thanked: 16,798 Times
Brother had tried it, and apparently was a wasted effort. He threw it into the trash after that.
condor is offline
Old 25th May 2010, 12:47   #112
Thanked: 18 Times
Thanks for this really quick response mate; Looked to me a total waste at the first glance; however, somehow got tempted to try my hands on it and hence this thread.
Old 25th May 2010, 13:06   #113
bblost's Avatar
Thanked: 17,751 Times
Might as well give this a try
http://www.team-bhp.com/forum/techni...t-rs-12-a.html
bblost is offline
Old 25th May 2010, 13:10   #114
MAS
MAS's Avatar
Thanked: 1,621 Times
I have many times seen the advertisement on television and was tempted into buying one.
Condor: Did it work atleast in removing part of the dent or was it just like a cheap chinese toy?
MAS is offline
Old 25th May 2010, 13:15   #115
condor's Avatar
@MAS, apparently not good atall.
Incidentally, I was checking out such stuff. This particular one uses glue and I was skeptical about it till my brother confirmed it's 'value'. This thing is also priced well above it's cost on Amazon.com.
Suggest you guys try the one that @BBlost has provided a link to. It's cheaper, and in case it doesnt work, then you can still use it at home for what is actually intended for
condor is offline
Old 25th May 2010, 13:34   #116
aargee's Avatar
Thanked: 10,048 Times
From what I found in TBHP, this product is not much appreciated. Here're few other links on removing dents, if that is what you're looking at
1. http://www.team-bhp.com/forum/access...h-remover.html
2. http://www.team-bhp.com/forum/techni...-you-know.html
3. http://www.team-bhp.com/forum/techni...nt-repair.html
aargee is offline
Old 25th May 2010, 15:04   #117
sgiitk's Avatar
Thanked: 4,808 Times
When I was a student in the UK in the 70's garages would often make a tiny hole and then use a jig which was essentially a heavy block on a bar with a small screw at the end to pull out the dent - was called the dent puller. Once the dent was pulled the hole was covered up with epoxy, and the paint touched up or a decal put. Now you can use a hot melt glue in place of the hole. That is all.
sgiitk is offline
