Old 20th November 2007, 15:03   #1
InternetUser's Avatar
A loud 'thud' sound whenever my Ford Ikon passes over potholes on the road.
I'd recently bought a used 2006 Ford Ikon 1.3 Flair with 30,000 KM covered.
There's a certain issue that I've found with the car, what's the possible reason for this issue:
I hear a loud 'thud' sound whenever the car passes over potholes or speed breakers on the road, while driving at anything higher than a 20 KMPH speed. This occurs with both sets of wheels--the front as well as the rear wheels. The only way to avoid this sound is to slow-down completely while driving over rough roads. My other car--a Maruti Esteem doesn't make any sort of sound while traveling over the same roads.
What can be the possible causes of this sound? Does this issue occur with any of the other cars of this model?
Thanks.
InternetUser is offline
Old 20th November 2007, 15:05   #2
kpzen's Avatar
Thanked: 1,882 Times
Get the suspension bush(rubber) checked or even replaced.
kpzen is offline
Old 20th November 2007, 15:10   #3
headers's Avatar
Thanked: 563 Times
I'd agree.. But its strange that Ford's suspension bushes wear out at 30K kms..Maybe non genuine mileage..
headers is offline
Old 20th November 2007, 15:14   #4
What's so strange in that, headers? Its the same in my Ford Ikon 1.6 2005 model and not even 30k km on the odo!
I'd just say the suspension is a real noisy one.
cya
A
Absar is offline
Old 20th November 2007, 15:17   #5
snaronikar's Avatar
Thanked: 31 Times
Yeah...even mine too. I have 2004 Ikon Flair. Done around 15K kms. It also gives a loud thud sound when even you gove over a hump >25kmph. But it is okay and managable.
snaronikar is offline
Old 20th November 2007, 15:24   #6
normally_crazy's Avatar
Thanked: 543 Times
That is quite normal for an ikon. It actually thumps over the pot holes. Very noisy suspension it has. But for your peace of mind , get the bushings checked and replaced if necessary.
normally_crazy is offline
Old 20th November 2007, 17:17   #7
gbpscars's Avatar
everybody has said it,... so do i. just check and / or replace the suspension bushes. it comes as a complete replacement kit.i did this for my OHC sometime back and did not go further to change the suspensions as was thought / adviced before i did this.the difference was quite obvious.
gbpscars is offline
Old 20th November 2007, 17:22   #8
Yeh Suspension must be culprit, pls get it chked !
nicejits is offline
Old 20th November 2007, 17:29   #9
benbsb29's Avatar
Thanked: 14,184 Times
I dont think that is a cause for concern. Its a feature/trait of the ikon.
My Ikon Flair which is now at about 12K+ kms on the odo also exclaims the same way when its pushed over speedbreakers. I guess its got to do with the stiff suspension it is endowed with.
benbsb29 is offline
Old 20th November 2007, 17:54   #10
Jaggu's Avatar
Thanked: 17,293 Times
its the suspension rebound damper thats making the thud sound. you can just do a routine check of the suspension and if everything is aok, leave it there.
Jaggu is offline
Old 20th November 2007, 18:21   #11
gbpscars's Avatar
it is surprising to me a bit that quite a lot of ford owners agreeing to this sound to be common!!!
am just adding in a quick way to check your suspension...
- park your car on a solid and even surface with no tilt
- apply pressure using yourself at a point right over each wheel (of course one at a time) and try to depress the suspension setup by pushing it downwards.
- the car body must bound back with a firm, non-lethargic single bounce
- no creaking sound must be heard
- now,...drive onto an empty and straight road and while the car is going steadily and straight folloing an imaginary or the painted line, leave your hands off the steering wheel (do this preferably below 35 kmph)
- the car must traverse a straight line and not pull towards one side.
then, if you hear the thud sound and if you have a ford, live with the sound.
else change your suspension bushes.
this is more than enough for the daily drivers.
gbpscars is offline   (1) Thanks
Old 20th November 2007, 18:28   #12
sanju.sreekumar's Avatar
I guess i have nothing new to mention here. I just got the suspension bushes replaced a couple of days back.
sanju.sreekumar is offline
Old 20th November 2007, 18:30   #13
benbsb29's Avatar
Try crossing the same bump at the same speed with a loaded car, and it might scrape the bump, but you will not hear any 'thud' sound from the suspension.
benbsb29 is offline
Old 20th November 2007, 22:34   #14
esteem_lover's Avatar
Thanked: 513 Times
I prefer to hear the thud than to hear my car scrape through every pothole. But it is disappointing that the ikon suspension has to give up so early. Just see if you can deaden that thud sound.
esteem_lover is offline
Old 21st November 2007, 14:19   #15
benbsb29's Avatar
John i dont think thats because the suspension has given up. I was saying its actually how the suspension is. I got the same feedback from other sources as well whom i got in touch with.
benbsb29 is offline
