Old 13th November 2007, 17:21   #1
nitrous's Avatar
Thanked: 333 Times
Shelf life of Engine oil
Guys,
My Sumo needs an engine oil change and the API-CI rated Castrol GTX Diesel available at the distributor is dated 07/2006 which is 16 months old.
Can I safely use it?
nitrous is offline
Old 13th November 2007, 17:24   #2
1self's Avatar
Thanked: 334 Times
If it is in a sealed can....i really do not think there will be a problem.
1self is offline
Old 13th November 2007, 17:28   #3
n_aditya's Avatar
Thanked: 3,806 Times
I dont think it will be an issue Nitrous. Engine oil is designed to perform in pretty harsh conditions like high temperature etc. So just ensure the container is sealed to rule out any pilfering or adulteration and you're good to go.
n_aditya is offline
Old 13th November 2007, 22:03   #4
tsk1979's Avatar
Thanked: 23,484 Times
In a sealed condition its not a problem at all.
tsk1979 is offline
Old 13th November 2007, 22:17   #5
kpzen's Avatar
Thanked: 1,882 Times
Mostly all engine oils are certified with a shelf life of 5 years.
kpzen is online now
Old 14th November 2007, 10:04   #6
Rtech's Avatar
Thanked: 369 Times
Yup. You can safely use it. also, its a Sumo, so it's not very particular about the oil it uses! lol
Rtech is offline
Old 14th November 2007, 13:07   #7
iraghava's Avatar
Thanked: 281 Times
Originally Posted by Rtech View Post
Also, its a Sumo, so it's not very particular about the oil it uses! lol
ROFL
Anna, that's hardly old stock in Oil terms!
iraghava is offline
Old 14th November 2007, 14:39   #8
hey man
mobil 1 has a very safe self life of 5 years
synthetics do have a longer shelf life in harsher conditions as compared to rock oil
: just make sure the bottles sealed
cyneverdie is offline
Old 14th November 2007, 19:35   #9
nitrous's Avatar
Thanked: 333 Times
Taking all the Oil-walas green signal, I've bought the oil.
nitrous is offline
Old 3rd April 2008, 09:47   #10
rippergeo
Posts: n/a
sorry for digging up an old thread, but i found this with the search function
but is it OK to use oil that has been opened but not used? its been sitting on my shelf for 2 months with the lid closed tight, but not sealed.
a full 3 litres of magnatec, which is sufficient for my DDiS.seems a waste to throw it away just cos it was opened.
does the oil degrade just sitting on the shelf?
Old 3rd April 2008, 10:03   #11
nitrous's Avatar
Thanked: 333 Times
Can be used,rg.
OT:
Magnatec is not diesel oil.Especially new gen diesels require atleast CG/CH-4 rating.
nitrous is offline
Old 3rd April 2008, 11:29   #12
tsk1979's Avatar
2 month oil is safe to use.
But not this magnatec for your swift. Swift requires API-CH, Magnatec is API-CF4.
tsk1979 is offline
Old 3rd April 2008, 11:54   #13
jkdas's Avatar
Thanked: 1,496 Times
Swift needs just 3lit? Xing needs 3.3L for top up.
jkdas is offline
Old 3rd April 2008, 12:54   #14
rippergeo
Posts: n/a
thanks for the replies guys! but, its a 10W 40 oil meets SAE,CF, API standards. is that not sufficient? 3 litres is enough for the swift D. atleast, it fills up when i empty 3 litres into it.
Old 3rd April 2008, 13:39   #15
tsk1979's Avatar
Check out your Swift D manual I think it says API-CH required, and not API-CF
The series is CD,CF,CG,CH,CI
If your manual says CH you can put in API-CH or API-CI.
Castrol GTX Diesel(Not GTD) is a common API-CI oil available and its pretty cheap too(20% less than Magnatec)
tsk1979 is offline
